Secondary help - HCS Snowmobile Forums
Like Tree1Likes
Old 02-29-2020, 07:35 PM   #1 (permalink)
davray's Avatar
Current Sled(s): 05 Sabercat 700
Previous Sled(s): 1st sled: 1972 Firebird 650
Favorite Riding Area: Wellston
19-20 Mileage: 200
18-19 Mileage: 225
17-18 Mileage: 450
Riding Since: 1978
Default Secondary help
Hey guys, I have a 700 sabercat with a bad secondary. Can I use any secondary that fits, or do I have to match the helix and spring? I have a spare off a 99 zl 600. Thanks
Always buy the fastest you can afford. You can always let up on the gas.
davray is offline   Reply With Quote
Old 02-29-2020, 08:32 PM   #2 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
Riding Since: 1959
Match to what you have now.
Old 02-29-2020, 09:01 PM   #3 (permalink)
davray's Avatar
19-20 Mileage: 200
18-19 Mileage: 225
17-18 Mileage: 450
Riding Since: 1978
I know that's what I should do but am curious as to what would change.
Old 02-29-2020, 09:12 PM   #4 (permalink)
Super 8's Avatar
Current Sled(s): 2014 XF 8000 137" Orange Limited
Depending when your 99 ZL was built or if it's an efi, but the later model year efi build had the same helix but you will need the green spring from your sabercat. The sabercat had cut out's for O-rings to seal out moisture, but not necessary if you want to use the zl clutch. An alignment bar after install would be a good idea.
No Substitute For BIG JUGS!!
Super 8 is offline   Reply With Quote
Old 02-29-2020, 09:16 PM   #5 (permalink)
Current Sled(s): 2018 ZR 6000 ES, 2020 ZR 6000 Limited iACT
Favorite Riding Area: Pinehurst area
Those clutches were floating so as long as you have that, an alignment bar really does not help. Now if you are talking ACT drive, then yeah, but totally different clutch set up.
jim_ramstad@yahoo.com is online now   Reply With Quote
Old 02-29-2020, 09:36 PM   #6 (permalink)
davray's Avatar
19-20 Mileage: 200
18-19 Mileage: 225
17-18 Mileage: 450
Riding Since: 1978
The zl is a carb has a yellow spring. Maybe I'll take it for a rip tomorrow and see what is acts like.
Old 02-29-2020, 09:52 PM   #7 (permalink)
Current Sled(s): "Agri-vator"
Pretty easy to just swap your helix and spring over into the other clutch.
XCR1250 likes this.
Old 02-29-2020, 09:58 PM   #8 (permalink)
davray's Avatar
19-20 Mileage: 200
18-19 Mileage: 225
17-18 Mileage: 450
Riding Since: 1978
yes, I just created a tool to compress the spring. I'm just curios as to what the effect it would have to just bolt it on.
Old 03-01-2020, 08:06 AM   #9 (permalink)
Super 8's Avatar
Secondary's didn't float from 2003-2006 on the firecat/sabercat's.
Old 03-01-2020, 08:08 AM   #10 (permalink)
Super 8's Avatar
The yellow spring is much softer than the green, sled will over shift.
