Walker Evans Velocity RTS - Page 9 - HCS Snowmobile Forums
Switchback Assault/SKS/RMK (AXYS Platform) This is a brand-specific forumand a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree68Likes
Old 03-16-2019, 09:08 AM   #81 (permalink)
ditchbanger64's Avatar
Current Sled(s): 2017 Polaris SBA 800
Previous Sled(s): 06 Doo Renegade 800,17 others over the years
Favorite Riding Area: U.P.,
17-18 Mileage: 1100 mi
Riding Since: 1970
Originally Posted by lennstang View Post
Originally Posted by ditchbanger64 View Post
How much are the NTN Blue bearings? Seems like it would be expensive to do all the idlers etc... Did you do the drive bearings too?
I believe the NTN bearings were $12 each. I did not change the drive bearings. I just pop the seals off and hand pack new grease into them. Do this at the beginning of every season and they will last the life of the sled.
Thanksfor the info. If you don't mind if you have the part #s for the bearings or a link that would be appreciated. I'd like to replace all mine this off season.
ditchbanger64 is offline   Reply With Quote
Old 03-17-2019, 09:56 AM   #82 (permalink)
lennstang's Avatar
Current Sled(s): 2018 Axys 800 Assault
Previous Sled(s): 2017 Assault, 2016 Axys Pro S LE Night Lightning, + 20 more!
Favorite Riding Area: Pittsburg, NH and Maine
18-19 Mileage 3750
17-18 Mileage: 3300
16-17 Mileage: 3231
15-16 Mileage: 2450
Riding Since: 1969
Originally Posted by Major664 View Post
Does this recommendation apply to a 600 as well? (suspension components are the same as the 800?)
Hell yes!
Lenn Johnson
Pittsburg, New Hampshire
2019 Indy XC 850S
2018 800 Assault 144
lennstang is offline   Reply With Quote
Old 04-10-2019, 09:50 PM   #83 (permalink)
Newbie
So with the velocity RTS now coming standard in the xcr 128 do you think this is a similar setup? I’m sure it’s valued stiffer, but is there a difference with the progressive damping?
Zr-1 is offline   Reply With Quote
Old 04-14-2019, 09:34 AM   #84 (permalink)
RRXCR's Avatar
Current Sled(s): 98 XCR 440 x 2
Previous Sled(s): Deere, Poo, Doo
Favorite Riding Area: Where snow is measured in ft.
Riding Since: 1969
Originally Posted by just-pinch-it View Post
Amen! And don’t forget the XCR brake to slow this bad boy down.
When you say XCR brake, what are you referring to?
Master cylinder? Caliper? Disc/rotor? Pads? Brake lines?
Keep your eye on the ball!
RRXCR is offline   Reply With Quote
Old 04-14-2019, 10:02 AM   #85 (permalink)
Lueck89's Avatar
Current Sled(s): 14 Indy 800 136"
Previous Sled(s): 03 pro x, 09 iqr
Favorite Riding Area: u.p.
18-19 Mileage 1150
15-16 Mileage: 30
Riding Since: 2000
Probably rotor. A drilled/slotted one...
Sent from my Moto Z (2) using Tapatalk
Lueck89 is offline   Reply With Quote
Old 04-14-2019, 11:45 AM   #86 (permalink)
just-pinch-it's Avatar
Current Sled(s): Waiting...
Previous Sled(s): Pro-R SB 800, 700 dragon, Pro-XR, XCR, Storm, XLT, Trail
Favorite Riding Area: MI
Riding Since: 86
It’s a disk and pads. I believe its the material and how they work together that makes a difference.
just-pinch-it is offline   Reply With Quote
Old 04-14-2019, 12:37 PM   #87 (permalink)
Riding Since: 86
I believe NSP has a velocity shock set up for the rts. I would go that route vs using the one from the XC. I would think Rick’s set up would be better since he has set it up specifically for the assaut.
lennstang likes this.
Old 04-15-2019, 06:29 PM   #88 (permalink)
Wantry's Avatar
Current Sled(s): 2019 SWB Assault 800; 2016 SWB Pro-S 800
Previous Sled(s): Started on 1972 Yamaha 338
Favorite Riding Area: Away from the crowds
18-19 Mileage 2313
17-18 Mileage: 3870
16-17 Mileage: 936
15-16 Mileage: 803
Riding Since: 1987
Per the Race Dept., the upgrade is pretty simple and consists of pads, rotor, and cooling scoop from the XCR. If you look up the race dept. tech sheets for the Indy XC (or the older ones for Pro-S), or just the XCR parts fiche, you can find the part numbers. List price is about $350. I think the rotor was the expensive piece, and also on backorder right now.
Wantry is offline   Reply With Quote
Old 04-16-2019, 09:13 AM   #89 (permalink)
lennstang's Avatar
18-19 Mileage 3750
17-18 Mileage: 3300
16-17 Mileage: 3231
15-16 Mileage: 2450
Riding Since: 1969
I installed the XCR brake rotor and pads on my 2019 Indy XC. My stock brake pads were worn out at 3000 miles. Decided to go this route instead of just replacing the pads. The rotor is not a wave rotor like stock. It's just round and cross drilled. Works MUCH BETTER!
rchespo likes this.
Lenn Johnson
2019 Indy XC 850S
Old 04-17-2019, 07:02 AM   #90 (permalink)
northstarrick's Avatar
we replace any warped rotor with one from the xcr along with the brake pads. it's also cheaper than the wave rotor.
formula NTN bearings are $8.95 ea. at our shop. i have hundreds in stock. these last the best out of all we have tested. but these will still fail after a while 3+ years. but are way better than the bearings Polaris use's. the formula bearings are the only ones designed for snowmobile use. bearings are full of a white low temp synthetic grease. Polaris needs to use idler wheel caps to keep snow/water away from the bearings. go for a ride in snow and look at your idler wheel's. the recess in the wheels where the bearing is gets packed with snow.
lennstang and razor16 like this.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
northstarrick is online now   Reply With Quote
Similar Threads
Walker Evans Velocity Front Shocks ?? lennstang Indy (AXYS Platform) 98 12-10-2018 08:48 PM
Bunke Racing Walker Evans Rear Shocks whitejeepxj Polaris 0 08-18-2017 09:30 AM
Walker Evans WalkerE71 Rush/Switchback (AXYS Platform) 0 01-18-2017 10:24 PM
Walker Evans front shocks Ibudd General Snowmobile Forum 0 11-21-2016 07:52 AM
Adding adj. rebound to Walker Evans blackwidow875 Rush/Switchback (AXYS Platform) 5 11-16-2016 04:27 PM
