Parting out a 2002 Polaris Pro-X 600 - HCS Snowmobile Forums
Parted Out Sleds Please post a price with all classified ads. This is required for posting on the classified forums as of 5/26/14. Any posts without a price will be deleted after a PM is sent to the poster by the site staff, stating the need for prices and no action by the Poster is taken.
Old 04-03-2011, 09:56 PM   #1 (permalink)
catkillerppx's Avatar
Current Sled(s): Indy
Previous Sled(s): Far too many
Favorite Riding Area: Locally
15-16 Mileage: 500
14-15 Mileage: 500
13-14 Mileage: 600
Riding Since: 1999
Default Parting out a 2002 Polaris Pro-X 600
I am parting out a 2002 Polaris Pro-X 600, all parts are for sale, came from a good running sled. All parts for sale are listed below, but if you don’t want to read through it all message me with any inquiry!
Under the hood:
-Motor: 2002 Liberty 600 V.E.S. 123/125 compression, 8000 miles, but only 1700 on complete fresh rebuild. Runs great, only ‘issue’ is one of the exhaust valve cover bolts stripped, so I replaced it with a longer 10mm bolt, and put a nut on the other side. It comes with carburetors (38mm Rack’s), Y-pipe, recoil, primary clutch (120-310 spring, 10-58 weights), motor straps, CDI & wiring harness, ignition, heat sensor, outer coil and the oil pump and fuel pump.
-Secondary clutch: Polaris roller (Silver/blue spring, R11 helix) good condition.
-Airbox: good condition comes with boots, foam and inner shelf.
-Oil reservoir: has the storage box in it, fuel pump mounting bracket, cap is not stripped unlike most.
-Pipe: good condition, pump has a little bit of surface rust, and the heat shield has 1 ding in it.
-Sno Stuff Rumble Pack exhaust can (1 season old) & stock exhaust can.
-Chaincase: everything is in good condition, 24/41 gearing.
-Brake: Hayes brakes, rotor is in good condition, pads are in good condition and brake line is braided steel.
-All coolant hoses are in good condition, come with coolant bottle.
-Other misc parts (belt guard, speedometer drive housing, shock tower cover (1), motor mounts (3) and the jackshaft, or anything else you might need).
Chassis/suspension & misc parts:
-Front shocks: Ryde-FX non-clicker, compression adjustable, shocks still have a good charge, but a inspection couldn’t hurt them, Red springs, minimal
surface rust.
-Radius rods: All straight, 2 lowers, 2 uppers, all come with tie-rod ends, 2 steering arms (come with steering brackets and boots), minimal surface rust.
-Trailing arms: both are good and straight, paint has chipped off at front and a little on top, come with bolts & bushings, sway bar blocks and spindles.
Both LH & RH available.
-Sway bar: black and in good condition.
-Front bumper Y-brace: good condition, no dents or bends, comes with hood flares:
-Front bumper: trail version bumper (black) & Pro-XR race front bumper (painted black, but paint is chipping).
-Holeshot skid-plate: blue, in good condition, comes with mounting hardware, will fit Pro-X/XcSp.
-Skis: black in color, saddle less design, come with black OR red loops (paint is chipping red loops), mounting hardware and spindle stoppers, great
condition, NO carbides.
-Rear bumper covers: black, in good condition.
-Tunnel supports: silver in color, good condition.
-Rear suspension: Ryde-FX reservoir shocks (compression adjustable), they are a little soft, but spring back up to where they should be), main springs
are stock .359” square wire, all arms and everything are good, no cracks or bends. A little bit of surface rust in places, some of the idler wheel bearings
need replacing, 4-wheel rear axle.
-Rear Bumper: silver, good condition.
-Seat: foam is good, plastic ‘body’ is also good, all lights work, lens is perfect, but the cover has a few little holes, and 1 of the seams is split in 2
places.
-Gas tank: Black, 45 litre capacity, brand new gas cap (has gauge), comes with fuel sending line.
-Gas tank shroud: Black in color, a few of the tabs are broken off, otherwise no cracks, or damage, has hole for heated visor, key switch, hand warmer
controls.
-Handlebar riser block, pivoting style, stock Pro-X 3.75” block, good condition.
-ProTaper SE (ATV LOW) handlebars: great condition, come with Scott grips, throttle block with lever and bar pad
-Brake master cylinder: brake control that mounts to handlebar, great condition, brake lever and light switch/wire come with it.
-Hood: Red in color, great condition, only has 1 little paint chip the size of a beer bottle cap. Has custom made decal kit, comes with headlight (works
perfect, Xenon bulbs) and screens (black plastic’s).
