12V DC Supply - HCS Snowmobile Forums
Nytro This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 04-06-2011, 11:07 AM   #1 (permalink)
Default 12V DC Supply
I have a 2008 Yamaha Nytro that I want to add a 12V dc supply to so I can power up a heated shield. Where can I find the 12V supply on these sleds?
torszula is offline   Reply With Quote
Old 04-06-2011, 03:06 PM   #2 (permalink)
gobonas99's Avatar
Current Sled(s): 2010 Yamaha Vector LTX (pink)
Previous Sled(s): 2005 Sabrecat 600 LX (pinked out)
Favorite Riding Area: Old Forge and surrounding
12-13 Mileage: 2300
11-12 Mileage: 800
10-11 Mileage: 800
Riding Since: 2007
hahahahahahaahhahahaaha.....now that's funny. The 2008/2009 nytro's stator is barely big enough to heat the hand grips, and you want to add a heated shield? say bye-bye to ANY heat in the grips if you do that.
Yamaha put a larger stator in the nytros in 2010, so the handgrips actually work and headed sheilds could be added.
gobonas99 is offline   Reply With Quote
Old 04-06-2011, 03:34 PM   #3 (permalink)
cire's Avatar
Current Sled(s): 10 Nytro XTX 06 Crossfire 7
Previous Sled(s): 07 Attak
Favorite Riding Area: northern lower
10-11 Mileage: 1500
Riding Since: 1969
I dont think 08 had a acc. power outlet lead but if it does it is behind the pto side radiator mount and is a white lead with a white plug in the end of it. A acc 12 volt plug will install into it or you can cut it off and wire directly. You can also just run power from the battery.
cire is offline   Reply With Quote
Old 04-06-2011, 03:47 PM   #4 (permalink)
Favorite Riding Area: city streets of burton MI
Does`nt have to be DC, AC will work fine...
Heated sheilds are not sensitive to AC or DC..
Fixerupper is offline   Reply With Quote
Old 04-06-2011, 03:56 PM   #5 (permalink)
grizztracks's Avatar
Current Sled(s): FX Nytro RTX
Previous Sled(s): RS Vector
The 08 Nytro was not wired for the 12 volt accesory but it can be added. The fuse box has an empty keyed 12 volt socket that is used in the newer sleds for the feed. A terminal end and lead wire needs to be installed into the block before adding a 3 amp fuse. I picked up what I needed at a local auto parts store for a couple dollars. It's a little more work to run the needed wire into the the fuse box but at least it's done right.
grizztracks is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
