Engine reverse stalling - HCS Snowmobile Forums
Old 04-15-2017, 02:00 PM   #1 (permalink)
aglick87's Avatar
Current Sled(s): 15 xf800, 04 zr 900, 03 zr hooper, 01 T-Cat
Previous Sled(s): 1989 wildcat 650, 04 F6 Early Build
Favorite Riding Area: New Brunswick, Canada
14-15 Mileage: 2200
13-14 Mileage: 1500
Riding Since: 1993
Default Engine reverse stalling
Has anyone ever had trouble with their engine reverse, and the motor stalling? We are having trouble with a 2010 F8 with the 800 HO. We have checked the wiring harness everywhere and swapped ECUs with a 2015. The stater and ignition pick up coil's ohm within spec. It runs fine otherwise. Where else should we look? It's stalls kicking into reverse and kicking into forward.
aglick87 is offline   Reply With Quote
Old 04-15-2017, 03:25 PM   #2 (permalink)
zoggan's Avatar
Current Sled(s): 2014 XF7000LTD
Previous Sled(s): Many Ski-Doo's
Favorite Riding Area: Grand Marais, Mn
Riding Since: 1978
On Doo's with electronic reverse, it's a sure sign of low compression. Almost guaranteed on Rotax engines. And yes they do run fine until you try to reverse them.
zoggan is offline   Reply With Quote
Old 04-15-2017, 03:42 PM   #3 (permalink)
sleeping_dragon's Avatar
Riding Since: 1974
Check tps
sleeping_dragon is offline   Reply With Quote
Old 04-15-2017, 04:12 PM   #4 (permalink)
Super Moderator - Chris
Bontz's Avatar
Current Sled(s): 2016 Switchback 800 Pro-X
Previous Sled(s): '15 Rush Pro-S; '12 SB Pro-R; '11 Rush Pro-R; '09 D8; '07 F8
Favorite Riding Area: Lake Namakagon/Cable, WI
16-17 Mileage: 825
15-16 Mileage: 1100
14-15 Mileage: 1153
13-14 Mileage: 1450
Riding Since: 1975
Took the words outta my mouth. A lot of times it's a sign of bigger issues, and I would agree that a compression check is a must. If it checks out, good - one less thing to worry about!
Bontz is offline   Reply With Quote
Old 04-15-2017, 09:19 PM   #5 (permalink)
aglick87's Avatar
14-15 Mileage: 2200
13-14 Mileage: 1500
Riding Since: 1993
I'll check the compression. There's 7500 miles on the machine. To my knowledge, the engine has not been cracked open yet. The other issue that has surfaced recently is hard starting below 15f. That could be linked to the compression as well. It takes strong brisk pulls to get it to fire when really cold out. Never was this way before. Reeds were inspected and all petals are intact.
Old 04-15-2017, 10:20 PM   #6 (permalink)
Current Sled(s): "Agri-vator"
Isn't as simple as a belt thats just to tight is it? Short belt, or a worn one that got adjusted short, dragging hard on the the primary shaft but not contacting the sheaves enough to squeel or creep the sled? (Seen it)
Old 04-15-2017, 11:15 PM   #7 (permalink)
Fun11cat's Avatar
Current Sled(s): 14 XF7000 Ltd, Totaled 1st 7000,10 F8 SP
Previous Sled(s): 05 F6,02 ZL 600SS, 99 ZL 600, 96 Pantera, to many to mention
Favorite Riding Area: Central MN
16-17 Mileage: 960
15-16 Mileage: 849
14-15 Mileage: 660
13-14 Mileage: 1900
Riding Since: 1972
This was my first thought also, try taking the belt off and see if sled still quits when you put it into reverse.
Fun11cat is offline   Reply With Quote
Old 04-16-2017, 12:25 AM   #8 (permalink)
aglick87's Avatar
14-15 Mileage: 2200
13-14 Mileage: 1500
Riding Since: 1993
I'll remove the belt and try it. He did blow a belt on our trip up north. I threw the new one on quick and didn't remove any washers from the secondary bolt. And this problem did seem to start about that time.........this has the potential to be quite embarrassing. I do know the belt is not chirping though. All the ones I've had a touch tight chirped and sounded horrible. But boy do they leave hard/smooth that way.
Old 04-16-2017, 12:44 AM   #9 (permalink)
Be an easy fix though, if that's it.
Old 04-16-2017, 11:52 AM   #10 (permalink)
aglick87's Avatar
14-15 Mileage: 2200
13-14 Mileage: 1500
Riding Since: 1993
Stalls with the belt laying on the seat. Compression test is next. What's a reasonable cranking compression warmed up for the 800 ho? 145 psi?