-Speedometer & Tachometer: both work fine, solid white 5” gauges, odometer has 8100 miles on it. 6 pulse tachometer.
-Driveshaft (2): both are in good condition & come with bearings, both has 2-drivers (good condition), 1 is off this Pro-X, the other is off a 2003 Polaris
XcSp.
-Belly pan: Red in color great condition other than 1 patch that is ‘scuffed’ about the size of a VHS movie.
-Chassis: silver in color, comes with tunnel, bulkhead, shock tower cross brace, foot rests, and all heat exchangers unless sold, it comes with
ownership.
Anything else I missed, or you are looking for, message/PM me! Make an offer on anything.
Note: windshield is 12” red chrome, but is damaged (hole in side), I am keeping the track, belts, storage bag on the belt guard and snowflap.
2009 Polaris IQ 600 Dragon SP: Sold
2004 Polaris Pro-X 700: Sold
2002 Ski-Doo MxzX 440: Parted Out
2005 Polaris XcSp 600: Parted Out
2003 Polaris Pro-X 600: Sold
2001 Polaris XcSp 700: Sold
2001 Polaris XcSp 600: Sold
2001 Polaris XcSp 500: Sold
2002 Polaris XcSp 500: Sold
1998 Polaris Indy 500: Sold
1993 Polaris Indy 650: Parted Out
1991 Polaris Indy 650: Parted Out
1991 Polaris Indy Sport 440: Backup Sled
catkillerppx is offline   Reply With Quote
Old 04-04-2011, 09:38 PM   #2 (permalink)
Current Sled(s): 02 PRO X 440/800BB, wifes 02 500xc
Previous Sled(s): 97 xcr 600 se, 02 edge xc 800 RIP
Favorite Riding Area: Wisconsin, soon to be Michigan
Riding Since: 80's
how much for the sway bar?
NOREDLINE is offline   Reply With Quote
Old 11-16-2011, 04:41 PM   #3 (permalink)
Newbie
I am very interested in the chain case. I am in need of one badly. What do you want for it?
timmy8997 is offline   Reply With Quote
Old 11-17-2011, 10:55 AM   #4 (permalink)
SLEDNECK56308's Avatar
Front shocks and front and rear bumper prices shipped to 56308.
SLEDNECK56308 is offline   Reply With Quote
Old 12-13-2011, 09:13 PM   #5 (permalink)
highmile440's Avatar
Current Sled(s): 14 SB Pro-R LE, 80 Citation SS
Previous Sled(s): 08 SB Dragon600, Fusion 660, 00' XC 600, 94 Polaris Indy 440
pm sent
highmile440 is offline   Reply With Quote
Old 01-14-2012, 01:41 AM   #6 (permalink)
k5blazer72's Avatar
Current Sled(s): 2015 Axys ProS 800 Switch w. ProX shocks
Previous Sled(s): '98 XC700, '80 SnoJet 440, '79 MotoSki Capri
Favorite Riding Area: On Snow...
15-16 Mileage: 400
14-15 Mileage: 2000 mi
Riding Since: 1987
I'm interested in the fronts shocks if you still have them? Price shipped to K0K 2G0 or how close are you to Sault Ste. Marie? My bro lives there...
k5blazer72 is offline   Reply With Quote
Old 01-19-2012, 09:04 PM   #7 (permalink)
Current Sled(s): Polaris IQR
Previous Sled(s): Pro xr Iq 660 Fusion 600
Favorite Riding Area: Track or Back Country Mountain
How much for the motor?
"Fuck Fear Just Pin It!"
Polariskid22 is offline   Reply With Quote
Old 01-21-2012, 04:50 PM   #8 (permalink)
Newbie
Default polaris pro x 600
Hi, I would like to buy the oil resivoir off the rear shock and the hose that connects it to the rear shock. Would you sell that separatly from the shock?
ahorner7 is offline   Reply With Quote
Old 01-22-2012, 04:58 PM   #9 (permalink)
mike@TZR motorsports's Avatar
Current Sled(s): 04 prox2 700 iqr 860cc and proxr 800
Previous Sled(s): bout every polaris made, see my blog on profile pg
Favorite Riding Area: southern tier of ny state
Riding Since: 1984
price on bare bone motor?? no carbs ,oil pump, recoil, flywheel ,stator or reeds whats yur price thank you
mike@TZR motorsports is offline   Reply With Quote
Old 01-22-2012, 07:09 PM   #10 (permalink)
Newbie
Current Sled(s): 01 xcsp 700
how much for the rumble pack?
xcsp63 is offline   Reply With Quote
