2013 SB600 bogging out - HCS Snowmobile Forums
Old 01-21-2020, 09:01 AM   #1 (permalink)
Member
Current Sled(s): 2013 Switchback Adventure
Previous Sled(s): Fusion 600
Favorite Riding Area: Northern Michigan
19-20 Mileage:
18-19 Mileage: 1000+
17-18 Mileage: 750
16-17 Mileage: 1000
Riding Since: 1971
Default 2013 SB600 bogging out
Before I start throwing parts at it, I wanted to get some ideas from you guys. Iím on a 2013 SB adventure 600.
About 15 miles into my ride the sled shuts off like I hit the stop button. It started right back up, so I thought I did. A few miles later, same thing, and just kept stalling out. I managed to limp it home, but it only ran 45 mph max and if I let off the gas would stall right away as if starved for fuel. BTW, at the second stall out I put new plugs in it.
Because no dealers stock ANYTHING anymore, I have a new fuel sock on order (Iíve never changed it). Any other ideas?
Home in 48661 is offline   Reply With Quote
Old 01-26-2020, 06:51 PM   #2 (permalink)
Member
19-20 Mileage:
17-18 Mileage: 750
16-17 Mileage: 1000
Riding Since: 1971
This weekend I replaced both the fuel sock and the filter. The sled will start up and idle but is only running on one cylinder. Both plugs are sparking, so it must be fuel related? Now I’m kind of at a loss. Carburetors I understand, not this new-fangled injection stuff. Any suggestions on what to do next? Trade it in? Keep riding my fusion? At least that old girl is bullet proof, otherwise I’d really be bumming this season.
Old 01-26-2020, 07:17 PM   #3 (permalink)
york08's Avatar
Current Sled(s): 2018 assault 800
Previous Sled(s): 99 xc 700. 02 pro x 600. Edge xcr 800. Iqr 600. 2013 Indy600
Riding Since: 98
I would do a compression check to be sure everything is good with engine. If compression is good in each hole. I would think you have a plugged or bad injector or fuel pump not providing enough pressure?
york08 is offline   Reply With Quote
Old 01-26-2020, 08:16 PM   #4 (permalink)
Member
19-20 Mileage:
17-18 Mileage: 750
16-17 Mileage: 1000
Riding Since: 1971
Thanks. Didn’t do a comp test yet. The way the problem came on all of a sudden makes me think its an injector or other related issue. Does gum-out work in these things or am I looking at a tear-down?
Old 01-26-2020, 08:49 PM   #5 (permalink)
sleeping_dragon's Avatar
Riding Since: 1974
Id compression test it....could also be a crank bearing.
How many miles on it?
sleeping_dragon is offline   Reply With Quote
Old 01-27-2020, 02:43 AM   #6 (permalink)
siralop700's Avatar
Current Sled(s): 2014 Indy 800, 2001.5 xc 700ev Many more
Previous Sled(s): Favorite Previous TXL 340 AAEN setup
Favorite Riding Area: Michigan
Riding Since: 1980
A crank seal or intake boot is possible. Any lights or codes on the dash?
siralop700 is offline   Reply With Quote
Old 01-27-2020, 09:10 AM   #7 (permalink)
Member
19-20 Mileage:
17-18 Mileage: 750
16-17 Mileage: 1000
Riding Since: 1971
It has about 5k miles on it total, 1500 since it was professionally rebuilt. It’s been running perfectly up until it ‘stalled’. When that happened it flashed ‘det’ on the dash, but only for a minute. At that time, it would re-start but not idle or go over 45mph. After fresh plugs and a new sock and filter, it will start and idle ‘fine’ but not really, since It appears that only one cylinder is getting fuel. No lights or codes are currently showing.
I will check the compression and seals, but I’m sure if this thing had carbs on it, I could just take it off and blast it with some gum-out and everything would be fine. Is there an equivalent cleaning procedure for injectors? Or is that a trip to the dealer? This CGI crap or whatever it is, is all Greek too me. Too many darn computers!! Now if you’ll excuse me - I have to chase some kids off my lawn so I can yell at the clouds.
Old 01-27-2020, 11:17 AM   #8 (permalink)
Current Sled(s): 2016 Pro-S Switchback
Previous Sled(s): 2007 IQ 600+2011 Pro-R 800
Favorite Riding Area: Bayfield Co., WI.
17-18 Mileage: 1558
Check closely the wiring that runs to the injectors. The cable ties sometimes ware though causing a short. Hard to see, so inspect carefully.
Stormrider3
stormrider3 is offline   Reply With Quote
Old 01-27-2020, 11:32 AM   #9 (permalink)
Lexuslover's Avatar
Current Sled(s): 2012 Switchback Pro R 800
Previous Sled(s): 2001 800XC 1999 XLTSP
i was chasing a very similar issue and it was my injectors. I would bring it to the dealer like i did and ask for a digital wrench diagnosis. There should be codes. Actually just waiting for my injectors to come in today so i can replace them. 5800 miles on my sled with 1100 of that on my rebuild
Lexuslover is offline   Reply With Quote
Old 01-27-2020, 12:25 PM   #10 (permalink)
Member
19-20 Mileage:
17-18 Mileage: 750
16-17 Mileage: 1000
Riding Since: 1971
If I understand it, the injectors aren't available individually? It looks like they come as a set with the harness. Polaris part #4013394. New they are $339. but I see used ones on ebay for less than half that. Would it make sense to pick up a set on ebay? How can I know if they would be good? Can they be tested/cleaned while off the sled? Sorry for the stupid questions, this is my first problem with fuel injection.
