Lima Project - Page 4 - HCS Snowmobile Forums
Switchback Assault/SKS/RMK (AXYS Platform) This is a brand-specific forumand a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree188Likes
Old 12-21-2018, 08:58 PM   #31 (permalink)
calltrex's Avatar
Current Sled(s): 2019 850 Assault 144
installed rubber grease nipple covers on all the grease nipples
removed spark plugs and opened the gap to .027 and also the spare plugs for belt holder
plugs are always less then .027 new
ID:	2034016   Click image for larger version
MisterWister likes this.
2019 Lima Build
2019 Trailer Build.
2017 Switchback Assault 800 Build Here.
calltrex is offline   Reply With Quote
Old 12-21-2018, 09:05 PM   #32 (permalink)
calltrex's Avatar
Set rear spring to middle stiffness to try on these new ones. not sure if they changed anything in the last 2 yrs
my 2017 sled i always used highest setting and it worked good.
ID:	2034020   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 09:20 PM   #33 (permalink)
calltrex's Avatar
started bumper and skid plate. you have to do them at same time.
ID:	2034024   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 09:28 PM   #34 (permalink)
calltrex's Avatar
get one of these longer bolts at dealer to make it much easier to install this 1 bolt through bumper and skid. They have lots laying around from other jobs
Drill both support holes a bit bigger. different sleds can be tight and hard to install. this will make it easy to install no matter what
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 09:30 PM   #35 (permalink)
calltrex's Avatar
Remove stock bumper. easy
pull sled on side onto a step or something
ID:	2034038   Click image for larger version
ID:	2034040   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 09:44 PM   #36 (permalink)
calltrex's Avatar
get the new support inside installed. leave bolts loose till you get all bolts in place
drill the skid plate hole to 5/16 ( the second hole down from front of the plate)
thats the hole for the longer bolt
bigger hole to get to the bumper support inside compartment
dont forget to drill the stock belly pan hole.
so long bolt goes through the bumper, skidplate, belly pan. Thats why its much easier with the longer bolt
hold the skid up and slip the bumper in place at same time. get the front bolt through bumper,skid,belly pan,support inside
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 09:59 PM   #37 (permalink)
calltrex's Avatar
tighten the bumper bolts, support bolts, 2 skid bolts
the 2 tight skid bolts will hold the skidplate up nice
the 5 self tappers are the last thing to do
push plate up and should be straight at the end
hold and screw the first 2 screws tight. I always finish the screws by hand so you dont strip the holes.
the last 3 screws install them at a little slight angle forward. tip of screw angled towards the front of sled. Theres a bolt boss inside you will hit if you just do them straight up.
Name:	20181219_190608 copy 2.jpg
ID:	2034052   Click image for larger version
t hillrider and MisterWister like this.
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 10:03 PM   #38 (permalink)
calltrex's Avatar
front view
ID:	2034058   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 10:09 PM   #39 (permalink)
calltrex's Avatar
same battery as usual that comes with these. Will use it for now
they come with fluid separately
2019 Lima Build
2019 Trailer Build.
Old 12-21-2018, 10:10 PM   #40 (permalink)
MisterWister's Avatar
Current Sled(s): 2019 Polaris SBA 800
Previous Sled(s): 2004 Polaris XCSP 700, 2004 Arctic Cat ZR 900, 1998 Arctic C
Favorite Riding Area: On the snow preferably
17-18 Mileage: 250
Riding Since: 2000
Default Lima Project
Is this aluminum or plastic? Great build I like it
MisterWister is offline   Reply With Quote
Similar Threads
WTB - 1979 Blizzard 7500 Project Sled curta3531 Ski Doo Wanted 0 10-10-2018 05:27 PM
Project Assult crdude2 Switchback Assault/RMK (Pro-Ride Chassis) 14 03-12-2018 09:16 AM
Rangeley Airport Extension Project SummitX864 Maine 4 09-09-2017 09:24 PM
Summer project KFS ProCross (2012 - ) 43 08-27-2016 09:22 PM
My Sons Senior Project! Rock On New Hampshire 34 05-10-2016 12:19 PM
