Polaris sled/watercraft motor question. - HCS Snowmobile Forums
XCR This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 03-07-2012, 10:32 AM   #1 (permalink)
warpspeedxcr's Avatar
Current Sled(s): 98 Indy 654
Previous Sled(s): XCR 800-1100 XC700
Favorite Riding Area: MN
Riding Since: 1972
Default Polaris sled/watercraft motor question.
I know there is plenty of info out there regarding the watercraft triple conversion, using 700/800 jugs for a 1050 or 1200 motor.
Has anybody looked into something smaller, based off the 440/500/600 smallblock jugs? Just curious. It seems to me something like this could be much lighter, more compact, and still toss up some pretty respectable HP numbers.
warpspeedxcr is offline   Reply With Quote
Old 03-07-2012, 10:46 AM   #2 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
Years ago my buddy tried building a 780 piston port triple using the watercraft rods only to end up in failure. Motors would produce close to 180 hp before twisting the crank. Tried a 150 hp trail version of it in a 95 xcr but never got more than a couple hundred miles on the motor before the crank failed.
Old 03-07-2012, 11:09 AM   #3 (permalink)
2fastxcr's Avatar
Current Sled(s): Outlaw XCR 1650cc triple TURBO & 2001 XCR 800
Previous Sled(s): Ultra & Xcr Sp
Favorite Riding Area: 500ft,660ft,&1000ft
Riding Since: 1988
regardless of cylinder you use the dimensions of the motor from pto to mag is going to be the same.the watercraft cases are big.add the stator housing you need on top of that with the pullys and they are 4-6"s wider than an xcr8.the watercraft triple cranks however if using the xc 800 70mm stroke or the xc 700 68mm stroke are very beefy cranks.they make the xcr 8's crank look like a twig.with that being said now you could use smaller jugs on the cases if the patterns will bolt up and bore and stroke combos are available.you could always have brad make you a custom crank of the stroke you want.on SW forum there was a thread were a guy weighted his 1200cc watercraft v.s ultra 680.there was only 15lbs difference in the motors weight wise and the 1200 is almost double the displacement.
2fastxcr is offline   Reply With Quote
Old 03-07-2012, 06:52 PM   #4 (permalink)
Riding Since: 1972
Interesting. I would have thought the weight difference would be more like 30. Well, if the motor can't me made lighter or smaller than a similar displacement fuji motor not much sense in whipping up a "900".
Old 03-07-2012, 07:02 PM   #5 (permalink)
ivar's Avatar
IIRC, weight difference between a smallblock 600 and a BB 700 sled was around 9lbs, all else being equal.
I'm pretty sure it could be done, cutting/welding 2 small block cases into a triple. But would be pretty time consuming and expensive. (I recall 10-12 years ago, there were such motors made from Rotax 670's..?)
So using WC cases is an easier and cheaper solution - and more potential for big HP
(But then, a small block triple, using 660 or 685 jugs, done by e.g Rugland should be a ripper )
2015 600 Adventure (int'l)
02 XC800 / 00 XCR800 - Pro-X rear skid
99 XC700SP/97 XLT SKS
RIP: 800SBA, 02 XC800, 99 SKS700
ivar is online now   Reply With Quote
Old 03-07-2012, 08:16 PM   #6 (permalink)
Super Moderator
fastsleddr's Avatar
Current Sled(s): 15 AXYS 800/ 09 shift 797/ 06 fuse 600
Previous Sled(s): Lots of everything
Favorite Riding Area: the bedroom YEEHAW!!
16-17 Mileage: 2860+
15-16 Mileage: 2750+
14-15 Mileage: 3408
13-14 Mileage: 2515+
Riding Since: 1968
Hmmm!!
fastsleddr is offline   Reply With Quote
