squish on stock 800 - HCS Snowmobile Forums
Rush/Switchback (Pro-Ride Chassis) This is a brand-specific forum and a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 10-29-2013, 10:34 PM   #1 (permalink)
ottawaair's Avatar
Current Sled(s): 2012 Switchback Pro R, srx 700 grass dragger
Previous Sled(s): All Yamahas
Favorite Riding Area: northern michigan
13-14 Mileage: 450 in Dec
Riding Since: 1992
Default squish on stock 800
Wondering if anybody has checked the squish on a stock motor.
Just curious what it is.
If you're gonna be dumb, you better be tough.
ottawaair is offline   Reply With Quote
Old 10-30-2013, 07:21 AM   #2 (permalink)
213921's Avatar
Favorite Riding Area: Munising, Michigan
Riding Since: 1984
Grab some solder, a spark plug wrench and a set of calipers and let us know.
"I'm not useless, I can still be used as a bad example"
2013 Polaris Switchback 600 ProR
213921 is offline   Reply With Quote
Old 10-30-2013, 11:21 PM   #3 (permalink)
ottawaair's Avatar
Riding Since: 1992
Yea. I did. Just wondering if anybody else had checked thiers.
Thanks for letting me know just how easy it is tho.
Old 10-30-2013, 11:57 PM   #4 (permalink)
650brad's Avatar
Current Sled(s): 2013 Switchback 800 Pro R LE, '08 F6 Sno Pro
Favorite Riding Area: Anywhere with snow
14-15 Mileage: 665
What did yours measure?
650brad is offline   Reply With Quote
Old 10-31-2013, 08:03 AM   #5 (permalink)
ottawaair's Avatar
Riding Since: 1992
.074". About. .020" too much. IMO.
Wondering if cutting head would cause detonation issues.
Old 10-31-2013, 10:45 AM   #6 (permalink)
213921's Avatar
Riding Since: 1984
Mind you that there are allot of variables that need to be taken into account when setting squish. Timing, Fuel, Pipe length, squish angle, piston dome shape, and port timing are all factors that have to work together for a completely effecient engine package. Squish is just about the lowest influence on it.
I have helped build allot of different 2-stroke engines and allot of big tripple Imp Stock sled engines, and have seen enignes with less than .01" squish and engines with .100" of squish. While it is an important area to adress, on a stock sled engine that is setup to run on pump gas with a factory exhaust on it, you really doing nothing more than emptying your wallet.
Now move to race gas, put a good pipe on it, and re-chamber the head (more angle with less squish) you can usually get more torque out of the motor and maybe a couple of HP, but you are also setting it up for less margin of error. This is a little safer on a engine with a DET sensosr, but it isnt a fail safe.
If you are wanting to deck the head, I would take the time to find the thickest jug gasket (either from the OEM or from Cometic) or look into a shim (Cometic can cut you a copper shim that matches a jug gasket), and deck the cylinders up about .05" (1.5mm) and then deck the head the same amout your raised the cylinders. This will increase port timing yet leave you with relatively the same runnign compression you had.
Old 10-31-2013, 10:17 PM   #7 (permalink)
Current Sled(s): '11 IQ Turbo, '15 Axys 800
Previous Sled(s): '12 Pro-R 8, '08 IQ 8, '02 Pro-X
Favorite Riding Area: Where the snow is....
16-17 Mileage: 2050
15-16 Mileage: 2150
14-15 Mileage: 4050
13-14 Mileage: 6350
Riding Since: 1976
.074" seems like a lot, almost so much that it doesn't seem reasonable. Sure the solder landed in the right spot? Its tough to see if the solder is right over the wrist pin and with the way these pistons rock, missing the location would change the number dramatically.
orville-x is offline   Reply With Quote
Old 11-01-2013, 07:16 AM   #8 (permalink)
ottawaair's Avatar
Riding Since: 1992
It was in the right spot. I measured both cylinders, both sides of pistons.
I've done it many times before.
As far as the piston rock, my sled has RK-Tek direct replacement pistons. shouldn't be rocking very much.
That is why i wanted to know if anybody measured a stock motor.
I neglected to check mine before the pistons went in last season.
I realize there is a lot more at play than just the squish number, but as orville said, it seems rather loose.
I just wondered if this was what polaris did to protect themselves from detonation issues and crappy gas.
Curious what cutting .030" or so would do for it.
Old 11-01-2013, 01:11 PM   #9 (permalink)
213921's Avatar
Riding Since: 1984
Performance wise, you would probably not even notice a difference. All you would do is make it more suseptable to detonation
But again, the squish angle (the angle between the top of the piston and the angle of the sqush bank on the head) has just as much to do with it as the "squish" itself
More squish angle (flatter pistons or a steeper angle of the head) will let you get away with less "squish". Pistons with more dome and shallower head angles will need more "squish"
This is the kind of thing that you can mess around with and you "might" gain enough power to actually tell the difference (if any), but take it .005" too far and you can run into detonation problems very quickly.
If the goal is to try and get some more power, this isn't the way to do it. Two Stroke compression is a completely different game that how tight the combustion chamber is to the piston. 60% of your compression comes from the pipe
Old 11-01-2013, 01:29 PM   #10 (permalink)
just-pinch-it's Avatar
Current Sled(s): Waiting...
Previous Sled(s): Pro-R SB 800, 700 dragon, Pro-XR, XCR, Storm, XLT, Trail
Favorite Riding Area: MI
Riding Since: 86
Dis you get the correct replacement pistons. I'm sure RKtec could tellyou what it should be.
just-pinch-it is offline   Reply With Quote
