Garmin gps on a axys - Page 9 - HCS Snowmobile Forums
Indy (AXYS Platform) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree37Likes
Old 12-01-2019, 11:01 AM   #81 (permalink)
Current Sled(s): 2016 Pro S 800
Previous Sled(s): '04 MXZ 600SDI, '09 GSX 600, 15 600X
Favorite Riding Area: Iowa when we have snow!
19-20 Mileage:
18-19 Mileage: 1500
16-17 Mileage: 1400
Riding Since: 1980
Originally Posted by flasch7192 View Post
What wires on the sled are you tapped into ?
The ones right under the hood. Flat 2 prong trailer type.
sledlover is offline   Reply With Quote
Old 12-05-2019, 08:44 PM   #82 (permalink)
Current Sled(s): 19 XC850, 15 SB ProS 600, 16 Indy 550
Favorite Riding Area: U.P.
19-20 Mileage: 500
18-19 Mileage: 2750
17-18 Mileage: 2150
Do not do this.
Got it hooked up so it gets power when the key is on. Spliced into the harness on ignition. Red w green gets power when the key is on. Red yellow always has power.
I was hesitant to do it this way but needed to in order to be able to remove the hood and not have to screw w gps power cord. Used heat shrink connectors and made damn sure that they are solid connections. Hook ground to the black and blue wire on the end. The all black is hooked to the kill switch.
Do not do it this way. Only getting 11.2V off of these wires making the GPS act up.
Update 12/11/19:
I now go straight to battery with an SAE plug positioned by the harness that gets unplugged when the hood is removed. Already have 12v outlet in dash so I didn't use the plug others are using. I also wanted to power the unit without the sled running. I turned GPS off but left it plugged in. If it drains the battery, I can pull start it and will then know to unplug the GPS when not using.
ID:	2065456   Click image for larger version
scuba1221 is offline   Reply With Quote
Old 12-05-2019, 09:11 PM   #83 (permalink)
flasch7192's Avatar
Current Sled(s): 20 Indy 850 xcr
Previous Sled(s): lots of pol. and few cats
19-20 Mileage:
18-19 Mileage: 3600
17-18 Mileage: 1500
16-17 Mileage: 322
Riding Since: 1995
Just a f.y.i for people with the std gauge there is no power up by the hood with the key on sled not running .
flasch7192 is offline   Reply With Quote
Old 12-06-2019, 09:11 AM   #84 (permalink)
mewaschuk's Avatar
Current Sled(s): 2020 XCR
Previous Sled(s): ZR6000RS, Rush ProS, SR Viper, Yamaha XTX RR
19-20 Mileage:
18-19 Mileage: 3400
Montana 600 with AMP cradle (hard wired to RCA plug) and GPS Trail Masters map ⭐⭐⭐⭐⭐
2020 XCR 850
mewaschuk is offline   Reply With Quote
Old 12-06-2019, 10:31 AM   #85 (permalink)
19-20 Mileage:
18-19 Mileage: 1500
16-17 Mileage: 1400
Riding Since: 1980
Originally Posted by stompintom View Post
Attachment 2062968
Works great on Dash bag. I did add a small plastic
backer plate on the inside of the bag.
The other thing is the mini usb power cord has to have the proper socket orientation for a nuvi. I went through a few that did not always work. Dont know why as the were supposed to work with the nuvi.
This cord finally did the trick and I never lost power with it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I think this is what I need. Trying to charge the Nuvi with the mini USB cord that came with it. Probably the data cord? Doesn't want to work for me correctly.
Old 12-06-2019, 08:33 PM   #86 (permalink)
stompintom's Avatar
Current Sled(s): 2019 Indy XC 850,2018 SBA 800
Previous Sled(s): 2015 Prox 800, 2009 D8, 2006 Fusion 600, 2002 RMK 600
Favorite Riding Area: Maine
19-20 Mileage:
18-19 Mileage: 150
17-18 Mileage: 1000
16-17 Mileage: 1100
Riding Since: 2000
Correct. Need to buy USB charging cable for Nuvi
stompintom is online now   Reply With Quote
Old 12-06-2019, 11:30 PM   #87 (permalink)
19-20 Mileage:
18-19 Mileage: 1500
16-17 Mileage: 1400
Riding Since: 1980
Thanks, I feel dumb about that. Frustrating thats all it was. Am I the only one that had no clue about this?
Old 12-09-2019, 10:38 AM   #88 (permalink)
flasch7192's Avatar
19-20 Mileage:
18-19 Mileage: 3600
17-18 Mileage: 1500
16-17 Mileage: 322
Riding Since: 1995
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
This doesn't put out enough power to run the Drive 61. It was working sitting still but when I ran on the trail, it started acting up right away. Switched to the cig plug power cord and it worked fine.
Started reading reviews and found one that says it puts out less than 2 amps which is required for the 6" units.
Works fine for me
Old 12-09-2019, 03:42 PM   #89 (permalink)
Current Sled(s): 20 SKS 146 850, 16 SB pro-S 600
Favorite Riding Area: UP
19-20 Mileage: 400
18-19 Mileage: 1,200
17-18 Mileage: 1,400
16-17 Mileage: 1,400
Originally Posted by snowtime View Post
I have been using this to power my gps. You just plug it in under the hood and then plug your gpsr's USB power cable into it #easypeezy
Battery Tender® USB Charger Adaptor
Thanks Snowtime, I was in the process of figuring out how to connect gps when I saw your post. I bought the same adaptor.
mcmrk is offline   Reply With Quote
Old 12-09-2019, 11:00 PM   #90 (permalink)
rabbi's Avatar
Current Sled(s): 2016 600 Switcback Adventure
Previous Sled(s): Lots of Polaris'
Favorite Riding Area: Wi northwoods
19-20 Mileage:
18-19 Mileage: waiting
Riding Since: 1979
Originally Posted by zr sled head View Post
Easy to see, easy to use n removes in a flash when I go in for lunch.
Only glitch, can be a tic hard to see in bright sunlight when riding, in the bush no problems, same at night.
zr sled head, I have a question. I have the same windshield bag as you on my '16 Switchback. The front of the bag where the GPS will mount is pretty much straight up and down whereas the gauge is slanted back towards the driver. Is that an issue seeing the GPS screen at that angle? I'm mounting a Garmin Nuvi 67LM with a 6'' screen using VV mapping.
I like the idea of using the windshield bag as a shock absorbing mount.
Riding an AXYS, pure adrenalin!
rabbi is offline   Reply With Quote
