Supertraxmag, Procross Suspension article - HCS Snowmobile Forums
Old 03-16-2012, 09:12 AM   #1 (permalink)
ecdlmd02's Avatar
Current Sled(s): 14' XF8000 SP
Previous Sled(s): F8, ZL800, Wildcat
Favorite Riding Area: The County
12-13 Mileage: Not enough
11-12 Mileage: 900
10-11 Mileage: 700
Default Supertraxmag, Procross Suspension article
Did anyone read this from Supertrax? Wonder if that is a typo, below in bold, could it be correct? Seems insane as compared to the 20lbs of the F series.
If you found your 2012 ProCross Cat tended to "pack up" about two-thirds of the way through its suspension travel, we may have a fix for you.
We found this tendency ourselves and were a bit frustrated this winter trying to get the skid to use its full travel and take advantage of its shocks' ability to dampen.
It actually felt like it was bottoming out all the time - a tendency we never experienced at all on the early 2012 Cat protos we rode a year ago.
This was especially noticeable on Sno-Pro models where there are no damping adjusters on the skid shocks and the calibration seems to be overly stiff anyway.
Our LXR press sled did the same "packing thing" but because the shocks are set to be more compliant, we could live with it much better. Still not as good as we knew it could be!
According to the Cat engineers, here's the fix: Apparently, the 128-inch track on the Procross tends to be too tight. Since the track doesn't have enough deflection when set at what would be normal adjustment other years, when it gets past the halfway point in its travel, the track goes way tight and resists movement through the rest of its travel.
If you've noticed this stiffness (almost like the sled is bottoming out - call it "soft bottoming"), you need to back off your adjusters so the track is hanging down 1.5 inches with 110 pounds pressure measured halfway down the rail.
Make sure you've set your pull scale from the center of the track, not the outside edge, when measuring deflection.
Apparently, a looser track allows the ProCross skid to deliver everything you paid for.
ecdlmd02 is online now   Reply With Quote
Old 03-16-2012, 09:26 AM   #2 (permalink)
JMR
Banned
110 lbs? That seems excessive.
JMR is offline   Reply With Quote
Old 03-16-2012, 09:30 AM   #3 (permalink)
Current Sled(s): Procross 800 RR
Previous Sled(s): ,12 F800 sno pro, Rush 600, 600RR, F8 sno pro, many doo's
12-13 Mileage: 3000
11-12 Mileage: 1400
10-11 Mileage: 3000
I would never of thought to run the track that tight. Maybe that is why I never really thought it rode stiff.
WOTF8 is offline   Reply With Quote
Old 03-16-2012, 09:32 AM   #4 (permalink)
Current Sled(s): 2012 cat turbo lxr
Favorite Riding Area: dorset
Riding Since: 1993
it must be a typo id say 10 lbs. regardless it could explain a few things such as slider wear.
Sideshow Bob is offline   Reply With Quote
Old 03-16-2012, 11:07 AM   #5 (permalink)
Arctic Cat Cheerleader!!
krom's Avatar
Current Sled(s): 09 Sno Xer
Favorite Riding Area: South of the Hill
Typo, should be 10 lbs
Originally Posted by backcountryislife View Post
Hoping a poo motor will hold up is like voting for Obama... it's ranbows & fairy dust... hope & change
Originally Posted by 6.2 View Post
Wow, this 800 RUSH PRO R dude needs to get a life. Seriously dude, give it up.
Originally Posted by A05GSHO View Post
Thats cause most of the Poo guys are a bunch of whiny bitches, unlike you Cat guys
Originally Posted by 800 RUSH PRO R
Facts are facts the 800 Polaris r has 20 less hp
krom is offline   Reply With Quote
Old 03-16-2012, 11:17 AM   #6 (permalink)
What does the owners / service manual say?
f11 turbo is offline   Reply With Quote
Old 03-16-2012, 11:39 AM   #7 (permalink)
gwilburn's Avatar
Current Sled(s): 2012 F8 Sno Pro
Previous Sled(s): 08 F8, 06 CF6, 03 F7
Favorite Riding Area: Ontario & da UP
12-13 Mileage: 2175
11-12 Mileage: 853
10-11 Mileage: 1400
Riding Since: 1972
I always run mine much looser than the manual. I think it says 1-1.5 under 20 lbs of tension.
I'm running that deflection under NO tension.... but i'm not studded.
My problem was the small chop, not the big stuff
gwilburn is offline   Reply With Quote
Old 03-16-2012, 12:08 PM   #8 (permalink)
Jester's Avatar
Current Sled(s): 12 F1100 SP turbo Orange, 08 f1000 sp
Previous Sled(s): 06 cf 700 SP, 05 F7sp
Favorite Riding Area: Norther Ontario/ Quebec
11-12 Mileage: 1800
10-11 Mileage: 2500
Riding Since: 1969
I felt this with mine and never could really get tid of it. I was more worried about the tracck ratcheting. I will play with this next year.
Jester
Ready for snow wherever it may be!!!!
Jester is online now   Reply With Quote
Old 03-16-2012, 02:33 PM   #9 (permalink)
I'm reading my spec sheet for F800 and track deflection is: 2-2 1/4" @ 20 lbs.
ttraynor is offline   Reply With Quote
Old 03-16-2012, 03:19 PM   #10 (permalink)
gwilburn's Avatar
12-13 Mileage: 2175
11-12 Mileage: 853
10-11 Mileage: 1400
Riding Since: 1972
Hmmm. maybe i should make mine 2.25" deflection with 0 lbs. I was told a long time ago to run it as loose as possible w/out ratcheting.
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
