'12 800 breaking up at high rpm, then died - HCS Snowmobile Forums
Old 03-19-2017, 08:55 PM   #1 (permalink)
onsno's Avatar
Current Sled(s): '12XF8sp, '06F6, '91EXT530, Can-Am Spyder
Previous Sled(s): F8ext, ZR6, Coug440, Coug500, Jag440, Lynx303
Favorite Riding Area: always willing to chase snow
16-17 Mileage: 4
15-16 Mileage: 450
14-15 Mileage: 2600mi
13-14 Mileage: 2350mi
Riding Since: '74
Default '12 800 breaking up at high rpm, then died
My 2012 xf8 was breaking up at upper rpm.
(9000 miles, riot kit)
After another 30 miles trying to get to the nearest town she gave out altogether, about 2 miles out.
Towed it to town to the very nice Skidoo dealer there and left it as it was 10pm.
Ate a late dinner next door then went out and pulled her over. Fired right up, then quit after twenty seconds.
Hasn't fired since.
Have any of you experienced this with the 800?
Haven't gotten into it, but I'll start with the obvious; plugs, connections, worn wire casings, etc.
I'm thinking coil or stator.
Where would you start?
Any thoughts?
Shut up and ride!
onsno is offline   Reply With Quote
Old 03-19-2017, 09:02 PM   #2 (permalink)
palerider9999's Avatar
Current Sled(s): 2008 Polaris FST & 2005 Polaris 600 Classic
Previous Sled(s): 1996 Polaris 800 Indy Storm-RIP and a Polaris 340 TXL
Location: Central Penna where you have to travel at least 6 hours to ride a snowmobile
Favorite Riding Area: Boonville and Otter Lake
Riding Since: 10
Fuel filter as well.
palerider9999 is offline   Reply With Quote
Old 03-19-2017, 10:02 PM   #3 (permalink)
Current Sled(s): "Agri-vator"
No fuel filter. Does have Smart valves in the tsnk, that are like filters, but I doubt that's it. Could be coil or stator, I've seen 3 or 4 higher mileage ones where the solder comes loose and wir s fall off the stator.
Old 03-20-2017, 12:36 AM   #4 (permalink)
taperk600's Avatar
Current Sled(s): ALMOST sledless ....
Previous Sled(s): too many Cats.......way too many ...
Favorite Riding Area: VT,Tug Hill, Moosehead/Rangley
15-16 Mileage: 286
14-15 Mileage: 1633
13-14 Mileage: 1670
Riding Since: 1975
Sounds a lot like a stator issue
IT FACTOR
Options suck.....at least having to choose which ones to waste money on...........
1999 Chaparral Sunesta 233 LE
Scuba year 'round
Australia and South Pacific Islands
taperk600 is offline   Reply With Quote
Old 03-20-2017, 12:57 AM   #5 (permalink)
favoritos's Avatar
Current Sled(s): 2015 XF 800 137"
Previous Sled(s): F8 EXT, Lots of Crossfires
Favorite Riding Area: U.P.
14-15 Mileage: 2800
13-14 Mileage: 2500
Sounds a lot like stator or ECU.
Check the stator first. They do hiccup as they die.
Been stuck in the woods. I know the drill.
I'm still learning.
favoritos is offline   Reply With Quote
Old 03-20-2017, 04:09 PM   #6 (permalink)
onsno's Avatar
16-17 Mileage: 4
15-16 Mileage: 450
Riding Since: '74
Thanks for the replies guys.
My first instinct trailside was the stator. I will report back with my findings. But it may not be for a while…
Not a fuel delivery issue, in my opinion. That's usually coughing and sneezing. Over my 43 years I've had enough 3 wheelers, quads, or old sleds break down that you can usually tell if it's fuel or spark.
The symptom in this case was identical to when my stator went on my Tecate-4 250 twostroke about fifteen years ago. Breaks up at high rpm, then slowly breaks up at lower rpms, then kaput..
I'll see what I can find.
Thanks again for replies. Fortunately, I also owned the other sled with me, so he rode bitch, at midnight in 0 degrees on our return to camp.
Shut up and ride!
Old 03-20-2017, 06:16 PM   #7 (permalink)
BentBar's Avatar
15-16 Mileage: 1100
14-15 Mileage: 1200
Riding Since: 1973
Might want to check your reeds.
BentBar is offline   Reply With Quote
Old 03-20-2017, 06:22 PM   #8 (permalink)
Not reeds, imo. You could have a reed half missing and a trail sled will still run smooth at wot.
Old 03-20-2017, 07:06 PM   #9 (permalink)
onsno's Avatar
16-17 Mileage: 4
15-16 Mileage: 450
Riding Since: '74
Exactly.
On my '91 EXT, it had a broken reed for a couple years. Blubbery and rough low and lower mid-range, but screamed as always upper mid and top.
It's definitely spark, or lack of.
Having said that, she probably needs a set of reeds, too. Changed out the stock at 4400mi. Boyesens since, but started to smell a little "fuely" down low and at idle. Same as it did when the stock reeds were failing. 9000mi now.
Shut up and ride!
Old 03-21-2017, 10:53 AM   #10 (permalink)
CASEY MR F7's Avatar
Current Sled(s): 03 F7 2012 F800 LXR
Previous Sled(s): 2005 T 660 Touring 99 ZR600
Favorite Riding Area: U P of Michigan
16-17 Mileage: 2005
15-16 Mileage: 1095
14-15 Mileage: 1485
13-14 Mileage: 2555
Riding Since: 1972
Had similar problem on my 12 800. Started breaking up at hi rpms then died. Stator failed. Around 9000 miles on my sled also.
Truck: 05 Silverado 2500 Duramax crew cab 4x4.
Sleds: 03 Fire kitty F7 Sno Pro Sabre Cat graphics
2012 F800 LXR
CASEY MR F7 is offline   Reply With Quote
