2020 850 137 track noise - HCS Snowmobile Forums
Indy (AXYS Platform) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree2Likes
Old 01-13-2020, 11:42 AM   #1 (permalink)
Member
Default 2020 850 137 track noise
Anyone notice this? Track seems kind of loud. Running the ice ripper. Was riding a couple weeks ago and suddenly the track seemed to get louder
in lower snow conditions. With plenty of snow its not as bad. I came off of a 137 switchback that seemed a little quieter. When i got home i put the sled up on the left and ran it and could still hear the noise. Almost like the snow-flap is pushed into the track. Tension is a little loose but not terrible.
My15AXYS is offline   Reply With Quote
Old 01-13-2020, 07:13 PM   #2 (permalink)
Sledtuner360's Avatar
Check in the front of tunnel to see if it is rubbing the tunnel guard. Are you running tunnel protectors?
Sledtuner360 is offline   Reply With Quote
Old 01-13-2020, 07:52 PM   #3 (permalink)
Member
OK thank you ill do that. Yes i have factory installed tunnel protectors. Ill make sure those are not loose either. Are tunnel guards different than Tunnel
protectors?
Old 01-13-2020, 09:05 PM   #4 (permalink)
Drumerjb's Avatar
Current Sled(s): 14 Indy 800/ 05 800 XC
Previous Sled(s): 72 340 Rupp Nitro,73 440 Nitro,75 440 FA,02 Edge 500
Favorite Riding Area: Any where in WI.
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 2300
16-17 Mileage: 2100
Riding Since: 1968
I had of a vibration in mine. Everything was fine before we went in for dinner came back out and rode and had a severe vibration down by my left foot. Pulled over after about 5 miles of riding and looked at it with a flashlight and sure enough there was a two and a half foot three-quarter inch stick wedged in. Removed it and wallah no more vibration. I could have sworn the lower drive shaft bearing was bad.
Just a thought to take a look it's happened to me twice already.
Drumerjb is offline   Reply With Quote
Old 01-14-2020, 09:30 AM   #5 (permalink)
2002silverex's Avatar
Current Sled(s): 2020 Polaris XCR 850
Previous Sled(s): 2016 Pros 800
Favorite Riding Area: Saint Zenon
19-20 Mileage: 3500
18-19 Mileage: 1500
17-18 Mileage: 3000
Riding Since: 1999
Im on a different sled 2020 rush pro-s 850 but I to am heading a ton of noise from my track. ive had a lot of sleds never heard anything like this. Ive checked it over and over on the lift on the trails etc etc etc, i cannot seem to find out where the noise is coming from!
2002silverex is offline   Reply With Quote
Old 01-14-2020, 12:53 PM   #6 (permalink)
SouthernTierSwitchback's Avatar
Current Sled(s): 2020 Indy XC 850 137
Previous Sled(s): 2016 Switch Pro S, 2005 XCSP 600, 2003 classic touring 700,
Favorite Riding Area: WNY / North Country
19-20 Mileage:
18-19 Mileage: 875
17-18 Mileage: 270
16-17 Mileage: 1380
Riding Since: 1978
protectors?
Same. Toe-mato Ta-motto
Two eyes... Two ears... One Mouth... Ever wonder why?
SouthernTierSwitchback is offline   Reply With Quote
Old 01-14-2020, 12:57 PM   #7 (permalink)
19-20 Mileage:
18-19 Mileage: 875
17-18 Mileage: 270
16-17 Mileage: 1380
Riding Since: 1978
On the rush Pro S I found that the track tension mattered a bunch. Make sure your checking with the right weight and that you have good alignment. If it is not ratcheting and you have checked over your track lugs super well for bends , breaks , and blowouts you may need to check bearings up front. I always hated that you cannot grease those from the factory anyway. I assume you checked over all the wheel bearings and alike.
Old 01-14-2020, 02:18 PM   #8 (permalink)
rockin's Avatar
Current Sled(s): '20 Indy XCR 850
Previous Sled(s): 9 Polaris, 4 Cat
Favorite Riding Area: Mercer, WI
Riding Since: '79
I had my '20 XCR on the lift a few days ago to warm up the track before checking the track tension and noticed a noise coming from the chain case area. I took the side panel off on that side and was able to find that that the noise was coming from the inside brake pad knocking against the rotor, I'm not sure what is causing this at this point (maybe a warped Rotor???) as I didn't have time to look into it much further but am going to take it to my dealer soon and let them figure it out under warranty. Good luck with yours!!!
rockin is offline   Reply With Quote
Old 01-14-2020, 05:54 PM   #9 (permalink)
Member
Ill check the brake pad area. The sound seemed to come from the other side more. Ill pull the bearing and check it. Track tension is a little loose. I noticed there is a little black on the Tunnel protectors. Possibly just too loose hopefully. About 2" or so with about 10# on the track.
Old 01-15-2020, 10:46 AM   #10 (permalink)
skidooman383's Avatar
Current Sled(s): 2019 Polaris XC 850
Previous Sled(s): You name it, I had it
Favorite Riding Area: Bayfield County, WI
17-18 Mileage: 2,100
I get a vibration and noise some times on mine but I've always found it to be ice build up and nothing to worry about. The faster you drive the less you notice it so just drive faster.
bedlam bikes and Sledtuner360 like this.
[SIGPIC][/SIGPIC]
skidooman383 is offline   Reply With Quote
