Homemade Trailer Guides - HCS Snowmobile Forums
Snowmobile Trailers & Haulers Section for discussions about trailers & other ways of hauling snowmobiles.
Old 02-11-2013, 11:53 AM   #1 (permalink)
Current Sled(s): 2003 polaris 700 classic touring
Default Homemade Trailer Guides
Has anyone ever used PVC trim boards for homemade ski guides. I was thinking about doing just that. I'd run groves in the board with a router for ski carbides. If I used 3/4" thick by 4" wide boards I could outfit a 20' trailer, front to back for approx. $125.
If I used a 4'x8' sheet of 1/2" PVC and ripped it into 4" wide strips I could get it done for $100.
Would 4" be wide enough? Would it be slick enough?
Jackpine Savage is offline   Reply With Quote
Old 02-11-2013, 04:04 PM   #2 (permalink)
lawnmoweragrass's Avatar
Current Sled(s): 2011 sno pro 600
Previous Sled(s): '13 XF1100turbo, 2011 F8 EXT 2002 MtnCat 570
Riding Since: 1992
for ski guides, you really want the ridges...
Originally Posted by matt6195
No.... but my insurance company sent me an anti-theft kit....it's an APEX cover.
Come on,you know Skii Doo owners have feelings too!...NO im wrong. theyre just a bunch of rich little haters that cant buy a cat because there friends will make fun of them,plus they have all that money sunk into those pretty yellow clothes.
lawnmoweragrass is offline   Reply With Quote
Old 02-11-2013, 04:09 PM   #3 (permalink)
thr2tom's Avatar
Current Sled(s): '12 F1100T Sp '09 F8sp '05 500xcsp '96 440 i
Previous Sled(s): 06 f7/800 bb
Favorite Riding Area: Tug hill, Local
Riding Since: 10
what about the synthetic decking boards? Access to a router table might work
thr2tom is offline   Reply With Quote
Old 02-11-2013, 04:11 PM   #4 (permalink)
nipmuckrider's Avatar
Current Sled(s): 2010 Doo MXZ 600ETEC
Previous Sled(s): too many
Favorite Riding Area: Long Trail Brewery
13-14 Mileage: 730
Riding Since: 1988
Default Re: Homemade Trailer Guides
Just buy a used plastic truck bedliner off craigslist. Should be able to find one for $20 or $30 bucks. If you're lucky theres one for free every now and then. Could try the local junk yard too. Cut them in strips with a sawzall or circular saw. If done this on several trailers and it works great!
If you do 5" strips one bedliner will do a whole 10' trailer. If you have a longer trailer or want wider strips (I recommend at least 6" wide) then u need two bed liners.
nipmuckrider is offline   Reply With Quote
Old 02-11-2013, 04:39 PM   #5 (permalink)
thr2tom's Avatar
Riding Since: 10
Ive heard of people doing this. Works good from what they say
Old 02-11-2013, 04:47 PM   #6 (permalink)
Mr. Part Time-On Line
Paul's Avatar
With a quick google search, I found the real thing for $110.
Caliber Trailer Ski Guides
I'm sure some of the Advertisers here on HCS can hook you up for similar, because I know what cost is on these, and its lower then the price above......
Paul is offline   Reply With Quote
Old 02-11-2013, 04:50 PM   #7 (permalink)
Thats for 40 linear feet. My solution above is for 80.
Old 02-11-2013, 05:00 PM   #8 (permalink)
sled208's Avatar
Current Sled(s): 2017 ZR 800 RR 137" ES LOL OR 2016 m8 ltd
Previous Sled(s): 13m8 13&12 XF HC, 4 X-fires, F7, 4 poos
Favorite Riding Area: On top of snow
Riding Since: 1988
The bed liners work for a while. They aren't nearly as durable as a manufactured ski guide. They get cut up from carbides
sled208 is offline   Reply With Quote
Old 02-11-2013, 06:20 PM   #9 (permalink)
snowtime's Avatar
Current Sled(s): 17SBA8ES
Previous Sled(s): 11SB6ES, 01XC5SP
Favorite Riding Area: Seney
16-17 Mileage: 630
15-16 Mileage: 380
14-15 Mileage: 975
13-14 Mileage: 1100
Riding Since: '99
People use the grooved vinyl garage door trim boards from home depot too.
2017 SWITCHBACK ASSAULT 800 ES WITH 2" TRACK, GRIPPER SKIS, AND 6" SHAPER BARS
Previous: '11 POLARIS SB 600ES, '01 POLARIS 500XCSP, '98 ARCTIC CAT ZL500
Trailer: TRITON LT4.5 Single place when needed.
snowtime is offline   Reply With Quote
Old 02-26-2013, 10:40 AM   #10 (permalink)
lg96gt's Avatar
Current Sled(s): 2013 SBA, 05' RMK, 74' Raider Double Eagle
Previous Sled(s): 73 lynx, 92 indy, 99 xcsp 600, 07 IQR 600HO, 09 Polaris D8.
Favorite Riding Area: POWDER!
Riding Since: 2002
on my two place tilt the truck bed liner idea worked out well..until i wanted to load 4 wheelers in the summer and i found them to be ice rinks basically. in my enclosed 30ft trailer i called around, found 4 bed lines, cut them up and installed them, went 8" wide on the sides, 12" wide in the middle. lets just say their gonna be forsale at haydays, not only because they fetch a pretty penny..(way more than they should) but as much as i want it to be guided, i want to be able to slightly turn, or even to pick up the front bumper and slide the sled just that inch left or right, with the bed liners you have to completely lift the sled and get the skis out of the MUCH deeper grooves(the carbide sits almost all the way in the grooves)...this on top of the height of them (pry almost 3/4") the fact i'm constantly tripping over them, the water that sits in them, the debree you cant sweep out of them...all reasons there a fail as far as i'm concerned for an enclosed trailer. i thought about synthetic decking, thought about 1x5" and i'm settling for now on nothing. i'll take the belt sander every other year, clean up the scratches, and repaint it. the other options are just to spendy...to go with the actual ski guides i'm looking upwards of $300. i thought about maybe just 7 sheets of quarter inch plywood so i can replace that every few years instead of wrecking my trailer floor...i'll ponder that for a while...since when did PLASTIC get so damned expensive...
lg96gt is offline   Reply With Quote
