| Fusion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
Member
ok, I'll admit it - I'm not the most handy with a set of tools but can someone, anyone, share with me how you get to the adjusting bolt to adjust the chain? Something must move out of the way, right???
Thanks, Lou |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Current Sled(s): 06 600 HO Fusion
Previous Sled(s): 07 600 IQ carb
Favorite Riding Area: Northern Lower and UP
10-11 Mileage: 1500
Riding Since: 1969
You need to pull the exhaust to do that, and if you're going into it that far, I'd go ahead and pull the chain case cover to change the oil. While the cover is off adjust the chain so you can see exactly what's going on.
600HO Fusion w/4 valve Air 2.0, HRP spindles, .359 torsion springs, X-Clicks, Retro graphics by ArcticFX, and Tempaflo |
#4 (permalink) |
Current Sled(s): 2005 Polaris Fusion 900,2009 Yamaha Nytro XTX
12-13 Mileage: 1000km
11-12 Mileage: 1500 km
on my 05 900, I usually remove the pipe and can. Pipe removal requires removal of 7 springs: 3 on the y-pipe, 2 on the corner outside, 2 where it meets the can. To remove the muffler there are 2 nuts that have to come off. Then just pull out the pipe (also remove exhaust probe: either 9/16 or 14mm wrench to remove) and pull out the muffler. Can removal/install can be a pain; it's much easier if the can-side side console screw is out, then just pop out bottom of console (much easier this way).
To adjust, back off the jam nut, turn adjuster bolt by hand until tight (you might have to rotate your track a little to remove the slack), back off 1/4 turn and tighten. Put can/pipe back and you're done. To remove the pipe springs, I built a spring removal tool out of a coat hanger. Suspect the 06 is pretty much the same. You might be able to get at the adjuster bolt without removing can but I do mine at maintenance time so can is off. |
#6 (permalink) |
michahicks is right about chaincase oil but I would avoid the cover removal. First - you can drain the chaincase oil with a hex head drain screw on the bottom, second - many of these leak despite the recall and require silicone in addition to the gasket that is there (maybe this is only an 05 issue), third - it's no problem to tighten if you do what I said above.
On the other hand if you've never had the chaincase cover off and don't know where your sled has been it might be better to pull the chaincase cover. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
