Arctic Cat issues snowmobile recall - Page 4 - HCS Snowmobile Forums
Krom's Korner A place for powersports recalls. GDF rules apply Posts MUST be extremely brand biased!
Like Tree10Likes
Old 06-09-2017, 07:24 PM   #31 (permalink)
mnstang's Avatar
Current Sled(s): SnoPro 500, z1 turbo, zr900
Previous Sled(s): all cats
Favorite Riding Area: Northern MN
Originally Posted by mnstang View Post
Wow.
Recalls aren't bad. Failures are. I deal with recalls every day, it's just a company fixing a known issue.
But you're right, one clutch failure with no injury and the manufacturer proactively issuing a recall is just as bad as multiple people dying, countless vehicles burning to the ground before the manufacturer reluctantly is basically forced to do something about the issue. One recall each right so it's the same thing?? Pretty dumb thought process.
mnstang is online now   Reply With Quote
Old 06-09-2017, 11:57 PM   #32 (permalink)
Current Sled(s): 17' XF8 CC LMT 10'SP500
Previous Sled(s): 13' F800 RR 2006 CF 700SP
Favorite Riding Area: Out West
Riding Since: 1976
No doubt......Bontz...you are smarter than that.
Do not post much...read most, and Bontz, a former Cat guy, get's it.....not this time.
Firstdoo is offline   Reply With Quote
Old 06-12-2017, 09:11 AM   #33 (permalink)
fortune46x's Avatar
Current Sled(s): 2016 Zr8000 Limited, 2014 zr6000r
Previous Sled(s): 14 xf7000 limited, 12 F800,Sp500 , F7
The recall is due to the bearing in the primary seizing up and causing sheeves to get hot and potentially blow apart - its on the new "self adjusting" deflection primary.
I wouldn't say xx amount of years and still can't get it right because my 2016 works damn good with a team primary compared to my 2012 that had to be replaced due to incorrect clearances.
fortune46x is offline   Reply With Quote
Old 06-13-2017, 08:01 AM   #34 (permalink)
Current Sled(s): 15 800 Pro S, 17 800 Assault
Previous Sled(s): 12 800 Pro R,09 Dragon, 00 + 03 XCR
Favorite Riding Area: Central Ontario
16-17 Mileage: 650
15-16 Mileage: 500
14-15 Mileage: 775
13-14 Mileage: 700
Originally Posted by krom View Post
it was up when I got home.
Team industries at their finest...
I'm guessing you are working 24-7 on Cat repairs, no time to mindlessly surf the net for crap
tripleflipper is offline   Reply With Quote
Old 06-18-2017, 09:08 PM   #35 (permalink)
Boggy's Avatar
Current Sled(s): 2016 pro x switch
Previous Sled(s): 2015 pro x dragon 02 prox 800 boa ski
Favorite Riding Area: Off trail
16-17 Mileage: 600
15-16 Mileage: 1200
14-15 Mileage: 10000
13-14 Mileage: 600
Riding Since: 1978
So some guy has a gas can right on top of the exhaust of his razor on a sweltering hot day. The can explodes and kills the occupant of the machine.
Why would the mfg not hold off and question every case then. I am sure every time someone dies on any type of vehicle the lawyers and ambulance chasers are going to go after the guy with the fattest wallet.
Boggy is offline   Reply With Quote
Old 06-18-2017, 09:36 PM   #36 (permalink)
That is not even close to what happened. There were thousands of issues. That is why it cost Polaris an absolute shit ton of money. And their investors even more
2lapsdown is offline   Reply With Quote
Old 06-19-2017, 08:39 AM   #37 (permalink)
fortune46x's Avatar
When the fires are becoming an epidemic and the manufacturer was turning a blind eye to it is what the problem is until the CSPC stepped in and forced them (see the stop sale/ride of all 2016 turbos the morning of their dealer show to reveal the 2017 models - they didn't even release the 2017 turbo car that day because they knew they had an issue that was still unresolved). Then they stuck the consumer that invested in that $26k pile because if the consumer called the dealer about the recall the dealer was to report their vin number if they continued to ride it to exit any responsibility they (Polaris) had.
Ive seen Cats, Yamahas, and Canams go up in flames for the brilliance of having the fuel cans in the back - Thats not the issue with the 200k+ unit recall that poo has issued.
The largest issue was on the 900, 1000 s , 900/1000 fullsize cars were that some brilliant engineer put the fuel tank vent line above the header. Then on the turbo Polaris went cheap on an casting that an oil fitting went into - it cracks and sprays oil all over the header. These things run red hot headers from the factory thanks to the epa and the minute fuel slops out of the vent it ignites the vapor in the tank thats under the occupant. Or when the turbo casting breaks it sprays all over the header and the occupant can't see they're on fire in most cases until its too late.
Old 06-19-2017, 06:49 PM   #38 (permalink)
^this
Old 06-20-2017, 08:17 AM   #39 (permalink)
Goin' For Snow's Avatar
Current Sled(s): 15 XF8 CC (hers) 15 XF8 LE Green(me)
Previous Sled(s): M's, Xf's, F's in the shed
Favorite Riding Area: Staples MN,Cooke,Big Horns,Tog
16-17 Mileage: 330
15-16 Mileage: 47
14-15 Mileage: 870
13-14 Mileage: 2200
Riding Since: 1981
Originally Posted by 2lapsdown View Post
^this
he needs to double space and take out any words that longer than 4 letters for some on this thread to understand.
Slow down the f-ing clock....
Goin' For Snow is offline   Reply With Quote
