Check out our products - HCS Snowmobile Forums
Old 01-03-2011, 12:06 PM   #1 (permalink)
HCS Advertiser
Default Check out our products
betweenthelinesdesigns.com
SLIDEKICKS™
THE NEXT GENERATION OF ICE SCRATCHER DESIGN!
Ice-spray generating device for all makes/models of snowmobiles.
Engineered to reduce engine temperatures and lower drive track friction.
INDUSTRY-EXCLUSIVE DESIGN features both reverse gear capability AND replaceable wear points!
SlidekicksThe Slidekicks kit contains two scratchers, two replaceable wear points, all mounting hardware, and installation instructions..Price: $69.95
Check out our video
Slidekicks™ Super-Single™
check out our video
h
Reverse-compatible ice scratcher…CREATED BY CUSTOMER REQUEST! Combine the dependable performance of the original SLIDEKICKS™ with the unmatched ice-chipping action of the
CARBIDE REPLACEMENT TIPS at half the weight and cost in one package, and you have the ALL-NEW SUPER-SINGLE™!
SLIDEKICKS™ SUPER-SINGLE™ reverse-compatible ice scratcher mounts on the right-hand slide-rail only and creates more-than-ample ice spray so that there is no need for a scratcher on the other side. Intentionally-prescribed right-hand mounting ensures the mounting bolt stays tight.
Tech Note: Newly redesigned carbide-inserts reduce the tendency of the carbide tip to bite into trailer decks so there is less chance of product damage if you forget to stow the SLIDEKICKS™ on the rail when trailering your sled.
Price: $49.95
Quick Clickers™
PATENT # 7726927
THE ORIGINAL, not a cheap copy!
Rapid RPM adjustment mechanisms that directly replaces the stock locking-nuts on SKI-DOO TRA Series centrifugal snowmobile clutch clicker-bolts. This unique device allows for quicker changes of maximum engine speed to OPTIMIZE HORSEPOWER OUTPUT.
Price: $49.95
New video
NEW!
Trac-Link™
TRAC-LINK™ is a new innovation aimed at giving you the ability to adjust traction and balance characteristics of your any make/model snowmobile quickly and easily.TRAC-LINK™ replaces the OEM limiter-straps with an ultra-strong GoodyearŽ strap combined with with the Patent-Pending aluminum adjustment mechanism to give you 3 full inches of infinite adjustment with a simple turn of a 1/2″ or 13mm wrench.TRAC-LINK™ weighs just 15oz including the strap and all necessary hardware and is adaptable to any rear suspension that employs conventional limiter-straps.
Price: $74.95
New video
NEW!
POWAIR™ INTAKE VENTS
  • Low cost design for a cheaper alternative to the competition
  • 100% digestable materials
  • Intake screen for debris protection
  • Plastic construction prohibits icing and sticking
  • Easy hole-saw installation
  • Extremely low cracking pressure ensures the engine does not bog
  • The 3 inch vent has nearly 2x the flow volume as the competition (the 2 inch is comparable)
MSRP
2 inch - $11.95 each
3 inch - $14.95 each
INTRODUCTORY SPECIAL!!!!
$10
Sizes 3 inch Vent $10.00 2 inch Vent $10.00
New video
Trinity Taz is offline   Reply With Quote
Old 02-16-2011, 10:48 AM   #2 (permalink)
HCS Advertiser
Great news, the Slidekicks are now PATENTED!
Old 02-25-2011, 05:07 PM   #3 (permalink)
I just purchased three sets of Slide kicks and one set of carbide tips to try out. Put one set on my F7 yesterday. Haven't tried it yet, but these look and feel beefy. Definitely more heavy duty than I expected. The other sets are for a Polaris xcsp and a zr 800.
zr8rider is offline   Reply With Quote
Old 04-04-2011, 12:15 PM   #4 (permalink)
chris6641's Avatar
Current Sled(s): 2010 Yamaha Nytro XTX
Previous Sled(s): 2000 AC ZL700, 2002 AC ZR 800 CC
Favorite Riding Area: Anywhere with enough snow
10-11 Mileage: 850
Riding Since: 2005
How did these work out for you this year? How were they in their not in use position? did they ever get inthe way or self deploy?
chris6641 is offline   Reply With Quote
Old 04-04-2011, 10:29 PM   #5 (permalink)
I wish I had better news on these to report. They self deployed all the time. And it gets worse. The right side one was in a deployed position on every ride and it always turned a little so it was just sitting there with the tip floating above the snow. The problem is in the not in use position the cable hits the snow and turns. It doesn't matter how tight you can get it, it will hit the snow and turn. I took them off and used grade 8 bolts and loctite to get them tighter than with the stock bolts and the result was the same. The cable is just too low and will hit. I have them mounted in the top hole on the slide rail also. They couldn't be mounted higher. I fought with them all winter and will go back to the spring ones for next year. If anyone has any ideas please let me know what worked for them.
Old 04-11-2011, 11:48 PM   #6 (permalink)
HCS Advertiser
Question for all concerned:
Why are you storing the Slidekicks up on the rails? If the snow is soft, they do not wear and drag is negligible. If the snow is hard, they need to be down. Slidekicks have replaceable tips, are you worried about wearing them out?
Slidekicks do not break in reverse, so why worry about them being deployed?
They stay up fine when loading on a trailer which is when they should.
FYI:
When people install the Slidekicks the first time and neglect to properly torque the mounting bolts, the toothed washer that were intended to create a bond between the rail and the scratcher is ruined once it spins from pull force. The customer then attempts to use the same flat toothed washer again and again, to no avail...the teeth are bent flat and will not bite anymore. A simple replacement of the toothed washer and proper torque the first time will do the trick el permanento.
Old 04-24-2011, 01:56 PM   #7 (permalink)
We store them up because we do a lot of road crossings and unfortunatley mud and snirt in the spring. I bought the hardened tips also. The toothed washer isn't the problem here. The curve part when in the stored position hits the ground. I might try to make a different bracket to raise the height. My friend installed his on the skis on his xcsp and they look like they are going to catch on stuff. He never got to try them. Thanks for the reply.
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
