Questions on Turbo Dynamics aftermarket Products!!! - HCS Snowmobile Forums
Old 11-30-2011, 08:29 PM   #1 (permalink)
Jester's Avatar
Current Sled(s): 17 Sidewinder LTX-SE, 12 f1100lxr
Previous Sled(s): 12 F 1100 SP Turbo06 cf 700 SP, 05 F7sp, 08 f1000, 07 cf1000
Favorite Riding Area: Norther Ontario/ Quebec
16-17 Mileage: 800
15-16 Mileage: 1800
14-15 Mileage: 2200
13-14 Mileage: 2500
Riding Since: 1969
Arrow Questions on Turbo Dynamics aftermarket Products!!!
Please post your questions here!
Please refrain from other manufacturer questions here and posers dropping in for a bash will be warned and then be taking a holiday. The TD crew doesn't need to waste their time on posers when they can be helping us Joes!
Thanks
JesterTurbo Dynamics Arctic Cat 2012 F1100 XF1100 M1100 and Z1 turbo ECU reflash
Ready for snow wherever it may be!!!!
Jester is offline   Reply With Quote
Old 11-30-2011, 08:42 PM   #2 (permalink)
Jester's Avatar
16-17 Mileage: 800
15-16 Mileage: 1800
14-15 Mileage: 2200
13-14 Mileage: 2500
Riding Since: 1969
Default TD at Dynotech
From Ben at TD
All these numbers are with the TD TurboForce Super Quiet muffler and TD turbo outlet and stock intercooler. Everything else is bone stock.
304 HP on 91 octane 5 second pull (tested at 7% ethanol if you are curious)
That is the OFFICIAL RECORD
That is maximum power, the highest boost we could go without getting any knock and no clicks from Jim's detonation ear phone. This is the same map is Max91/94 running max boost with a small shim of the turbocharger.
273HP with Max91/93 running at normal boost level (available to the public)
256HP Powertrail 91
221HP Ecotrail
200HP with the stock ECU with only mods being TurboForce Super Quiet and TD turbo outlet.
More details to come tonight.
Turbo Dynamics Webstore
2012 1100 turbo and Z1 turbo
4 stage ECU REFLASH, 200-267HP on pump gas
TD ECU reflash owns the Pump gas record, Methanol Record, Top speed Z1 unofficial record holder 161.5mph on radar and 1/4 mile top speed record 154.5mph ! Along with many Drag racing wins !
Check out our Youtube videos search for Turbo Dynamics Z1
Old 11-30-2011, 08:44 PM   #3 (permalink)
Jester's Avatar
16-17 Mileage: 800
15-16 Mileage: 1800
14-15 Mileage: 2200
13-14 Mileage: 2500
Riding Since: 1969
From Ben at TD!
Originally Posted by jtssrx
is there going to be runs done on 93 octane fuel and if so are those numbers going to be posted today?
why is the 304 hp tune not available to the public?
It is available (it's the max91 map with extra boost)
but I don't recommended it. I can tell you how to get it done.
But To be safe you would run minimum 93 octane and a little race fuel maybe a gallon or two to be sure you won't get any knock.
We were on the edge of detonation. On 93 it made 301HP...lost a few HP.
Our 91 ended up being slightly superior to the 93. But that is most likely because when you buy gas at the pump it is minimum 91, we most likely had more like 93 in it from the looks of it.
Still this goes to show how much room our programs leave on pump gas. At 273HP the max91 map at regular boost looks conservative LOL !
Old 11-30-2011, 08:44 PM   #4 (permalink)
jason_hildo's Avatar
Current Sled(s): 2014 XF9000HC Limited 2012 M800SP
Previous Sled(s): 2005 Firecat F6, 2010 CF8SP, 2012 XF1100T Ltd
Riding Since: 1996
Maybe dealers or TD themselves could post up their clutching recommendations as they start getting some testing in with the ECU reflash?
jason_hildo is offline   Reply With Quote
Old 11-30-2011, 08:50 PM   #5 (permalink)
Jester's Avatar
16-17 Mileage: 800
15-16 Mileage: 1800
14-15 Mileage: 2200
13-14 Mileage: 2500
Riding Since: 1969
Great question and I am sure Ben will check in!
Thanks
Jester
Old 11-30-2011, 08:51 PM   #6 (permalink)
Jester's Avatar
16-17 Mileage: 800
15-16 Mileage: 1800
14-15 Mileage: 2200
13-14 Mileage: 2500
Riding Since: 1969
From Ben at TD
Ok. So you guys want to know what HP level can be selected to hold for a very long time (mile).
That will depend on many factors, including clutching RPM, fuel quality, actual boost level and fuel pump condition etc...
Yes we have tested extensively long throttle pulls.
Powertrail is the highest safe setting for long pulls. Most people can hold it for very long time. The ones who cannot hold it as long are typically overboosters (machines who run more boost than the average).
That said overbooster machines make more power than 256HP on Powertrail and therefore can run the Performance 91 program to make the same power as powertrail and hold it for long periods of time also.
This is why we offer many programming starting from Ecotrail (14psi) to Performance 91 (16psi) to powertrail (18psi) to Max91 (20.5 psi) to race (22psi-30psi).
So to be conservative for long throttle pulls (more than 5000 feet) 256HP is the highest recommended setting for pure 91 octane fuel. The knock light will warn if you are exceeding max power level.
Old 11-30-2011, 10:18 PM   #7 (permalink)
Bormo85's Avatar
Current Sled(s): 13 f1100t RR, 16 zr 8000 137 limited
Previous Sled(s): Xf 1100t ltd, 2011 cf 800 sno pro, 2009 cfr 800, 2001 zr 600
13-14 Mileage: 1000
Default Ben did any mufflers send today?
Ben just wondering if you happened to ship any mufflers today? If so which model
Bormo85 is offline   Reply With Quote
Old 11-30-2011, 10:38 PM   #8 (permalink)
dmaxkidf7's Avatar
Current Sled(s): 2012 M1100T 2013 Assault
Favorite Riding Area: snow
Riding Since: 1992
X2 !!!!!!! patiently waiting
13' Assault 11' RaptorKiller
12' M1100T 08' OverPowered PlowTruck
11' Z1EXT 07' Canturion Avalanche
99' ThunderCat
dmaxkidf7 is offline   Reply With Quote
Old 12-01-2011, 09:28 AM   #9 (permalink)
type_a_positive's Avatar
Originally Posted by Jester View Post
256HP Powertrail 91
221HP Ecotrail
What about HP for the TD Performance 91 map????
And is it safe to run the muffler and outlet without ECU mods?
Proclimb 1100T SP 162, re-mapped and GEARED UP!
Bearcat Z1 XT, Jaguar Z1, Ski-Doo GT 500F
type_a_positive is offline   Reply With Quote
Old 12-01-2011, 09:53 AM   #10 (permalink)
Jester's Avatar
16-17 Mileage: 800
15-16 Mileage: 1800
14-15 Mileage: 2200
13-14 Mileage: 2500
Riding Since: 1969
Cannot answer the first qustion but the second it is planty safe as that is the combo I am running and you still have warranty and 200 hp! Only issue may be running rpm closer to the rev limiter. If so a set of weights or a good clutch kit will help. Won't know that unitl we hit the lake later.
Jester
