04 Sabercat 500 Chain case Issue - HCS Snowmobile Forums
Old 01-26-2020, 02:49 PM   #1 (permalink)
Newbie
Default 04 Sabercat 500 Chain case Issue
Took the sled for a hard run last week and the chain case started making a lot of noise the faster I went. Reverse is also no longer working. Took the chaincase apart and found metal fillings and a tooth in the oil. Not sure where to start or what needs to be replaced. Attached photos for reference. Does everything including the chain need replacing?
ID:	2072174   Click image for larger version
ID:	2072176   Click image for larger version
ID:	2072178   Click image for larger version
ID:	2072180   Click image for larger version
Jbfen is offline   Reply With Quote
Old 01-26-2020, 03:09 PM   #2 (permalink)
-dw-'s Avatar
Current Sled(s): 13 Indy, 01 600xcsp, 00 600xcsp
Previous Sled(s): 3 arcticcraps
Favorite Riding Area: from my house
Riding Since: 85
The reverse idler is grinding against the tips of the lower sprocket. Self tensioner is doing its job keeping the chain snug and looks to be at the end. My guess is the lower driveshaft bearing it out. Pull the gears and have a looksie.
Originally Posted by krom
you are wrong
-dw- is offline   Reply With Quote
Old 01-26-2020, 03:41 PM   #3 (permalink)
Newbie
Yes, bearing is gone. Do I need to replace any of those gears as well?
Old 01-26-2020, 03:59 PM   #4 (permalink)
-dw-'s Avatar
Riding Since: 85
Limited by pics but it looks like the bottom sprocket isa goner. Part#0702-393. 4 of them on eBay. Check the chain for any broken links and stretch.
you are wrong
Old 02-08-2020, 05:11 PM   #5 (permalink)
Newbie
Anyone know of a replacement part for 0602-447 gear. 39 T, Part number is obsolete
