Galvanic Corrosion - HCS Snowmobile Forums
Snowmobile Trailers & Haulers Section for discussions about trailers & other ways of hauling snowmobiles.
Like Tree5Likes
Old 06-12-2017, 07:35 PM   #1 (permalink)
Paparazzi of the Trail
can-amsledder's Avatar
Current Sled(s): 2010 MXZ800R
Previous Sled(s): 2006 MXZ800X
Favorite Riding Area: Parry Sound On.
14-15 Mileage: 1500
13-14 Mileage: 1400
Riding Since: 1985
Default Galvanic Corrosion
I have a 2004 Triton LT with a clam shell. Knowing about galvanic corrosion I have been keeping an eye on the frame where the axle bolts to. This past fall I knew I was going to have to do some repairs. This spring when I was getting ready to put everything away for the summer I was surprised at just how bad it had gotten.
The clam shell is now off and the axle is out. The trailer is upside down on my other trailer ready to go to a fab shop.
ID:	1852690   Click image for larger version
ID:	1852698   Click image for larger version
ID:	1852706   Click image for larger version
Snowmobiling, the most fun you can have with your clothes on
can-amsledder is offline   Reply With Quote
Old 06-12-2017, 08:01 PM   #2 (permalink)
Super Moderator - Chris
Bontz's Avatar
Current Sled(s): 2016 Switchback 800 Pro-X
Previous Sled(s): '15 Rush Pro-S; '12 SB Pro-R; '11 Rush Pro-R; '09 D8; '07 F8
Favorite Riding Area: Lake Namakagon/Cable, WI
16-17 Mileage: 825
15-16 Mileage: 1100
14-15 Mileage: 1153
13-14 Mileage: 1450
Riding Since: 1975
Good thing you're on top of things, Chris. That could've turned out really bad next season!
Bontz is offline   Reply With Quote
Old 06-12-2017, 08:07 PM   #3 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
I had an all stainless steel trailer up to last year, axle was the only steel part on it.
Old 06-12-2017, 08:21 PM   #4 (permalink)
polaris754's Avatar
Current Sled(s): 17 xcr 800 ,2 xcr 800,s 2000
Previous Sled(s): 95 xlt sp 69 399 nordic 73 cheetta 440 84 indy 600
Favorite Riding Area: bald mnt ,houghton lake
16-17 Mileage: 1175
15-16 Mileage: 550 x2
14-15 Mileage: 850
13-14 Mileage: 550
Riding Since: 1970
yep mine did the same, had it boxed and welded, welder said should be good as new
polaris754 is offline   Reply With Quote
Old 06-12-2017, 08:33 PM   #5 (permalink)
14-15 Mileage: 1500
13-14 Mileage: 1400
Riding Since: 1985
Here's a couple more pics.
A guy I know has a fab shop. He builds and works on a lot of hot rods and is a real good welder. He's going to get it fixed up for me.
ID:	1852722   Click image for larger version
Old 06-12-2017, 08:40 PM   #6 (permalink)
14-15 Mileage: 1500
13-14 Mileage: 1400
Riding Since: 1985
One of his last builds. Yes that's a Corvair
Old 06-12-2017, 08:44 PM   #7 (permalink)
snowtime's Avatar
Current Sled(s): 17SBA8ES
Previous Sled(s): 11SB6ES, 01XC5SP
Favorite Riding Area: Seney
16-17 Mileage: 630
15-16 Mileage: 380
14-15 Mileage: 975
13-14 Mileage: 1100
Riding Since: '99
There should be a protector between the frame and the axle mount. Those protectors last about 5 years. I've replaced mine three times and the aluminum frame has not shown any signs of GC. Trailer is an 02 triton.
example
http://www.hannarv.com/P/Triton02604...ntGasket/21253
2017 SWITCHBACK ASSAULT 800 ES WITH 2" TRACK, GRIPPER SKIS, AND 6" SHAPER BARS
Previous: '11 POLARIS SB 600ES, '01 POLARIS 500XCSP, '98 ARCTIC CAT ZL500
Trailer: TRITON LT4.5 Single place when needed.
snowtime is offline   Reply With Quote
Old 06-12-2017, 08:51 PM   #8 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
example
Triton 02604 Axle Mount Gasket - 2 Pack | TRITON-02604 | Hanna Trailer Supply Oak Creek, Wisconsin
Yup, it's a sacrificial anode.
Old 06-12-2017, 09:27 PM   #9 (permalink)
Current Sled(s): 97 t cat
Favorite Riding Area: Pinedale WY
15-16 Mileage: 100
Riding Since: 1977
that axle also looks like its on its way out, and YES< there should be a buffer between axle and trailer frame
metals just don't play happy with each other and being able to just replace a small part, makes life easier
I',m on my third axle(second one was a BAD axle from factory)
dexter axles are what I use and pay extra to have them galvanized , they last longer, my trailer is a 1997 yr model
over the yrs I had the main draw bar develop a crack at the pin hole for the tile, and had to replace that whole section, I up graded at that time and went thicker aluminum, so, should be stronger, and even added extra cross supports to help hold load better!
the last axle, I just BARELY caught in time, easy to take for granted there GOOD
I now inspect them every yr before season, better safe than sorry, and this time of yr isn;t a bad time to look, and FIX if needed!
Name:	trailer axle info 013.jpg
ID:	1852754   Click image for larger version
Name:	trailer axle info 022.jpg
ID:	1852762   Click image for larger version
Name:	trailer axle info 025.jpg
ID:	1852770   Click image for larger version
mrbb is offline   Reply With Quote
Old 06-12-2017, 09:45 PM   #10 (permalink)
14-15 Mileage: 1500
13-14 Mileage: 1400
Riding Since: 1985
example
You can see whats left of the gasket in this pic.
