XC 129 600 Oil tank leaks - HCS Snowmobile Forums
Indy (AXYS Platform) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 01-14-2020, 12:51 PM   #1 (permalink)
Newbie
Default XC 129 600 Oil tank leaks
I snow checked an XC 129 600 last year. It's had an oil leak since I've owned it. Dealer thought it might be an issue with the self venting cap. I replaced it and thought that solved the problem but its now leaking again. Dealer suggested I keep the oil level down about 1" from the top when I fill the tank but that hasn't stopped the leak. It does leak less when there is less oil in the tank.
When I say leak.......its not a dripping or flowing leaking from the tank. I ride the sled and let it sit in the garage for a few days and there will be a small stain on the floor. The stain is a mixture of belt dust and 2-stroke oil. The outside of the oil tank will have a light film of oil on it. That oil over time makes its way onto the belt guard, runs down and around the guard to where it fits into the belly pan plastic, then runs down the plastic and onto the floor.
I checked the oil line fitting on the rear of the tank (that goes to the engine). It's not leaking there. Only other leak areas I can think of are, the cap, the low oil sensor or a crack in the tank.
Its under warranty and I should just take it back to the dealer but he is over an hour away (one way), has a 3 week back log and really this just seems like it should be a simple thing. I could probably just fix it myself if I knew what the issue was. It's a brand new sled...shouldn't be doing this.
Any ideas? Maybe this is a common issue? Anything specific I should look for?
The sled has 1800 miles on it so I've been riding it like this for a while.
802sled is offline   Reply With Quote
Old 01-14-2020, 01:33 PM   #2 (permalink)
Super Admin
A05GSHO's Avatar
Current Sled(s): 2020 Indy XC 850 137
Previous Sled(s): Many Poo's & Doo's 1 POS Cat
Favorite Riding Area: Northeast WI, UP
19-20 Mileage: 1198.9
18-19 Mileage: 1470
17-18 Mileage: 684
16-17 Mileage: 694
Riding Since: 1968
Some tanks filler necks have proven to be somewhat out of round, try one of these.
RIP Cappy You Will Be Missed
A05GSHO is online now   Reply With Quote
