Snapped Belt - Firecat 1000 - Page 3 - HCS Snowmobile Forums
Old 02-13-2013, 06:42 PM   #21 (permalink)
98 Thundercat's Avatar
Current Sled(s): 2019 Renegade X-RS 850 2003 F7 Patriot
Previous Sled(s): Mutiple Cats
Favorite Riding Area: Old Forge
Riding Since: 1984
Originally Posted by cjt View Post
Only thing is,the rails were straighter on the '03's,maybe with the '04 rails the 10t drivers will hang down a little far for trail riding?
I may have this backwards but a larger diameter driver (10 tooth) should give a lower gear ratio shouldn't it? A smaller driver (9 tooth) should turn the track more times per revolution from the jack shaft shouldn't it?
"Woe to you, Oh Earth and Sea....
D&D Firecat F8 Pump gas Asphalt 9.79 @ 131 MPH
D&D Firecat F9 Stroker Asphalt 9.39 @ 134 MPH
98 Thundercat is offline   Reply With Quote
Old 02-14-2013, 12:16 AM   #22 (permalink)
Current Sled(s): 04 SuperCat 1000 Turbo Slayer
Previous Sled(s): 07 F1000, 08 F8, 7 Different F7s, '92 EXT w/ 580, 91 Wildcat
Favorite Riding Area: Anywhere in NB
19-20 Mileage:
18-19 Mileage: 2000 miles
Riding Since: 1988
Default Snapped Belt - Firecat 1000
A bigger driver is like bigger tires on a truck, faster speed. Check this out: http://www.arcticchat.com/downloads/...gear_chart.xls
fowlerrudi is offline   Reply With Quote
Old 02-14-2013, 01:19 AM   #23 (permalink)
cjt
cjt's Avatar
Previous Sled(s): Firecat 1200
Favorite Riding Area: On The Lake
Riding Since: 1975
no..I don't have the gear calculator in front of me but having 10t over 9 t is a pretty good size gear jump up..like higher gearing...kinda like 24-39 vs. 25-39...
cjt is offline   Reply With Quote
Old 02-17-2013, 09:20 AM   #24 (permalink)
Been running a 04 skid in our f6 eb, no issues, 3 years now, keep the limiters straps pulled up.
graynfast is offline   Reply With Quote
Old 01-23-2015, 12:04 AM   #25 (permalink)
19-20 Mileage:
Riding Since: 1988
Running 10T drivers, 24/39 gears 7400-7500 rpm and still ripping belt in half at 114mph on GPS. I market clutches with sharpie and its shifting the entire way out as far as I can tell. XS815 belt. Thinking I should regear if I want more speed?
Old 01-23-2015, 07:17 AM   #26 (permalink)
camarrow's Avatar
Current Sled(s): 06 F7
Previous Sled(s): Wilcat 700/ ZR500/ (2) 05 F7SP / 06 F7
Gear. Rpm. Mph
25/38 @ 7500. =132.08
25/39 @ 7500. =128.69
24/39 @ 7500 =123.54
23/40 @7500 =115.44
22/40 @ 7500. =110.42
22/41 @ 7500. =107.72
22/42 @ 7500. =105.10
camarrow is offline   Reply With Quote
Old 01-23-2015, 08:05 AM   #27 (permalink)
19-20 Mileage:
Riding Since: 1988
In theory I shouldn't be out of clutch right?
Old 01-23-2015, 09:28 AM   #28 (permalink)
Current Sled(s): "Agri-vator"
Nope, or gear. Secondary binding and stopping the shift? Hitting the bulkhead maybe, backside?
Old 01-23-2015, 10:00 AM   #29 (permalink)
I found the offsetbar didn't work that well messing with this,took off all the orings,and shimmed the driven the old way,and left some float in it.As mentioned,the inside of driven is very close to the hose behind the footwell,make sure the wires are pulled back.
FWIW, If you're running a stock 8"primary,I'm not sure if any of this is going to help you,I only swapped out when I converted to the 8.5".I've heard of guys using the 065 belt on grass to get the lower ratio,with a 8",but not sure if you're going to see any gain at full shift without a larger primary.
Old 01-23-2015, 11:33 PM   #30 (permalink)
19-20 Mileage:
Riding Since: 1988
I'm going to order up an xs814 instead of xs815. Also going to check for twisting with springs out of the clutch. Would love to find 26/37 or 25/35 gears to try too sometime. This thing should show me 120 mph. What kind of belt would I run if I had an 8.5 clutch? Where does one get an 8.5?
