| Fusion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
Current Sled(s): 06 Dragon 600HO, 08 RR
Previous Sled(s): 03 Edge X 700
Favorite Riding Area: NH, ME
10-11 Mileage: Not enough
5000 miles and I think its time...getting a DET light at WOT, gonna check the boots and hate putting the air box back in.
What are the steps to gutting the air box? is it just spliting tabs to seperate and removing shelves or is there more? I also have the ATACC installed Thanks
BATTEN ELECTRIC Your complete solution to a wired world |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Favorite Riding Area: Vilas Co. Wisconsin
If you are going to use the SLP airhorn kit, do what you mentioned plus you have to cut off the top raised portion for the plate to sit flat. It's the kinda triangular shaped area. Get the box very warm, heat the tabs with a hairdryer. Use very small screwdrivers and pics, work carefully and it will come apart. Clean it well on the seam and after putting it back together I like to run a bead of silicone around the seam to seal it from air leaks and belt dust. Duct tape works equally as well.
http://www.ilsnowmobile.com/Clubs/ivwsc.htm 2012 gearing chart 2http://s234.photobucket.com/albums/ee316/kawidave1/?action=view¤t=switchbackgears2.jpg |
#3 (permalink) | |
#4 (permalink) |
Current Sled(s): 06 Fusion 600
Favorite Riding Area: Wisconsin
12-13 Mileage: 850
11-12 Mileage: 1100
10-11 Mileage: 2150
Riding Since: 1970
I split mine and gutted it but I didn't do the SLP kit Just glued the foam chimney to the hood and let er go.
#5 (permalink) |
Yes it can be done without the SLP kit, do as Chief says.
#6 (permalink) |
Would I benefit from cutting the top to match the indent made into the foam from the hood?
#7 (permalink) |
12-13 Mileage: 850
11-12 Mileage: 1100
10-11 Mileage: 2150
Riding Since: 1970
I think you will see once you get it split, the top of the box has a plastic piece that once removed makes the hole pretty large - which I think is sufficient for the 600.
#8 (permalink) |
I like the SLP kit for the better seal you get. It has a funnel shaped horn with foam around it's outside that gets plastic riveted {push darts} to the hood plenum. It then fits into the airbox top.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
