Indy EVOlution Kit - Page 3 - HCS Snowmobile Forums
Like Tree18Likes
Old 10-12-2018, 02:30 PM   #21 (permalink)
All that wire does is tell the CDI that it is in Low Range. That may remove your speed limiter, but you wonít get any performance change from it. The new CDI has a different curve, and the complete upgrade kit also includes different clutch components and a gearing change as well.
Nick_R_23 is offline   Reply With Quote
Old 10-12-2018, 02:55 PM   #22 (permalink)
Since this machine doesn't have low range, that's the signal wire to apply the limiter at a specified MPH.
I'm not sure what you mean "you wont get any performance change from it" because removing the speed limiter IS EXACTLY the performance change I was looking for.
There certainly could be better programming on a normal 550 CDI that could give it a little more power. I'll reassess that once I get it to fully open the carbs, get the clutching calibrated, and we actually get some snow. This sled is for a 12 year old girl, I'm ok with leaving a little power on the table anyway.
The gearing is lower on the EVO. I'm ok with that and will leave it, and I'll probably just match the clutching to exactly what the regular 550 has.
The only other change its getting before snow is a new 1.35 cobra track and some studs. I haven't purchased the studs yet but the track has already arrived.
dskofich likes this.
indy440-2 is offline   Reply With Quote
Old 10-12-2018, 03:03 PM   #23 (permalink)
The machine doesnít have low range, but the CDI box doesnít know that. Thatís why the speed changes, the CDI thinks youíve put the machine in high range now (but you know better, you just unplugged a wire instead of letting a non existent switch control it). The programming is exactly what the difference is though. The sled may reach a higher speed, but itís not going to get there any quicker than before. On a 550, the CDI controls the timing curve and the programming is how aggressive the timing is applied. That will not only allow the higher speed, but allow the machine to reach the speed quicker, and it will also have more power at given RPMs to turn the taller gears and more aggressive clutching.
For a 12 year old, the speed limiter by itself is probably more than enough. But without the full size 550 CDI, there is still some being left on the table.
Old 10-12-2018, 03:14 PM   #24 (permalink)
My gut feeling says the ignition curves are identical between the two but I have no way to verify that and you definitely cant go just by what Polaris engineering claims.
I love the sled though and I think it was priced pretty well, my daughter is coming off a gen2 340 and absolutely loves her new EVO.
Old 10-12-2018, 03:20 PM   #25 (permalink)
Thry aren’t the same, as that’s why they’re included in the upgrade kit.
It’s a pretty sweet little sled though, we’ve had one on the floor presold but leaving soon. I checked the side panel fitment on my Pro Ride Switchback Assault, and they seem to fit well. I may order up a set of the red non ES panels and get some custom stickers done up to fit it for a totally different look.
Old 10-12-2018, 03:29 PM   #26 (permalink)
I ordered one from my dealer back in march and got the first one that came in this fall. When they first released i saw one with what appeared to be a factory wrap. I'd buy that wrap in an instant if i knew where to find it. I've got the picture on my phone somewhere i'll have to find.
Old 10-15-2018, 02:19 PM   #27 (permalink)
Member
Current Sled(s): 2013 PRO
Favorite Riding Area: Back country
Riding Since: 1978
Not that it is all inclusive but the picture of the upgrade kit in the 2019 parts accessory catalog does not have a cdi in it. Does anyone have access to the actual parts list and part #"s of what is included in this upgrade kit?
bushwacker1 is offline   Reply With Quote
Old 10-16-2018, 01:54 AM   #28 (permalink)
I have it printed out at work, but it includes a full suspension upgrade (brings machine up to full size 550 specs), gearing, clutching, and the CDI. I can post a full list later.
Old 10-16-2018, 07:07 AM   #29 (permalink)
That would be awesome, I'd really like to see the full list also.
Old 10-16-2018, 12:09 PM   #30 (permalink)
Hereís a full list of included components. I edited out the packaging part numbers as those arenít relevant, just the hard parts in the kit.
