secondary helixes - Page 3 - HCS Snowmobile Forums
Old 01-13-2015, 07:11 AM   #21 (permalink)
went to tightest hole, seems to be still be kind of high gear but definatley better out of the hole. 51*.
what would be the issue that I am setting this up tighter than STM recommends? b/c I have more power adders than their norm?
thanks
06 f7 std efi, rktek head for 91, d&d y bmp pipe, stm secondary, 1.5 track, boss seat
canf7 is offline   Reply With Quote
Old 01-15-2015, 07:32 PM   #22 (permalink)
ready2race's Avatar
Current Sled(s): 06" F 7- R
Previous Sled(s): 00 ' ZR 500 96" ZR 580 ,,Z440
Favorite Riding Area: 660FT
Riding Since: 1970
thanks
I would never go past the middle hole ...thats to tight
[SIGPIC][/SIGPIC]WIN....LOSE..OR .....DRAW
ready2race is offline   Reply With Quote
Old 01-15-2015, 09:59 PM   #23 (permalink)
RtoR, woud you go to the 45*?
Old 01-16-2015, 02:07 PM   #24 (permalink)
wondering if maybe the problem can be solved by taking weight out of the heel of my Cutler adj..? I have 65-75 weight and fully loaded, if I take out of the heel will that change the max rpm which is bang on right now.
I have been thinking about this and maybe it is fine off the line and shifts at 5-10mph to fast and rpm isn't high enough for that.
later
Old 01-22-2015, 09:38 AM   #25 (permalink)
a little more info, better description is like a car auto tranny with a shift kit, 1st then hits when it goes to second gear.
the sled shifts then spins when it shifts or spins up, maybe it is the nature of STM clutch, 51* helix, spring middle hole and adj. weights loaded middle and tip only, 73 grams total. rpm is still under 8000rpm. Haven't been out much but backshift seems fine and not much snow to really go hard pack then powder and back.
How loose can i go with the spring or just leave it in the middle?
later
Old 01-22-2015, 08:46 PM   #26 (permalink)
harmonysnowmobiler's Avatar
Favorite Riding Area: Local trails
You said you run a polaris belt.Is the primary properly shimmed?Try a different belt.
2012 WS 7.0 Class
2014 WS 7.0 Class
harmonysnowmobiler is offline   Reply With Quote
Old 01-24-2015, 02:21 PM   #27 (permalink)
measured the Polaris belt against my Cat belt and it is almost a 1/16 narrower, this might be the problem...?
I will see if there is a different option for belt, needs to be longer b/c of larger diameter secondary. I will put the stock 044 on and see what happens to compare also without any high speed
how is the primary shimmed?
thanks
Old 01-24-2015, 03:03 PM   #28 (permalink)
so did some reading and I do have a Thunder product abc primary bolt and this is supposed to do some sheave adj. with the locking collar, anyone with some experience with these?
later Kevin
Old 01-26-2015, 11:32 PM   #29 (permalink)
went out and everything seems fine now.. the longer polaris belt is narrower than the cat belt and the thunder product ABC bolt fixed my shimming issue
thanks for the help guys
