Post any issues, recalls, service bulletins and known issues for 2012 cats - HCS Snowmobile Forums
Turbo 4 Stroke Performance This is the section for all the Turbo talk This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 11-14-2011, 05:43 PM   #1 (permalink)
Super Moderator
ArcticCatDude9's Avatar
Current Sled(s): 2009 M8 162, 2000 ZL500
Previous Sled(s): 2012 xf 1100 turbo lxr,09 nytro xtx, 02 MM700, 01 ZL 580 esr
Favorite Riding Area: Shin Pond, Jtown, Greenville
11-12 Mileage: 2100
10-11 Mileage: 3568
Riding Since: 93
Default Post any issues, recalls, service bulletins and known issues for 2012 cats
Just trying to think of stuff that needs to be addressed with our dealers before we take delivery of our sleds and compile it in one thread. If i forgot anything please let me know and ill add it to the list, thanks
ALL OFFICIAL SERVICE BULLETINS AND RECALLS CAN BE VIEWED AND OR DOWNLOADED AT THE BOTTOM OF THIS POST. (thanks trdehmer and acsnoracer69)
1100 turbo's and na's
a. High/lo light dimmer switch recall
b. Reverse issues/ chaincase problems
c. Waste gate valve sticking (excess weld)
d. air filter elbow doesnt fit correctly
e. loose primary clutch (re torque to 55 lbs)
f. faulty idler wheels
g. Headlight Fuse Recall
h. Steering tie rod loose recall
i. Fuel filter incorrectly installed (turbos only)
800's
A. rivet stud in air box
B. leaky o ring oil container
C. mid pipe rub on cowl (fixed on later models)
D. air bubbles in oil lines
E. High/lo light dimmer switch recall
F. loose primary clutch (re torque to 55 lbs)
G. faulty idler wheels
H. Headlight Fuse Recall
I. Steering tie rod loose recall
J. Loose Drive Shaft Nut sb
K. Handle bar bolts loose sb
SB and Recall Downloads
BS201201 Handlebar bolts sb https://docs.google.com/open?id=0B90...M3MzQyMGI5MDQ5
BS201203 dimmer switch recall
https://docs.google.com/open?id=0B90...k3NDY3MzFjN2Nj
BS201204 gear shift sb https://docs.google.com/open?id=0B90...Q0OGM3ZTc0ZmI4
BS201205 gear shift sb https://docs.google.com/open?id=0B90...RiNDg1MDdiNjFj
BS201206 shift fork sb https://docs.google.com/open?id=0B90...M2YzY3MTA1ZmJh
BS201207 turbo elbow sb
https://docs.google.com/open?id=0B90...E0NGViOWFhZDAz
BS201208 faulty idler wheel sb
https://docs.google.com/open?id=0B90...E4MWQ3ODZhNDQw
BS201209 10 11 steering recall
https://docs.google.com/open?id=0B90...RhMjVjNDM5NWM2
BS201213 Fuel filter location https://docs.google.com/open?id=0B90...UxZTM0OTk2N2Iz
BS201214 Drive Shaft Nut sb https://docs.google.com/open?id=0B90...BmMTlkMjQxMDBj
BS201215 16 17 Reverse sb
https://docs.google.com/open?id=0B90...ZjOTQ1MzdmZThm
K24084107 2 stroke oil line sb https://docs.google.com/open?id=0B90...c0MGMwNTFkM2Iw
120009 headlight fuse recall https://docs.google.com/open?id=0B90...kxOTRhZGE3YTI5
ArcticCatDude9 is offline   Reply With Quote
Old 11-14-2011, 06:06 PM   #2 (permalink)
favoritos's Avatar
Current Sled(s): 2013 F8 SP
Previous Sled(s): F8 EXT, Lots of Crossfires
Favorite Riding Area: U.P.
11-12 Mileage: not enough
10-11 Mileage: 2,900
Is there a pipe update on the 800?
I'm still learning.
favoritos is offline   Reply With Quote
Old 11-14-2011, 06:10 PM   #3 (permalink)
SIOUX YEA YEA's Avatar
Current Sled(s): It's black
Previous Sled(s): They were orange
11-12 Mileage: 1300
10-11 Mileage: 1800
Riding Since: 1994
Not unless your sled develops a problem.
SIOUX YEA YEA is offline   Reply With Quote
Old 11-14-2011, 06:14 PM   #4 (permalink)
favoritos's Avatar
I wondered if I needed to get after the thing with a mallet? If it develops a problem it's too late.
I'm still learning.
Old 11-14-2011, 06:59 PM   #5 (permalink)
Current Sled(s): xf 800 high country
Previous Sled(s): 2001 zr 600
Favorite Riding Area: Pense
What is this leaky oring problem?
klemper is offline   Reply With Quote
Old 11-14-2011, 07:05 PM   #6 (permalink)
Way Fast Kitty's Avatar
Current Sled(s): 2012 800 pc 09 sno pro 600 09 phaser rtx05
Previous Sled(s): skandic550, vkpro, vk540, apex, tcat, mach z800 ,zr800 cc
Favorite Riding Area: anywhere fast
10-11 Mileage: 3500
Riding Since: 1978
What is the update on the pipe for ?
Is it breaking? Or meltting something ?
Way Fast Kitty is offline   Reply With Quote
Old 11-14-2011, 07:11 PM   #7 (permalink)
Current Sled(s): 2012 XF1100T Ltd
Previous Sled(s): 2011 Z1T EXT
if inj tank is filled to far up the plastic filler neck it can leak.
make sure you have the o-ring in the cap part # is 0109-733
omie is offline   Reply With Quote
Old 11-14-2011, 08:35 PM   #8 (permalink)
witewtr201's Avatar
Current Sled(s): 2013 F1100T SP RR Green and 2012 XF 800 SP
Previous Sled(s): A few Zr's, 05 f7, 07 XF 800
Favorite Riding Area: Jackman POW,Fort kent, Lincoln
12-13 Mileage: 3106
11-12 Mileage: 2500
10-11 Mileage: 2600
Riding Since: 1994
A small portion of the hood sits on the exhaust and COULD....not saying it will... but COULD be a problem
I know they fixed the issue at the factory and i wanna say it was maybe 3 weeks or so ago with making a slight indent on the exhaust sheild
Glad mine is being built now on the 28th
witewtr201 is offline   Reply With Quote
Old 11-14-2011, 08:39 PM   #9 (permalink)
witewtr201's Avatar
12-13 Mileage: 3106
11-12 Mileage: 2500
10-11 Mileage: 2600
Riding Since: 1994
I thought the OEM o ring wasnt big enough and the fix was a larger size o ring....i thought i read a guy getting a slightly larger size at the hardware store but i could have been mistaken
Old 11-14-2011, 08:49 PM   #10 (permalink)
I think you're right. I seen that somewhere here.
If the OEM o-ring is there, then as long as its not filled to high up the neck it shouldnt leak.
lots of people like to fill them to the top.
In that case a thicker o-ring would seal better.
the o-ring it comes with is the same one used on some AC gas caps.
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
