Td 4 stage v19 boost numbers - HCS Snowmobile Forums
Old 02-03-2013, 02:23 PM   #1 (permalink)
black1010's Avatar
Current Sled(s): 2012 f1100 turbo 50th
Previous Sled(s): 2007 f1200 sno pro 2004 ZR1010
Default Td 4 stage v19 boost numbers
Running 2012 procross with td 4 stage and getting 15 to 16 lbs on power trail and 17 to 18 lbs on max 91.....this seems low to me.
these numbers are taken at the engine manifold.
Can anyone share there numbers please?
black1010 is offline   Reply With Quote
Old 02-03-2013, 05:51 PM   #2 (permalink)
Current Sled(s): 2013 Apex XTX
Favorite Riding Area: U.P.
Riding Since: 1997
Doesn't seem low to me, 18lbs on a 91 tune is great. Max is 260 right?
painter6133 is offline   Reply With Quote
Old 02-03-2013, 06:22 PM   #3 (permalink)
HCS Advertiser
Turbo Dynamics's Avatar
Low numbers. Could be anything from boost leak blow off valve leak, or simply bad boost gauge or a wastegate issue etc...
How many grams in the primary and what RPM are you running on each program at full throttle once it settles... don't give me a recall number I'm talking about what it runs once steady for RPM.
1-800-549-0246
2009-2015 1100 turbo 4 stage ECU REFLASH, 200-273HP on pump gas up to 320HP on race fuel. Fastest stock turbo E.T. on grass 4.46 at Haydays 2013 (Priceless sled)
Turbo Dynamics is offline   Reply With Quote
Old 02-03-2013, 06:50 PM   #4 (permalink)
black1010's Avatar
running t1s with the two smallest inserts in the heal....will have to check how much weight that is.
The rpm is a concern it starts out about 8100 or so but drops to 7700 or so as you cross the lake.... This is on max 94 it's a little less rpm on power trail
Old 02-03-2013, 06:57 PM   #5 (permalink)
THUNDER333's Avatar
Current Sled(s): 2016 ZR 9000 turbo limited
Previous Sled(s): lots
Favorite Riding Area: bedroom
Riding Since: kid
You should not lose RPM with no tip Weight . Check all boost hose clamps and make sure your boost lines to selonoids are hooked up correctly
THUNDER333 is offline   Reply With Quote
Old 02-03-2013, 07:17 PM   #6 (permalink)
black1010's Avatar
Went over all the clamps last time I had the hood off but will check again.
what should the boost numbers be?
The rpms drop as the run progresses......I don't think it could be boost adjust because I don't get a light
Old 02-03-2013, 07:22 PM   #7 (permalink)
black1010's Avatar
Checked weight of t1s it looks like 92 grams......seems low
Old 02-03-2013, 07:47 PM   #8 (permalink)
trdehmer's Avatar
Current Sled(s): 2016 Axys SB 800 ProS & 2015 Axys SB 800 60th
Riding Since: 1984
Black1010 - what specifically are you running for clutching?
Previous Sleds:
2012 F1100 Turbo 50th
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
1990 Polaris 340 Sport
1984 Polaris 480 Trail
A Phazer
1969 Massey Ferg Ski Whiz
trdehmer is offline   Reply With Quote
Old 02-03-2013, 08:01 PM   #9 (permalink)
black1010's Avatar
T1s @ 92 grams d&d tan primary dalton 48/42 -38 helix dalton green silver sec. Spring
Old 02-03-2013, 08:09 PM   #10 (permalink)
trdehmer's Avatar
Riding Since: 1984
That should work. What are you running for a shim? Should run DDSA2 or D&D Z1 Turbo shim.
Previous Sleds:
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
A Phazer
