03 F7/04? - HCS Snowmobile Forums
Old 12-29-2019, 03:24 PM   #1 (permalink)
19-20 Mileage:
18-19 Mileage: 2200
Default 03 F7/04?
Hello, quick question. I have an 03 F7 that I exchanged the bottom half/ crank and crankcase with an 04 F7 crankcase. Iím having some issues fitting the O4 back in the chassis, are these bottom halves different? Am I missing something here? The 04 doesnít want to fit like the O3. Thanks.
ddm2016 is offline   Reply With Quote
Old 12-29-2019, 10:31 PM   #2 (permalink)
Current Sled(s): "Agri-vator"
Man, no difference that I remember. What isn't working?
Old 12-29-2019, 11:24 PM   #3 (permalink)
19-20 Mileage:
18-19 Mileage: 2200
It seems as though the water pump housing is different on the 04, I cant seem to get the motor to move back towards the bulkhead, it seems to far forward to get the throttle bodyís into the reed boot, the 03 block at the water pump housing seems to fit much better, the throttle bodies are tight but doable, the 04 is much tighter giving me fits, have had it in and out 3 different times, something just seems off and I canít figure out why?
Old 12-30-2019, 09:28 AM   #4 (permalink)
Member
I believe the 2004 Carb model crankcase has a different part number than EFI.
MOTO557556 is offline   Reply With Quote
Old 12-30-2019, 12:44 PM   #5 (permalink)
snoprotogo's Avatar
Current Sled(s): 03 440 & 700 sno pros. 15 zr6000 xc
Favorite Riding Area: northern Mn
19-20 Mileage:
18-19 Mileage: 750
17-18 Mileage: 1460
16-17 Mileage: 1000
The 04 has a different throttle body coolant configuration
the outlet brass fittings are angled differently on the block.
recommend getting the coolant hoses and routing as an 04 vs 03
E Bay is where i purchased the 04 / 06 hoses they have a plastic Y fitting
snoprotogo is offline   Reply With Quote
Old 12-30-2019, 12:49 PM   #6 (permalink)
19-20 Mileage:
18-19 Mileage: 2200
Ahh, bingo, thank you!
Old 12-30-2019, 06:29 PM   #7 (permalink)
So a tight hose as holding you up?
Old 12-30-2019, 08:11 PM   #8 (permalink)
snoprotogo's Avatar
19-20 Mileage:
18-19 Mileage: 750
17-18 Mileage: 1460
16-17 Mileage: 1000
You will also need the 04 throttle bodies to make it all fit
https://www.ebay.com/itm/2004-ARCTIC...559db16311cb30
Old 12-30-2019, 11:34 PM   #9 (permalink)
19-20 Mileage:
18-19 Mileage: 2200
Ok, so yes, human error, the water pump housing and everything is the same between the 04 bottom end and the 03 bottom end, (BOTH EFIíS) I honestly looked at them side by side before I did anything. So here is exactly what happened: I put everything together, put the motor back in the chassis. (3-4 times to be exact, and couldnít figure out why I couldnít not get the engine to fit, so, after the 3rd time out I happened to glance at the mag side mounting bracket and the shop I got the bottom half from has the motor mount on the mage side inside out! Lesson learned, thanks to everyone that helped me out on here. Much appreciated, I should have looked closer, my fault. 30+ years working on motors and still learning, lol.
Old 12-30-2019, 11:35 PM   #10 (permalink)
Because i really can't remember.... What alls different again? I don't remember anything that a few pieces of hose couldn't correct, but, I've not had a f7 apart in a long tine either.
