I have for sale a 800sx mod. It is basically all brand new, was stripped to the bare chassis and redone. The motor has been run for 10 mins. It has not been rode, and needs to be broke in the rest of the way.
Started out as a 06 600 mod and has a 05 800sx motor swapped in. When I say new I mean brand new off the shelf OEM parts.
The motor has been completely torn down and cases were split.
The crankshaft has been trued and welded.
The pistons and rings are new.
New V-force reeds.
New Carb boots
New orings/gaskets/seals.
Carbs were completely gone through new jets installed.
Has race gas head - was checked to see that it was straight and not warped.
New belt
New ceramic coating on the pipes and stinger.
New fuel pump
CDI was sent to arctic cat for programing
New speed sensor
New timing resistor
All bearings have been replaced with new.
New C&A XTX Skis
New studboy carbides
All new hoses - Every single coolant/fuel hose has been replaced.
New coolant bottle.
New handlebars.
New throttle cable
New throttle lever
New power valve cables
New brake assembly
New hyfax
Rear suspension completely rebuilt, new bushings, springs etc.
Rebuilt front shocks
Black front bumper with new nose bra
New airbox
New chain and gears
New stock 05 800sx weights and helix.
Polished tunnel
Black hood has new yamaha hood hold downs instead of cat, cats like to rip out.
New black powdercoat on everything.
Lots of new stainless steel hardware.
The track is the original, it is in ok shape but should be replaced. I have an almost new one to go with it.
I have a new black flyscreen which will be installed.
Choke cable has now been routed and hooked up.
I'm sure i've missed some things, but this sled is as good or better than new. I have receipts for everything I've done.
New V-force reeds.
New Carb boots
New belt
New fuel pump
New speed sensor
New timing resistor
New C&A XTX Skis
New coolant bottle.
New handlebars.
New throttle cable
New throttle lever
New brake assembly
New hyfax
New airbox
New chain and gears
Polished tunnel
