Bog/backfire . Won't rev over 5500 rpm - HCS Snowmobile Forums
Old 01-10-2017, 11:40 PM   #1 (permalink)
Member
15-16 Mileage: 2000
14-15 Mileage: 500
13-14 Mileage: 4000
Default Bog/backfire . Won't rev over 5500 rpm
I have an 1100 turbo. Speedwerx 240hp tune, td 2.5" exhaust. Was perfect for a while, then I experienced a wierd bog backfire when I hit it. Did it once then went away. Then next ride out it started to get progressively worse. At first it wouldn't rev over 6500, then 6000 and now 5500. Ran 2 full tanks of gas through and still getting worse. Doesn't matter if I'm full or near empty. Tried adjusting throttle Cable, no difference. Tried disconnecting tss, no difference . What should I look for next? I double checked all boost tubes, they look good. It does it under load or not. I'm stumped !
Hodgric is offline   Reply With Quote
Old 01-10-2017, 11:59 PM   #2 (permalink)
canoehead's Avatar
Current Sled(s): 2014 XF 9000 HC Limited
Previous Sled(s): 440 Motoski,340 Scorpion,JDX8,440Prowler,700ZR,RX1, 09 Nytro
15-16 Mileage: 800
14-15 Mileage: 2400
13-14 Mileage: 1600
Riding Since: 1967
You might want to have a look at your turbo impellers.
canoehead is online now   Reply With Quote
Old 01-11-2017, 12:02 AM   #3 (permalink)
Member
16-17 Mileage: 400
15-16 Mileage: 400
14-15 Mileage: 1000
13-14 Mileage: 700
X2 it sounds like turbo went out. That would be a good start anyway.
Catwheels88 is offline   Reply With Quote
Old 01-11-2017, 12:03 AM   #4 (permalink)
Member
16-17 Mileage: 400
15-16 Mileage: 400
14-15 Mileage: 1000
13-14 Mileage: 700
Any oil in boost tubes?
Old 01-11-2017, 12:30 AM   #5 (permalink)
HCS Advertiser
GreenInMyVeins's Avatar
Current Sled(s): 13' XF Turbo Lake Racer, FTS M162 Outlaw
Favorite Riding Area: Houghton Lake, MI
Check fuel pressure regulator vacuum hose.
Life is 440 Horsepower in a 2 Cylinder Engine.
GreenInMyVeins is online now   Reply With Quote
Old 01-11-2017, 12:41 AM   #6 (permalink)
canoehead's Avatar
15-16 Mileage: 800
14-15 Mileage: 2400
13-14 Mileage: 1600
Riding Since: 1967
Out of curiousity, is it common for these to come off?
Where is it located?
Thanks in advance.
Old 01-11-2017, 07:40 AM   #7 (permalink)
erskin's Avatar
Current Sled(s): 2014 xf9000 turbo ltd
Favorite Riding Area: Northern Maine
16-17 Mileage: 400
15-16 Mileage: 250
14-15 Mileage: 1350
13-14 Mileage: 1775
Riding Since: 1978
Did you ever gap your spark plugs?
erskin is offline   Reply With Quote
Old 01-11-2017, 08:21 AM   #8 (permalink)
HCS Advertiser
Thanks in advance.
I've seen it happen. Next to plenum on fuel rail, PTO side.
Old 01-11-2017, 08:55 AM   #9 (permalink)
jafo1970's Avatar
Current Sled(s): 17 Sidewinder, 16 ZR9000 TD tuned
Previous Sled(s): 12F1100T, 10 z1t sno pro,10z1t 300hp,08 XP 800rx,05 Mach Z
Favorite Riding Area: Where there's snow
15-16 Mileage: 2300
14-15 Mileage: 2200
13-14 Mileage: 3000
Riding Since: 1976
They crack after about 4 or 5 years also.
jafo1970 is offline   Reply With Quote
Old 01-11-2017, 09:02 AM   #10 (permalink)
Current Sled(s): Jacked xf 9000 turbo
Previous Sled(s): Jacked z1 turbo, Polaris xc 700
Favorite Riding Area: Bancroft,
13-14 Mileage: 1500
Riding Since: 1977
Make sure the motor is getting air,filter is not plugged, has this started after being in storage, good luck
bigbadbrad is offline   Reply With Quote
