Erlandson Clutch Kit - HCS Snowmobile Forums
Rush/Switchback (Pro-Ride Chassis) This is a brand-specific forum and a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 11-25-2012, 01:44 AM   #1 (permalink)
tweetz190's Avatar
Current Sled(s): 2013 Polaris Rush 800 Pro-R
Previous Sled(s): 600Rush,ZR600,2-F7s,PRO-X,ZR700
Favorite Riding Area: Hurley w/ the Girlies
Riding Since: 2000
Default Erlandson Clutch Kit
Sled is 2012 600 Rush Pro-R. Bought Erlandson Pro series clutch kit that will be installed this week. Ride 85% trails/ditches and 15% lakes & off trail. Not overly concerned with top end but still would like to hit 100 going across the lakes. Everything else is stock, anyone have experience with this as far as any need to change from stock gearing? Not overly concerned with top end but still would like to hit 100 going across the lakes.
Thanks in advance
tweetz190 is offline   Reply With Quote
Old 11-26-2012, 08:39 PM   #2 (permalink)
Current Sled(s): 2012 Polaris 600 Rush Pro R
Riding Since: 2011
I have no experience with a clutch kit but I am very curious to hear about yours once you get to test it out.
SnarkyBasturd is offline   Reply With Quote
Old 11-26-2012, 10:19 PM   #3 (permalink)
tweetz190's Avatar
Riding Since: 2000
Should have sled back by weekend. Will post info once we can get some miles on!
Sent from my iPhone using Snowmobile.com Free App
Old 12-14-2012, 01:07 AM   #4 (permalink)
tweetz190's Avatar
Riding Since: 2000
Just got back from 15 mile test run after installing EPI clutch kit finally. Can vouch for 600 pro r "pro series" clutch kit. Definitive difference in the pull if the sled, got up to 86 in the ditch very quickly and let off only due to rough conditions. If you're debating a clutch kit I would buy EPI hands down, new helix, weights, and both springs. No guess work, just install and drive the hell out of it!!
Old 12-14-2012, 09:57 AM   #5 (permalink)
sleepybrew's Avatar
Favorite Riding Area: salisbury, speculator, cny
you are lucky to have a "kit" work perfect for you. i have found that each sled is different and needs to be tuned individually. i normally aim for the target rpm and ability to hold it. many fine tuning tricks with alignment, belt deflection, ski alignment, clean clutches, belt condition, track tension and alignment. if you add studs that will cause a need for a clutch change. glad it worked for you.
sleepybrew is offline   Reply With Quote
Old 12-14-2012, 11:13 AM   #6 (permalink)
Current Sled(s): Pro-R 800
Previous Sled(s): many
Favorite Riding Area: NEK
13-14 Mileage: 75
Riding Since: 1972
What weights came with your kit ..thanks
Originally Posted by tweetz190 View Post
Just got back from 15 mile test run after installing EPI clutch kit finally. Can vouch for 600 pro r "pro series" clutch kit. Definitive difference in the pull if the sled, got up to 86 in the ditch very quickly and let off only due to rough conditions. If you're debating a clutch kit I would buy EPI hands down, new helix, weights, and both springs. No gu ess work, just install and drive the hell out of it!!
mocha is offline   Reply With Quote
Old 12-14-2012, 11:24 AM   #7 (permalink)
tweetz190's Avatar
Riding Since: 2000
I agree completely! I had done some research and talked to a friend that's had several from them and he had very good luck. I also had dealer do preseason checkup and they adjusted track tension and belt deflection among other normal items so I'm sure that helped also making sure those items were all inline. I had debated doing gearing also, but after test run, gonna leave everything else stock at this point. Still need to get out on hard packed trail but if it hauls @$$ like it did in a crappy ditch should really rock on the trail! Alot of guys talked about 68 gram weights and that's what the kit came with so I was happy to hear that from other guys who do more "piece by piece tuning". I just dont have the tools or time to do the proper testing so kit worked well in my case.
Old 12-14-2012, 12:07 PM   #8 (permalink)
prose's Avatar
Current Sled(s): 2017 Axys 800 Pro S Rush
Favorite Riding Area: Wherever she let's me
Are you sure they are 68g weights ? That seems like too much to me.........64g were even too much sometimes & my 600's were strong...........what rpm are you pulling ?
prose is offline   Reply With Quote
Old 12-14-2012, 12:31 PM   #9 (permalink)
tweetz190's Avatar
Riding Since: 2000
Pretty sure they were 68g but may have been 66s.... Keep in mind the other clutching components play a part also in the equation. Was in kinda rough ditch so didn't get good luck at rpm but want to say around 8100 and i didn't get to open it up all the way and not for long stretches where a guy can really see whats going on
Old 12-14-2012, 12:32 PM   #10 (permalink)
tweetz190's Avatar
Riding Since: 2000
EPI Performance ATV and Snowmobile Clutch Kits: Polaris • 600 Rush 10 • Pro-Series Clutch Kit
