timing key for the 850? - HCS Snowmobile Forums
Indy (AXYS Platform) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree8Likes
  • 2 Post By patrioticinnovations
  • 1 Post By flasch7192
  • 2 Post By sks8OO
  • 3 Post By patrioticinnovations
Old 08-28-2019, 08:30 AM   #1 (permalink)
Current Sled(s): 19 XC850, 15 SB ProS 600, 16 Indy 550
Favorite Riding Area: U.P.
19-20 Mileage: 500
18-19 Mileage: 2750
17-18 Mileage: 2150
Default timing key for the 850?
Is anyone considering adding timing to their 850 for this winter or is that a sure fire way to throw a warranty out the window and ask for trouble?
scuba1221 is offline   Reply With Quote
Old 08-28-2019, 09:48 AM   #2 (permalink)
patrioticinnovations's Avatar
Previous Sled(s): 2003 XCR 1100, 2000 XCR 800 turbo, 2005 Redline Revolt 800.
19-20 Mileage: 505 so far
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
I experienced DET on a long run on the lake last season even with stock timing. Fuel used was 93 ethanol and mode was non-ethanol 91. Temp was around 20-30 deg F at 900 ft elevation.
This might be okay if you leave the fuel mode in ethanol regular. Then switch to non-ethanol 91 mode with known good 91-93 non-ethanol fuel for short races. I switched fuel modes during this testing. Lost 1-4 mph top speed in reg mode.
https://www.hardcoresledder.com/foru...850-xc-21.html
Not worth the risk for trail riding IMO. I'd work on clutching myself.
scuba1221 and testpiolit like this.
Old 08-28-2019, 04:12 PM   #3 (permalink)
flasch7192's Avatar
Current Sled(s): 20 Indy 850 xcr
Previous Sled(s): lots of pol. and few cats
19-20 Mileage:
18-19 Mileage: 3600
17-18 Mileage: 1500
16-17 Mileage: 322
Riding Since: 1995
I had no issues no d.e.t , ran 91 and 93 both non ethanol.
scuba1221 likes this.
flasch7192 is offline   Reply With Quote
Old 08-28-2019, 06:31 PM   #4 (permalink)
sks8OO's Avatar
Current Sled(s): 2012 polaris assault
Previous Sled(s): polaris dragon 800
Favorite Riding Area: Highlands
Riding Since: 2010
go with a 2 degree key.
itll wake the sled up
sks8OO is offline   Reply With Quote
Old 08-28-2019, 07:28 PM   #5 (permalink)
Member
Axys180's Avatar
Bikeman just released this today... 😃
Axys180 is offline   Reply With Quote
Old 08-29-2019, 11:53 AM   #6 (permalink)
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
Take a look at the most recent dyno test of a Cat 800 C-Tec. With and without 2 deg key. Problem is that it causes longer to warm pipe up. Plus, it also changes timing by 2 deg over the entire rpm range where it can make an already lean calibration at low rpm even leaner. This also changes fuel injection timing, for better or worse.
They found a better setup by only advancing timing at top rpm using a PCV.
The BMP setup appears to be a better solution.
Meanwhile, Jim at DTR told me yesterday that they are planning a test session today on fixing some of the issues seen on certain Polaris 850s.
trdehmer, scuba1221 and testpiolit like this.
