Better Arctic Cat Jackshafts Available - HCS Snowmobile Forums
Old 07-17-2015, 06:33 PM   #1 (permalink)
HCS Advertiser
speedshopinc's Avatar
Default Better Arctic Cat Jackshafts Available
We now have two arctic cat procross/proclimb Jackshafts.
The newest version is for the 2016 Cat 8000 and 6000 models. It is 1.5 lbs lighter than stock. It can be used as a direct replacement for the stock shaft, but it also has a longer splined area. This is so that if you have a belt drive there is more area for a wider spline on the pulley. And the end is threaded to accept a 10mm bolt to hold the pulley on. This holds the pulley tight to the bearing so that it doesn't wobble like it can with the stock snap ring. This one is $229.
The next jackshaft is for 2012-2015 8000 and 6000 model arctic cats. It is the same weight as stock, but it also has the longer spline and is threaded in the end to accept a bolt to hold the pulley on tighter with a belt drive.
This version is $129
LIGHTWEIGHT JACKSHAFT 2016 ARCTIC CAT - Speed Shop, Inc.
ID:	1433530   Click image for larger version
speedshopinc is offline   Reply With Quote
