Headlights cut out
9.1K views 9 replies 7 participants last post by  motophile365
#1 ·
I was riding my Indy today and switched on the brights for a while. Then while I was riding my headlights suddenly flickered, turned on, off then on again. It just happened once then the rest of the ride they worked fine. Not sure where to start, anyone else have this issue?
#5 ·
I haven't looked at my 13 to close to see if they are designed like the old edge's but on my 02 the hi/low switch is built in with the heated hand grip adjustment. I was riding my 02 and the low went out completely but the hi would work flickering at times. I was careful and took the switch apart to find the plastic piece around the connections was melted not allowing to make a good connection on hi beam and no connection on low. So maybe this will be an issue with our new indys as well
#8 ·
I had my 14 indy 600 sp do this also. On,y seemed to happen at idle. Happened in the first 300 miles. I know have about 1000 miles on her and it not happened since I hit 300 miles.. I have had the hood off and disconnected the harness about 4-5 times since the 300 mile mark. Up to the 300 mile mark I did not disconnect the harness at all.. I am not sure if the harness was the problem or not, but it has not happened yet since mile 300..
Sent from Snowmobile.com App
