2005 f6 driveshaft bearing # - HCS Snowmobile Forums
Old 02-09-2020, 12:53 PM   #1 (permalink)
52psi's Avatar
Current Sled(s): 2016zr9000 turbo snopro
Previous Sled(s): 2011 z1 ,2007 f8 snow pro crossfire, 2013 f100 turbo snopro
Default 2005 f6 driveshaft bearing #
Hi all, pulled the drive shaft out yesterday and a bunch of ball bearings fell out with it, do not see it listed in pic, anyone know the part number? it is the large bearing by brake rotor, thanks in advance.
slides on shaft by number 3
52psi is offline   Reply With Quote
Old 02-09-2020, 02:03 PM   #2 (permalink)
heshtesh's Avatar
Current Sled(s): 03 440/700 SnoPro or 10 CFR8/Priceless901
Previous Sled(s): 01 MXZX 800 95,97,99 MachZ
Favorite Riding Area: NY Southern Tier
Riding Since: 1965
There are 2 bearings in the brake housing, be careful when you go to remove them as there's a hidden snap ring that has to be removed or you will break the brake caliber.
I am always ready to compromise, you are welcome to see it my way anytime!
heshtesh is offline   Reply With Quote
Old 02-10-2020, 10:31 PM   #3 (permalink)
52psi's Avatar
ok thanks, i didn't know that. will call dealer about bearings.
Old 02-15-2020, 06:15 PM   #4 (permalink)
52psi's Avatar
Bearing number is 2602-131, they are 45mm x 68mm x 12mm if anyone else ever needs them. Is there a spacer after snap ring, before 2nd bearing? Or run it down to snap ring?
Old 02-16-2020, 02:16 PM   #5 (permalink)
Newbie
Current Sled(s): 1998 Tcat & 05 f7 SP
Favorite Riding Area: Upper Michigan
19-20 Mileage:
18-19 Mileage: 2000
Riding Since: 1977
The outside bearing is held in by the snap ring then there is a spacer then the inside bearing.When you tighten the brake rotor on that holds that bearing in place.There is a spacer between the brake rotor and that inside bearing as well.I have two OEM arctic cat bearings if you need them.I went with a stainless hybrid ceramic bearing.Never want to do that job again.Had to knock my driveshaft out with a 25lb. sledge hammer.
Thundrcat is offline   Reply With Quote
Old 02-22-2020, 10:09 AM   #6 (permalink)
52psi's Avatar
thank you for the info, i already bought 2 factory bearings. i thought something was wrong without a spacer. got this sled from a guy already taken apart.
