Galvanic Corrosion - Page 4 - HCS Snowmobile Forums
Snowmobile Trailers & Haulers Section for discussions about trailers & other ways of hauling snowmobiles.
Like Tree5Likes
Old 06-19-2017, 10:19 AM   #31 (permalink)
Current Sled(s): 97 t cat
Favorite Riding Area: Pinedale WY
15-16 Mileage: 100
Riding Since: 1977
Originally Posted by snopromofo View Post
Inspected mine this past summer all looked good then this happened
OUCH< that looks like that was far from a fun day right there!
what happened, did the axle bend in the middle and break or??
mrbb is offline   Reply With Quote
Old 06-19-2017, 04:41 PM   #32 (permalink)
tcat446's Avatar
Current Sled(s): 2000 T-cat, 96 ZRT 800 AGLT/136" xfire skid
Previous Sled(s): 2000 Pantera, 2004 sabercat 500lxv
Favorite Riding Area: Mayville, Bemis point
Riding Since: 1973
I know of 2 guys who spent the money on fluid film for a few years and went back to Wal-mart bar and chain oil. Its straight 30 weight oil. It will stick better than fluid film and will not come off as easily. It will creep into any hard to get to area. It will penetrate pinched seams too. I do my truck every year. Something like 8 bucks a gallon. New oil will stick better than used and don't stink when your done. Been there done that. Not looking to argue with anyone on this, but me and my buddies have been doing this for years. Nothing but salt and brine here, so we have to do something or we will have nothing.
One big problem with some of these trailers is the front of the beam is open and salt and brine gets in and migrates to the area of the two metals. I have sealed mine off. Oil will help slow down the corrosion big time but won't eliminate it completely.
Michigan Brian likes this.
Life is not a bowl of cherries, its more like a jar of jalapenos, what you do today can burn your ass tomorrow.
tcat446 is offline   Reply With Quote
Old 06-19-2017, 07:11 PM   #33 (permalink)
polaris754's Avatar
Current Sled(s): 17 xcr 800 ,2 xcr 800,s 2000
Previous Sled(s): 95 xlt sp 69 399 nordic 73 cheetta 440 84 indy 600
Favorite Riding Area: bald mnt ,houghton lake
16-17 Mileage: 1175
15-16 Mileage: 550 x2
14-15 Mileage: 850
13-14 Mileage: 550
Riding Since: 1970
Originally Posted by jjlrrw View Post
I have a buddy that has a 2000 R&R he said there was a crack where the axle mounted to the frame. I'm not sure if it was caused from corrosion or stress I never seen it. He called R&R and they said bring it in and they repaired it free of charge, at the time it was almost 14 years old and he was not the original owner.
kinna thought i would do the please help bit at rnr ,they started off at 450 plus ended up some where else payin 175 deal
polaris754 is offline   Reply With Quote
Old 06-20-2017, 12:01 AM   #34 (permalink)
Current Sled(s): 15 Pro 600 155"
Previous Sled(s): 2008 Shift LE 155", 2000 700 RMK,94&95 XLT, 91 Indy 500
Favorite Riding Area: Big Holes or Centenials
13-14 Mileage: not enough
Riding Since: 1981
After reading all of the horror stories I checked my trailer (1991 Featherlite) this past weekend. Have done anything special to prevent corrosion and with exception of some stress cracks that I have had repaired and the natural oxidation that occurs with aluminum, I can't see any changes since I bought it 26 years ago.
steepndeep is offline   Reply With Quote
Old 06-20-2017, 10:44 AM   #35 (permalink)
15-16 Mileage: 100
Riding Since: 1977
they must not drench your road ways in winter time with salt like they do here then ,
Lucky you! road salt is the killer here, eats metals like kids and candy!
its why vehicles here fall apart in a 10 yrs or so, even if low miles and use, it just eats metals?
Old 06-20-2017, 03:53 PM   #36 (permalink)
Current Sled(s): '15 zr5000
Previous Sled(s): ext 600,cougars,fossils T660, zl800
Favorite Riding Area: 665
16-17 Mileage: 1926
15-16 Mileage: 2265
14-15 Mileage: 1430
13-14 Mileage: 1842
Riding Since: 1978
Wow, that must have hit the ground hard to knock all the rear lights out of the grommets.
thefoolsbro is offline   Reply With Quote
Old 06-20-2017, 10:46 PM   #37 (permalink)
Current Sled(s): "Agri-vator"
I'd agree with the new motor oil being as good or even better ( and way cheaper ) than fluid film, but after only a few years imo, oil starts to deteriorate rubber. Suspension and body bushings aren't what they use to be and after seeing some (new) ones of mine start to look pitted and cracking, I switched to Fluid film. I also have a '93 or '94 triton 12' purchased from a neighbor in '95 or 96, that I have only used for storage mostly in the last ten years or so, and it has most of the original paint on the axle, it's only on its second set of tires and rims (cheaper and easier than just buying tires) and it has no sign of corrosion between the frame and the axle. The isolator pad is crumbling though, maybe I'll replace it someday.
Old 06-20-2017, 10:52 PM   #38 (permalink)
aglick87's Avatar
Current Sled(s): 15 xf800, 04 zr 900, 03 zr hooper, 01 T-Cat
Previous Sled(s): 1989 wildcat 650, 04 F6 Early Build
Favorite Riding Area: New Brunswick, Canada
14-15 Mileage: 2200
13-14 Mileage: 1500
Riding Since: 1993
Had my 99 loadrite break the main frame rail from corroded aluminum around the u-bolts. Replaced them with 3/16 wall box tubing. Made custom axle brackets with a z-bar between the two plates to keep them from folding over. Added a layer of vinyl siding between the steel brackets and the new frame tubes. Painted the axle with por15 before assembling. Should be good for 20 more years.
ID:	1853577   Click image for larger version
aglick87 is offline   Reply With Quote
Old 06-21-2017, 12:54 AM   #39 (permalink)
snopromofo's Avatar
Current Sled(s): sw 800 pro s
Previous Sled(s): doo s
Favorite Riding Area: lots a snow
15-16 Mileage: 900+
14-15 Mileage: 1400+
13-14 Mileage: 300+
Riding Since: 1990
The left side tore out of the aluminum channel it was bolted to then it folded in half in the middle because the metal was getting thin and nearly tore the other side out could have gone real bad happened in the center lane of the mass. turnpike lost a days riding in Jackman. Had to buy a new trailer.
snopromofo is offline   Reply With Quote
Old 06-21-2017, 10:40 AM   #40 (permalink)
Luckily nobody got hurt. Really for what little these things use to cost back in the day, us guys getting 20 years out if them, really isn't that bad
Sexy bracket aglick
