2007 sdi 600 dies intermitently - HCS Snowmobile Forums
REV Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-14-2012, 06:57 PM   #1 (permalink)
Newbie
Default 2007 sdi 600 dies intermitently
my 2007 sdi 600 will run and then it dies and sometimes won't start back up. It may run for an hour on the trail the it dies and the gauges get stuck half way. It will usually start back up an run again. Anyone else had this? thanks Matt3552
matt3552 is offline   Reply With Quote
Old 02-14-2012, 07:31 PM   #2 (permalink)
AkS144's Avatar
Current Sled(s): 2008 Ski Doo Summit 600 HO SDI
Favorite Riding Area: The Mountains
I've heard there's a relay that can cause some crazy shit to happen to your sled, you might want to try and swap that out. I think it's inside that fuse box but don't hold me to it.
AkS144 is offline   Reply With Quote
Old 02-15-2012, 12:07 PM   #3 (permalink)
IF its anything like the '06's,there's a wire thats Zipped tied together near a harness under or behind the airbox somewhere thats common for getting worn thru or breaking. You wont see it unless you remove all that crap blocking it. I've never seen it myself but it was a problem on ours. Check the dealers to see if that could be it 'cause it sounds like an electrical issue.
denny4 is offline   Reply With Quote
Old 02-15-2012, 01:11 PM   #4 (permalink)
catrules2000's Avatar
Current Sled(s): 162" 2005 F-7/2007 Summit SDI
Previous Sled(s): T-Cat, ZR, EXT, V-Max
Favorite Riding Area: Starvation Lake & Rabbit Ears
18-19 Mileage 535
17-18 Mileage: 511
16-17 Mileage: 930
15-16 Mileage: 985
Riding Since: 1980
I had this happen on my 07' 600 SDI Summit one time. 20-25 miles after lunch and the thing just shut off going down the trail. Thought I locked it up. Pulled the DESS, plugged it back in and the thing started right up. First and only time this has happened in 3200 Miles
catrules2000 is offline   Reply With Quote
Old 02-17-2012, 05:00 PM   #5 (permalink)
evilvtwin's Avatar
Current Sled(s): Two 2012 TNT 600 ACE'S
Previous Sled(s): 07 600 Blizzard, 07 MXZ 550X
Favorite Riding Area: Jackman Maine
18-19 Mileage 0000
17-18 Mileage: 1100
16-17 Mileage: 2000
15-16 Mileage: 2300
Riding Since: 1975
Swap relays.
Members for the 2017/2018 season:
Jackman: Border Riders Sportsmans Club
West Forks: Coburn Summit Riders
(Website and Membership Officer for CSR)
Our Home Away From Home:
Spruce Meadow Cabins 207-668-4000
evilvtwin is offline   Reply With Quote
Old 03-01-2012, 05:28 PM   #6 (permalink)
evilvtwin's Avatar
18-19 Mileage 0000
17-18 Mileage: 1100
16-17 Mileage: 2000
15-16 Mileage: 2300
Riding Since: 1975
Once again my SDI stalled once while idling and once on the trail last Sunday. Replaced the relay and rode close to 600 miles. Left on Tuesday without any issues.
Matt how did you make out with your problem?
Old 03-16-2012, 10:59 AM   #7 (permalink)
18-19 Mileage 535
17-18 Mileage: 511
16-17 Mileage: 930
15-16 Mileage: 985
Riding Since: 1980
Mine did it 2 weeks ago again. Just riding down the trail and died. Started back up and rode a couple hundred more miles with no issues......weird
Old 03-29-2012, 05:44 PM   #8 (permalink)
AkS144's Avatar
Sounds like something is loose. I had mine die on me when I rolled it off the side of a hill. It was still running when I got to it but it eventually quit and would not restart at all. After much troubleshooting I found the red wire going from the battery to the capacitor had broken. Check all that wiring down there and make sure everything is good and tight.
