Polaris primary clutch interchangability. - HCS Snowmobile Forums
XCR This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
  • 1 Post By patrioticinnovations
Old 06-13-2017, 10:31 AM   #1 (permalink)
warpspeedxcr's Avatar
Current Sled(s): 98 Indy 654
Previous Sled(s): XCR 800-1100 XC700
Favorite Riding Area: MN
Riding Since: 1972
Default Polaris primary clutch interchangability.
So...I am looking for a used primary clutch for an Ultra, and I plan to use a 3211080 belt. What should I be looking for? Pretty sure I want something OTHER than an ultra primary, they didn't use the wider belts, right?
I also want to make sure I put a primary on it that will still use a standard clutch puller bolt for removal.
warpspeedxcr is offline   Reply With Quote
Old 06-14-2017, 12:12 AM   #2 (permalink)
Any of the newer clutches will work 01 to about 05. You wont be able to use the old puller that was used for all of the early indys
tripple mike is offline   Reply With Quote
Old 06-14-2017, 07:26 AM   #3 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
I machined a clutch for my 1989 650 Pro-stock sled to use a 1075 wide belt.
Old 06-14-2017, 09:17 AM   #4 (permalink)
patrioticinnovations's Avatar
Current Sled(s): 2015 AXYS Pr-S SB Ann 800, 2000 XCR 800
Previous Sled(s): 2003 XCR 1100, 98 XCR racer, 2005 Redline Revolt 800.
16-17 Mileage: 1310
15-16 Mileage: 930
14-15 Mileage: 1280+
Riding Since: 1982
I see no reason why you couldn't just reshim the spider on an Ultra primary for the wider belt Jeff.
I happen to have a nearly new primary for a 98 XCR SP if you can use it.
231680ultra likes this.
Old 06-19-2017, 09:47 AM   #5 (permalink)
Riding Since: 1972
Phil, shoot me a price for that clutch, let's see if it's in the budget. Thanks!
Old 06-19-2017, 12:38 PM   #6 (permalink)
16-17 Mileage: 1310
15-16 Mileage: 930
Riding Since: 1982
I actually have three clutches available.
The one that came from the 98 XCR triple triple is slightly damaged. The bolt broke and the clutch came off and hit the secondary. It was sold by a local sled part supplier as the correct one for that sled but doesn't appear to have the correct depth of crank engagement. I just checked it against a brand new P-85 I have as a spare for my XCR800.
The XCR800 clutch goes on the stub shaft I have as a disassembly holder to a depth of 32 mm as shown in the pics attached. This clutch only goes on to a depth of 37 mm from the face of the belt surface of the inner sheave to my workbench where the stub is mounted. A difference of about 5 mm or .2".
ID:	1853345   Click image for larger version
Old 06-19-2017, 12:44 PM   #7 (permalink)
16-17 Mileage: 1310
15-16 Mileage: 930
Riding Since: 1982
I have a different older P-85 without a date on it that does go to the proper depth of 32 mm. It's in GC. See part# in pic. I'd sell it for $150 plus shipping.
Be very careful buying clutches without knowing the depth of fit on the crank.
ID:	1853361   Click image for larger version
Old 06-19-2017, 01:00 PM   #8 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
August 7th. 1992.
Old 06-19-2017, 02:53 PM   #9 (permalink)
16-17 Mileage: 1310
15-16 Mileage: 930
Riding Since: 1982
Originally Posted by XCR1250 View Post
August 7th. 1992.
Thanks Don. Might be one from a 650 Indy or a 93 750 Storm. No weights in it, so didn't check belt width setup. Has narrow rollers.
