14' indy 600 serous problem - HCS Snowmobile Forums
Indy (Pro-Ride Chassis) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 03-27-2017, 04:28 AM   #1 (permalink)
Newbie
16-17 Mileage: 2500
15-16 Mileage: 2500
Default 14' indy 600 serous problem
Hello everyone, this is my first post here on HCS. I have a 2014 voyager 600 with 5000 miles. Ive had all the heating problems that alot talk about on here that i remedied with ice scratchers. Then while riding yesterday, my engine temp would not go down but continue to heat up as long as the engine ran. i knew coolant wasnt pumping, so i decided with a big lump on my throat to take the engine out and split the crank case. After doing so, i discovered the crankshaft gear that turns the oil pump and coolant pump was worn down so much it wasn't able to turn the pump gear. there is ground metal everywhere where the gear goes. it looks to me the gears are made of brass or some soft metal. I just wanted to know what other folks thought about it, and or what others would do. i live in a town of a 1000 and there is 4 recent indys that had the same problem. just seems like polaris made a "set to fail" part.
BeringIndy is offline   Reply With Quote
Old 03-27-2017, 06:09 AM   #2 (permalink)
zeg
zeg's Avatar
Current Sled(s): 2013 Indy and 2005 IQR 440 moded to 600ho
Previous Sled(s): 1989 sport 340/1992 indy440/1998 storm/1996 xlt/2001 xcr800/
Favorite Riding Area: my camp
13-14 Mileage: 814 miles
Riding Since: 1990
They are all like that. You can buy the gear but you will jave to change the bearings. It sucks a verry poor design IMO
Sent from my LG-H812 using Tapatalk
zeg is offline   Reply With Quote
Old 04-01-2017, 08:56 AM   #3 (permalink)
what scratchers are you running? neeed to add some on my 15 voyager in the near future... sad to see engine wear at that low of mileage!
rambin is offline   Reply With Quote
Old 04-09-2017, 10:47 PM   #4 (permalink)
Drumerjb's Avatar
Current Sled(s): 14 Indy 800/ 05 800 XC/ 02 500 XC
Previous Sled(s): First sled- 72 340 Rupp Nitro,73 440 Nitro,75 440 FA Nitro
Favorite Riding Area: Any where in WI.
16-17 Mileage: 2100
15-16 Mileage: 875
14-15 Mileage: 2300
13-14 Mileage: 2100 +
Riding Since: 1968
Wow,this is not good news. Do u know the mileage of the other sleds?
Is the crank brass gear shot also? Are you getting proper oiling? If the small gear is bad I would imagine crank has to be pressed for large gear to be replaced???
Large job. Where are u in the process? Please keep us posted.
Drumerjb is offline   Reply With Quote
Old 04-09-2017, 10:52 PM   #5 (permalink)
rabbi's Avatar
Current Sled(s): 2016 600 Switcback Adventure
Previous Sled(s): Lots of Polaris'
Favorite Riding Area: Wi northwoods
15-16 Mileage: 880
14-15 Mileage: 650
13-14 Mileage: 2550
Riding Since: 1979
For 2018, Polaris addressed that problem. The two gears now run in a slight oil bath, giving them more lubrication then oil splashing over them.
Riding an AXYS, pure adrenalin!
rabbi is offline   Reply With Quote
Old 04-10-2017, 08:31 AM   #6 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
Haven't run into those issues yet on the newer 600's but seen it on older ones. Running a cheaper 2 stroke oil seems to accelerate the wear on these gears. Imo its better to run the poo oil or something that meets very close to it. Good to turn up the pump to.
Old 04-14-2017, 04:39 PM   #7 (permalink)
Newbie
16-17 Mileage: 2500
15-16 Mileage: 2500
i sent my engine via 177$ air frieght to darbys in fairbanks. the replaced parts on my crankshaft and lower case. 1500$ for parts and labor. i now have the engine back and rode a 100 miles premixed fuel towing my 18'skiff to camp. th oil line at the injection popped off half way and left a mess but my fuel being premixed saved an engine burn out. everything is running normal, temps are back in the 120s but it sure seems like the part will fail again. i use spring and rod scratchers and the helps keep cool even in shitty snow.
Old 04-14-2017, 11:11 PM   #8 (permalink)
Drumerjb's Avatar
16-17 Mileage: 2100
15-16 Mileage: 875
14-15 Mileage: 2300
Riding Since: 1968
this just pisses me off knowing i m going to go through this same bullshit.
Old 04-15-2017, 01:54 AM   #9 (permalink)
1fast444's Avatar
Current Sled(s): 2009 polaris iq shift 600 128" 1.25 Ice Attac
Previous Sled(s): 74customII530,76tx340,79txl,86indy4,95ss,97xcf,99xc6sp,2002
Location: xc6sp, 01xc6sp, 02xc7sp, 07fst, 11 IQ turbo and SE WIS.
Favorite Riding Area: U.P.
15-16 Mileage: 1000
14-15 Mileage: 1600
13-14 Mileage: 3050
Riding Since: 1988
Your pre-mixed fuel wasn't touching anything in the bottom end of your engine, how long did you ride it before you found the line off? That will cause a lot of damage fast in my opinion. Sorry to burst your bubble, but the oil injection comes threw the engine from the bottom up unlike the old carb models.
1fast444 is offline   Reply With Quote
Old 04-15-2017, 07:36 AM   #10 (permalink)
northstarrick's Avatar
i could have sold you a new crank shipped for that. there is something we do the the upper case. no more waterpump/oil pump drive gear issue after that. we mod. the cases on all polaris motors once opened up. to get more oil to bearings,gear, etc. it works.
i really don't know what these engineers are doing but there is no common sense with these guys thats for sure.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
