Pipe Removal - Page 2 - HCS Snowmobile Forums
Indy (AXYS Platform) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree8Likes
Old 10-07-2019, 11:29 PM   #11 (permalink)
Doug S's Avatar
Current Sled(s): 2020 850 XC, RXL'S, Indy's
Previous Sled(s): 2019 850 XC 2017 & 2018 Assualt 2016 SB 2015 Axys SB
19-20 Mileage: 2982
18-19 Mileage: 3824
17-18 Mileage: 3802
16-17 Mileage: 2356
This is the spring puller and the route I use for the bottom spring.
ID:	2059340   Click image for larger version
Name:	20161113_143127 - Copy.jpg
Doug S is offline   Reply With Quote
Old 10-07-2019, 11:38 PM   #12 (permalink)
flasch7192's Avatar
Current Sled(s): 20 Indy 850 xcr
Previous Sled(s): lots of pol. and few cats
Favorite Riding Area: U.P
19-20 Mileage:
18-19 Mileage: 3600
17-18 Mileage: 1500
16-17 Mileage: 322
Riding Since: 1995
I use the same tool as doug but go in the other side with the can removed .
flasch7192 is offline   Reply With Quote
Old 10-07-2019, 11:38 PM   #13 (permalink)
Current Sled(s): 19 SBA 850
I used old style t-handle hook and lined it up/ installed spring from can side since it was already out.
Arvo17 is offline   Reply With Quote
Old 10-07-2019, 11:48 PM   #14 (permalink)
Current Sled(s): '11 IQ Turbo, '15 Axys 800, '19 850 XC
Previous Sled(s): '12 Pro-R 8, '08 IQ 8, '02 Pro-X
Favorite Riding Area: Where the snow is....
19-20 Mileage:
18-19 Mileage: 5060
17-18 Mileage: 5100
16-17 Mileage: 2050
Riding Since: 1976
Pulling the pipe is a PITA, but it does come out. I pulled the can first - I can say the can is the WORST to remove.
orville-x is offline   Reply With Quote
Old 10-08-2019, 12:01 AM   #15 (permalink)
NDN
NDN's Avatar
Current Sled(s): 2019 XC 850 Indy & CAT 2016 800 HC
Favorite Riding Area: U.P. MICH
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 1200
16-17 Mileage: 1800
I already had the can out. I'll get back at the whole thing again next weekend. It's a bitch being that the loops (where springs attach) on the end of pipe stick up (out) & can't get through, out. Maybe my loops are just welded on in a different angle making it wider....??
NDN is offline   Reply With Quote
Old 10-09-2019, 01:09 AM   #16 (permalink)
Having same trouble with pipe on 850 assault. Exact same problem. Miserable bitch. Had no trouble on my 800s... there has to be a trick? Will be watchin this thread closely for any more ideas...
sixpack is offline   Reply With Quote
Old 10-09-2019, 08:35 AM   #17 (permalink)
HCS Advertiser
northstarrick's Avatar
I have a 850 for service in the shop today. I will report back on the finding as we pull every ex. valve here. to inspect and clean. so the muffler and pipe has to come out. I've had my pipe out of my xc 129 850 and don't remember having any problem at all? but i do this everyday now until spring. so it just gets routine for me.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 10-09-2019, 08:47 AM   #18 (permalink)
patrioticinnovations's Avatar
Previous Sled(s): 2003 XCR 1100, 2000 XCR 800 turbo, 2005 Redline Revolt 800.
19-20 Mileage: 715 so far
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
My 2019 850 Shop Manual has a detailed explanation of how to remove the entire exhaust system. Page 3.126.
There is no mention of any problem.
DTR has removed it many times. dunno:
Old 10-09-2019, 10:47 AM   #19 (permalink)
NDN
NDN's Avatar
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 1200
16-17 Mileage: 1800
Like I said, I believe that mine (& others) have the springs loops (that are welded on pipe) in a different (incorrect) position, making it wider & HARD to get through the opening to totally remove.
I do need to get a long spring puller but have always used the boot string method. Easy to carry with you.
Old 10-09-2019, 06:13 PM   #20 (permalink)
I have no trouble getting springs off.....silencer is removed....have removed the pipe from my other 800's without issue....some wiggling...yes....but was always able to get it out.
My 850 with silener removed...as spoken above..the spring loops on pipe hit the cross member no matter which direction you lean the pipe over. I carved the shit out of my heat foam in the nose piece in an attempt to angle the thing out but no luck. Seems like airbox and steering post in the way.
If the top spring retaining loops werent' there...the pipe would wiggle out.
Like I said....no issue with my 2015, 16, 17, or 18 800 ho's getting the pipes assembly out.
The 850 is not coming out with out some grindage.
