Headlights Not Working - HCS Snowmobile Forums
Rush/Switchback (Pro-Ride Chassis) This is a brand-specific forum and a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-15-2013, 05:09 PM   #1 (permalink)
GreenState's Avatar
Current Sled(s): '14 Pro RMK 800, '11 Rush 800 Pro R
Riding Since: '89
Default Headlights Not Working
Fired up the 800 Rush for the season the other day and noticed that the headlight wasn't bright, just barely amber. It was fine last season. I thought that it might be the low battery so I charged it up. The charger said 'sulfated/weak' when it was finished, but it has enough juice to fire the sled right up when you turn the key.
Hooked the charged battery up and it still wasn't bright. I pulled the hood/headlight off the 600 Rush and tried it on the 800. Same result. Everything else seems to function as it should. Flicking between high and low beam changes between bulb filaments, but that 's it.
Everything looks to be hooked up and I can't find any frayed wires or such.
Any ideas?
GreenState is offline   Reply With Quote
Old 12-15-2013, 05:12 PM   #2 (permalink)
rabbi's Avatar
Current Sled(s): 2016 600 Switcback Adventure
Previous Sled(s): Lots of Polaris'
Favorite Riding Area: Wi northwoods
15-16 Mileage: 880
14-15 Mileage: 650
13-14 Mileage: 2550
Riding Since: 1979
If were an older Edge chassis, I would blame the regulator.
Any accessories added since last year?
RCA or 12V plug in?
Winter. Bring it on!
rabbi is offline   Reply With Quote
Old 12-15-2013, 05:16 PM   #3 (permalink)
GreenState's Avatar
Riding Since: '89
Nothing done/added to the sled over the summer.
Old 12-15-2013, 05:49 PM   #4 (permalink)
GreenState's Avatar
Riding Since: '89
Just tried the voltage regulator out of the 600 in the 800, lights are still dim.
Old 12-15-2013, 05:56 PM   #5 (permalink)
KSZRT's Avatar
Current Sled(s): 2012 TZ1 Turbo LXR
Previous Sled(s): 07 Jag,2002 ZL 800 99 Zl 600, 96 ZRT 800, 91 WildCat 700+ 7
Favorite Riding Area: NEK
14-15 Mileage: 832
13-14 Mileage: 2168
Riding Since: 1978
I am thinking a short somewhere, like a critter go in there??? With the sled running what is the battery voltage? Also check your grounds. I am not a Polaris guy so I don't know if your head lights are AC or DC.
Sent from Snowmobile.com App
Enjoy it while you can
KSZRT is offline   Reply With Quote
Old 12-15-2013, 06:14 PM   #6 (permalink)
Current Sled(s): 17' Rush Pro X 800
Previous Sled(s): 13/09 poo switch 800,01 mxz 800x
Favorite Riding Area: minnesota
I'm thinking dc, did you check voltage at the hood plugin? Do your hand warmers heat up? Might wanna check voltage in a few places but I'm sure if the stator wasn't throwing enough voltage it would throw a code. Take the battery out and see what happens with voltage. I'm pretty sure the battery does nothing but turn over the starter on these things same as my 09.
shabs1986 is offline   Reply With Quote
Old 12-15-2013, 09:18 PM   #7 (permalink)
Newbie
Current Sled(s): 2013 XF 800 High Country LTD
Previous Sled(s): 2012 Switchback 800 Pro-R Retro
I had a left Grip heater go out - and at the same time my buddy noticed the lights weren't on much - similar to your pictures. I pulled one of the wires out from under the grip (bad solder joint) and my lights came back on. In short I would bet it's a short! If your grip heater isn't working I'd start there.....
mick49157 is offline   Reply With Quote
Old 12-15-2013, 10:50 PM   #8 (permalink)
YZF
YZF's Avatar
Current Sled(s): Yamaha "Mountain" BRAVO
Previous Sled(s): 2012 Polaris Switchback thingy
Favorite Riding Area: in the snow
lights should be ac looks like a bad ground somewhere. find the main chasis ground and check it and make sure it is not loose or corroded. check the battery terminals for corrosion too. not likely a short
There is a message in my Cheerios is says "OOOOOOOOOO"
YZF is offline   Reply With Quote
Old 12-17-2013, 12:17 AM   #9 (permalink)
GreenState's Avatar
Riding Since: '89
Well, we've got a winner, @mick49157:
Handwarmers on: Lights go out. Handwarmers off: Lights go on.
As soon as I removed the brake lever/switch assembly the wire fell out of the grip. I'm thinking I damaged it when I rotated the brake lever at some point, there isn't much wiggle room for the heater wire in the clamp.
All I need is one new heating element and I'm good to go. Thanks for the help guys!
Old 12-17-2013, 09:26 AM   #10 (permalink)
z-driver's Avatar
Current Sled(s): 2013 SB ES 600
Previous Sled(s): Lotsa Poo's,2010 rush 600
Favorite Riding Area: In My Shop
14-15 Mileage: 306 lol
13-14 Mileage: 2300
Riding Since: 1968
Wow, note to self, be careful when rotating brake
Sent from a pay phone somewhere
z-driver is offline   Reply With Quote
