06 skidoo rev 800 problems - HCS Snowmobile Forums
REV Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-29-2019, 09:21 PM   #1 (permalink)
Newbie
Default 06 skidoo rev 800 problems
So I just bought a 2006 skidoo rev 800 ho. I was told it was rebuilt 2 years ago and it sat for a year. It needs a choke and needs a battery I just bought a battery still need to get a choke. I checked compression and both cylinders are at 140 I put fresh gas and new spark plugs in it finally got it running and as soon as it started the engine light was blinking and oil light was on I know it needed oil but I still seen oil in reservoir and just needed to move the sled out of the way but shortly after moving it like 5 feet and idling for maybe 2 mins it shut off on its own and I went to start it and it started right up ran for about 10-15 seconds and shuts right off. I stopped messing with it for the day. Next day comes are I try starting it and it seems like it wants to turn over for a second but doesn’t fully start. Anyone have any ideas??
Monaghan1020 is offline   Reply With Quote
Old 12-29-2019, 11:29 PM   #2 (permalink)
19-20 Mileage:
18-19 Mileage: 2200
Dess post and or chip in tether.
ddm2016 is offline   Reply With Quote
Old 12-29-2019, 11:33 PM   #3 (permalink)
19-20 Mileage:
18-19 Mileage: 2200
Also, check fuel pump/ clean it. Try spraying some carb cleaner (NOT STARTING FLUID) down each spark plug hole to try and prime the diaphragm in the fuel pump. Carb cleaner has a much lower flash point and wont hurt a thing. If that doesnt do the trick, try the fuel tank vent, see if its clogged.
Old 12-30-2019, 08:41 AM   #4 (permalink)
Newbie
Dess post? and for the chip in the Teather would I just need a new teather? I did get it to run and move it before it started acting funny and flashing check engine and shuttinf off and now not starting at all.
Old 12-30-2019, 10:48 AM   #5 (permalink)
Michigan Brian's Avatar
Current Sled(s): 2003 Yamaha RX-1 2003 Ski Doo REV 800
Favorite Riding Area: Manton, Mich
Riding Since: 1938
Try wiggling the tether on the post. Sometimes they just come loose
It is an anti theft device it will not let you rev to over 3000 to engage the clutch. It will beep but I do not think it will shut the motor down.
Could be wrong, my wife has an 03 REV and if the tether is not seated properly thats what it does
Michigan Brian is online now   Reply With Quote