1542993 1.000 EA ASM-SHOCK FRONT TRACK
1823875 1.000 EA ASM-SPINDLE F/C,LH
1823876 1.000 EA ASM-SPINDLE,F/C,RH
1823883-309 2.000 EA ASM-TIE ROD,WIDE,NAT
1823916-070 2.000 EA ASM-SKI SVC BLK
1824010-067 2.000 EA ASM-SHOCK IFS,WIDE,BLK
1824624-067 1.000 EA ASM-ARM LOWER CONTROL LH BLK
1824625-067 1.000 EA ASM-ARM LOWER CONTROL RH BLK
1824626-067 1.000 EA ASM-ARM UPPER CONTROL LH BLK
1824627-067 1.000 EA ASM-ARM UPPER CONTROL RH BLK
2010431 1.000 EA ASM-LEVER,HTR,HI/LO 35.5MM
2205307 3.000 EA SLUG-43 GR,CVT,135-1083
3090428 1.000 EA EC55 CDI INDY
3221094 1.000 EA SPROCKET-18T,3/4W,15 SPL,HV,PM
3222192 1.000 EA SPRKT-42T,3/4W,LWT,HYVO,PM
5010422 1.000 EA BUSHING-.385X.618X.95
5136910 2.000 EA BUSHING-15.88X10.13X76.20
5137360 4.000 EA BUSHING-M10X17.5X30
5220646 4.000 EA WASHER-DOMED
5333905 2.000 EA SLEEVE-.385X.560X1.24
5333906 1.000 EA SLEEVE-.385X.560X1.72
5414450 1.000 EA STRAP-LIMITER
7043281 1.000 EA SHOCK-R/T,ARVIN MPV
7043859-329 1.000 EA SPRING-TOR,.347S,80,10#,LH BLK
7043860-329 1.000 EA SPRING-TOR,.347S,80,10#,RH BLK
7044154 1.000 EA SPRING-DRV,202#,CVT 1151-1135
7044155 1.000 EA SPRING-DRVN,90#,CVT 5951-1006
7515391 1.000 EA SCR-5/16-18X1-1/2 TX/TAP,Y
7518070 1.000 EA SCR-5/16-18X1,TRX,GR5,Y
7518917 1.000 EA SCR-M10X1.5X95 HX FLG 10.9 ZOD
7519004 2.000 EA SCR-M10X1.25X20 8.8 HH ZOD P30
7519015 2.000 EA SCR-M10X1.5X75 10.9 HCS ZOD
7519145 2.000 EA SCR-HXFL-M6X1.0X12 8.8 ZOD P30
7542344 2.000 EA NUT-5/16-18,NYLOC,THIN-Y
7547263 4.000 EA NUT-3/8-24 FLG LOC
7547332 14.000 EA NUT-M8X1.25,FLG,NYLOC-OLIVE D
7547423 13.000 EA NUT-M10X1.5 HFN NYLOC ZOD
7547464 2.000 EA NUT-HEX-M12X1.5 8 ZOD NYL
7555730 5.000 EA WASHER-.189X.314X.015 - AL
7555806 6.000 EA WSHR-FL .406X.812X.065-Y
7556212 4.000 EA WASHER-7/16 SAE,STF,THRU-HRD-Y
9929062 1.000 EA INSTR-EVO UPGRADE
indy440-2 likes this.
Similar Threads
Got To See The Indy XC snowcrazed Indy (AXYS Platform) 8 03-22-2018 12:11 PM
RUSH or Indy SP Lexuslover Rush/Switchback (Pro-Ride Chassis) 43 03-02-2018 08:32 AM
2014 800 Switcback Adventure or 2013 Indy 600 SP markcp Switchback Assault/RMK (Pro-Ride Chassis) 6 02-26-2018 07:40 PM
Looking to buy a new Indy 600 or Switchback 600... help! Shalliday19 Indy (Pro-Ride Chassis) 27 12-30-2017 02:16 PM
Indy 500 Spindle question LilDavy Trail/Classic/XLT 11 01-10-2017 08:59 AM
