Fuel pump relays froze. - Page 2 - HCS Snowmobile Forums
Sidewinder This is the section for Tech talk and discussion for the New Siddwinder. This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
Old 02-04-2019, 02:39 PM   #11 (permalink)
TommCat Performance
Tommcat's Avatar
Current Sled(s): too many
Favorite Riding Area: Maine
Riding Since: 1977
Originally Posted by jtkz13 View Post
How many of the 4 pin relays are there? I dont have my sled nearby to check. I'd like to replace all of them so it isnt a worry for any of them.
4 of that relay, 2 of a different one
Old 02-04-2019, 02:49 PM   #12 (permalink)
snowfun348's Avatar
Current Sled(s): 2017 ZR7000
Favorite Riding Area: Matagami Qc
18-19 Mileage 1103 Km
17-18 Mileage: 4083 Km
16-17 Mileage: 4866 Km
15-16 Mileage: 4179 Km
Riding Since: 1968
When I first bought my Viper, I would warm up the sled before breakfast. When I returned ready to ride, it would not start. The way that we got around this issue is to start the sled, put on your helmet and then leave for the days ride. The ZR7000 that I have now is the same 'beast' and I do the same startup sequence. I do fill the sled with fuel at the end of the day too to keep out moisture. When it gets cold(below -10C at night), I use either isopropyl gas line antifreeze or Sea Foam.
snowfun348 is offline   Reply With Quote
Old 02-04-2019, 03:44 PM   #13 (permalink)
Current Sled(s): 2017 9000 RR
Previous Sled(s): ZR 600 & ZR 800
Would you suggest replacing the other 2 with sealed units as well? Do you know the part number for them as well?
jtkz13 is offline   Reply With Quote
Old 02-04-2019, 04:13 PM   #14 (permalink)
TommCat Performance
Tommcat's Avatar
Riding Since: 1977
the 2 different ones are shift forward and shift reverse. probably not a huge deal if one ever did stick, but i will see if i can find a sealed version of those as well.
edit, i found sealed versions of the others as well and have a stock order coming next week.
Old 02-05-2019, 07:34 AM   #15 (permalink)
MR WEEZ's Avatar
Current Sled(s): 18' Sidewinder LTX LE
Previous Sled(s): 15 Yami's 3 Doo's
Favorite Riding Area: Northern ON & Da UP Eh
18-19 Mileage 4095 km's
17-18 Mileage: 4430 km's
16-17 Mileage: 3786 km's
15-16 Mileage: 2990 km's
Riding Since: Lad
Always a good time when -15F.
MR WEEZ is offline   Reply With Quote
Old 02-05-2019, 09:40 AM   #16 (permalink)
Fun11cat's Avatar
Current Sled(s): 2020 ZR 8000 LTD IACT - 14 XF7000 Ltd
Previous Sled(s): 10 F8 SP,05 F6,02 ZL 600SS, 99 ZL 600, 96 Pantera
Favorite Riding Area: Central MN
18-19 Mileage 1170
17-18 Mileage: 1260
16-17 Mileage: 960
15-16 Mileage: 849
Riding Since: 1972
I'm sure your getting good at taking the hood off.
Is your symptom nothing when you turn the key on, that's what my 7000 was doing a couple weeks ago at -25F.
Fun11cat is online now   Reply With Quote
Old 02-05-2019, 09:45 AM   #17 (permalink)
MR WEEZ's Avatar
Riding Since: Lad
In my experience when I start the sled and let it warm up then shut it off until I'm ready it freezes. So now I don't start it until I know I'm leaving.
Old 02-05-2019, 09:51 AM   #18 (permalink)
Fun11cat's Avatar
18-19 Mileage 1170
17-18 Mileage: 1260
16-17 Mileage: 960
15-16 Mileage: 849
Riding Since: 1972
Mine is the opposite once its started it starts great until the next morning.
Old 02-19-2019, 08:43 AM   #19 (permalink)
Current Sled(s): Yamaha Viper xtx & Viper LTX
Previous Sled(s): Yamaha Nytro XTX, Phazer, Apex Attak, Polaris XLT
Favorite Riding Area: Keweenaw, MI
18-19 Mileage 1400
17-18 Mileage: 760
16-17 Mileage: 950
15-16 Mileage: 1400
A few weeks back, we had 3 sidewinders, and 2 vipers. 4 out of the 5 had issues.
3 out of 4 started, but then would not restart once we shut them off. Like others have said, we warmed them up, then went inside to put on the rest of our gear. Would have been ready to go, but we had one of the other machines not start at all.
The one that did not start at all, we had to take the relay inside and warm it up. Once that one fired, the chain reaction started to happen with the other relays on the other machines. Took us an hour to get going in the morning. Neg 11 F that morning.
SJB* is offline   Reply With Quote
Old 02-19-2019, 10:54 AM   #20 (permalink)
grizztracks's Avatar
Current Sled(s): 2015 Viper RTX SE, FX Nytro RTX, RS Vector
The shift relays are a single pole double throw unlike the other five in the fuse box that are single throw. The two shift relays are larger rectangular shape with 5 terminals so they can't be interchanged with the other square 4 terminal relays. The OEM relays come as "Flux Sealed" and can be replaced with relays that rated as "Washable".
Square relays, 4 terminal:
ISC (main relay)
Fuel
Fan
Headlight
Tail (lighting relay)
Original Part# (flux sealed): 303-1AH-C-R1-12vdc
Replacement Part# (washable sealed): 303-1AH-S-R1-12vdc
https://www.mouser.com/ProductDetai...lGo6lFOYUsTYwbpP89ku/7wyBpVWigJQObwg6RppX8prP
Rectangle relays, 5 terminals:
Forward shift
Reverse shift
Original Part# (flux sealed): 301-1C-C-R1- U01-12VDC
Replacement Part# (washable sealed): 301-1C-S-R1-12VDC
https://www.mouser.com/ProductDetai...3cc0Vh3MFi1ipUOIJJiF8hmNpWu1nmLOPAy swUIIcQg==
grizztracks is offline   Reply With Quote
Similar Threads
Full Throttle Speed Anti Surge 190LPH Fuel Pump Kit w/ Hydramat | 2012-16 ProCross 1100 Turbo Chassi GreenInMyVeins Turbo 4 Stroke 10 01-21-2019 05:40 PM
2013 Snopro 500 fuel pump Rtx99 Sno Pro Race Chassis 2012+ 1 12-12-2016 12:30 PM
Turbo dynamics 91/94 max pump fuel tune for 1100 turbo catdaddy1000 Turbo 4 Stroke 1 12-11-2016 10:16 AM
Difference between Turbo and N/A Procross Fuel Pump Twinrats496 Turbo 4 Stroke 9 04-01-2016 11:08 AM
