code 43 on 2008 nytro? - HCS Snowmobile Forums
Nytro This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-20-2011, 02:26 PM   #1 (permalink)
Default code 43 on 2008 nytro?
whatdoes it mean trying to help a buddy out over the phone and his nytro wont start and just says code 43
dexterdog is offline   Reply With Quote
Old 02-20-2011, 03:07 PM   #2 (permalink)
catchmeifucan's Avatar
Current Sled(s): 2012 F1100T SP LTD, 2007 Attak
Previous Sled(s): 1996 TCat 1004, PS1000 Cat
43
Fuel system voltage (monitor voltage)
The ECU is unable to monitor the battery voltage (an open circuit in the line to the ECU)
Fixes the battery voltage to 12 V
see:
TY 4 Stroke - Totallyamaha :: View topic - Error Codes for Apex, Attak, and Apex Mountain
catchmeifucan is offline   Reply With Quote
Old 02-20-2011, 03:07 PM   #3 (permalink)
that was for apes, imagine nytro same.
Old 02-20-2011, 03:14 PM   #4 (permalink)
oldsledhead's Avatar
Current Sled(s): 08 Vector LTX GT
Previous Sled(s): 02 Poo 500 classic,97 xlt touring,
Favorite Riding Area: Where theres snow
Riding Since: 1970
try these
If theres snow I,ll go.
oldsledhead is offline   Reply With Quote
Old 02-20-2011, 03:15 PM   #5 (permalink)
thanks... will see if this helps him, he is an hour away with no computer and i am a polaris guy who knows nothing about the nytro
Old 02-20-2011, 04:36 PM   #6 (permalink)
grizztracks's Avatar
Current Sled(s): 2015 Viper RTX SE, FX Nytro RTX, RS Vector
Check the 10 amp fuse on top of the starter relay. I think it's the front fuse that powers the fuel injection system, the rear is a spare. Also check the connector to the relay for corrosion. Another common problem is with the fuel relay which is the 3rd relay back from the front. It can be changed with the first (load control, lights) or 4th (fan) relay to get the sled running. Normally when the fuel relay malfunctions you won't hear the fuel pump run when the key is turned on.
grizztracks is offline   Reply With Quote
