Primary clutch shim for turbos? - Page 2 - HCS Snowmobile Forums
Old 11-20-2011, 10:55 AM   #11 (permalink)
rodder's Avatar
Current Sled(s): POS 2012 F1100 TURBO LE
Previous Sled(s): HIJACKED 09Z1 TURBO LXR
Originally Posted by hallnracing View Post
Must have been someone else. Primary clutch same as 2011. Shim still required for serious racing with all cam arms I have tried. Shimming is different than 2009-2010. If you are using the D&D shim, be sure it is for 2011-2012 and not the older one. Trail use will be fine without the shim.
So will it be o.k to run the D&DQA-T without the shim? Have the tools did it to my 09. Also what size shim and small end up? Thanx in advance.
rodder is offline   Reply With Quote
Old 11-20-2011, 11:03 AM   #12 (permalink)
31cccat's Avatar
Current Sled(s): Bigger Turbos
Previous Sled(s): Big Turbos
Favorite Riding Area: WI
Riding Since: 2
post down (small side)towards inner sheave, allows the sheaves to open more. Same shim as d@d 2011 clutch kit for new sleds
TD dealer
FTSS dealer
31cccat is offline   Reply With Quote
Old 11-20-2011, 11:04 AM   #13 (permalink)
rockerdan's Avatar
Current Sled(s): '16 1200x 4tec XS
Previous Sled(s): '14 Etec 800, '12 Cat F Turbo, '06 Apex, '06 MachZ
Location: Niag.Falls(Summer) ; Huntsville Ontario(Winter)
Favorite Riding Area: Huntsville,Muskoka
Riding Since: 1970
Ok guys clue me in...first cat ive ever owned and first turbo....
Is this shim strictly needed when using aftermarket weights/arms?
For an ECU tune, what is everyone doing for clutching? i was under the impression with the REV Limiter raised in the tune, we just were to run up around 8400rpms and were good to go.
I read so many threads saying the motor actually made better power/tq numbers up around 8400 too. So why not just run it there and not need to worry about a gearing change then?
thanks!
Dan
'16 MxZ-X 12004tec XS, Boost Engineering ECU Flash, MBRP Header, PB80
'14 MxZ-X 800Etec
'12 F1100 Turbo,TD 4 stage, Sandale full 3"
'06 Apex RTX
rockerdan is offline   Reply With Quote
Old 11-20-2011, 12:07 PM   #14 (permalink)
hallnracing's Avatar
Whether or not you need the shim has more to do with what you are using the sled for, rather than what weights you are using. Some more aggressive weight profiles (D&D holeshot, STM turbo) require shimming, just to make them fit. If you are having issues gripping the belt down low (usually only a problem on standing start wot, with very good traction), then you may want to give it a little more bite, with added shim. Very difficult to get a good race setup without added shim. Trail setup will be fine with stock shimming. D&D trail use T1 weights and white primary with stock belt and secondary. D&D race use shim, D&D belt, big D&D helix (still fine tuning details).
World's fastest Cats use D&D parts
Mod Z1 1000ft 172 Mike Martin
Stk Z1 1/4 mile 8.25 156mph Matt Ernst
Stk Z1 1/4 mile 8.14 159mph
Mod Z1 500' speed 141mph Jim Stanley
Stk Z1 1000' 137mph Jesse Wilson
Stk Z1 660' 5.27 124.9mph
Stk Z1 500' 4.41 110mph Jason Price
Mod Z1 660' 4.54 151mph Jeff Ratzlaf
Mod Z1 500' 3.81
Lakeracer 500' 3.96 Dave Gallano
Lakeracer 660' 4.77 148mph Jim Skiver
Lakeracer 500' 134mph Aaron Casler
hallnracing is offline   Reply With Quote
Old 11-20-2011, 03:54 PM   #15 (permalink)
rockerdan's Avatar
Riding Since: 1970
thanks for the detailed info, much appreciated!
I take it for trail riding and radar running only i should be ok with stock setup and just run more rpms. I would like to see what arms work well and maybe do a change on the arms only. I think ive read the secondary setup is good to go stock.
I guess with clutching we will all know more when we get some seat time in finally....need snow and a damn sled too!..LOL
Dan
'14 MxZ-X 800Etec
'06 Apex RTX
Old 11-20-2011, 04:01 PM   #16 (permalink)
catchmeifucan's Avatar
Current Sled(s): 2012 F1100T SP LTD, 2007 Attak
Previous Sled(s): 1996 TCat 1004, PS1000 Cat
I hear they are not gonna deliver your sled if you came from a yammie!
catchmeifucan is offline   Reply With Quote
Old 11-20-2011, 04:20 PM   #17 (permalink)
DCXR1000's Avatar
Current Sled(s): 2012 Procross F1100 Turbo
Previous Sled(s): 2010 Sno Pro 1200
Is the D&D shim the same as the Dalton?
Arctic Spider Shim
DSS-A1
DCXR1000 is offline   Reply With Quote
Old 11-20-2011, 04:29 PM   #18 (permalink)
rockerdan's Avatar
Riding Since: 1970
Arctic Spider Shim
DSS-A1
are we talking a shim behind primary spring?
Dan
'14 MxZ-X 800Etec
'06 Apex RTX
Old 11-20-2011, 04:40 PM   #19 (permalink)
Current Sled(s): "Agri-vator"
no. it's a shim located under/behind the spider as to relocate the moveable sheave. requires spider removal.
stronger800 is online now   Reply With Quote
Old 11-20-2011, 04:54 PM   #20 (permalink)
DCXR1000's Avatar
This shim goes between the spider and the outside sheave. You have to remove the large nut and spider and the shims are under the spider. Requires a clutch holder, deep well socket, a spider removal tool, and lots of heat.
