NOAA erases the " pause " - HCS Snowmobile Forums
General Discussion Forum Where sometimes threads get Hyjacked!!!Please Refrain from Political subjects UNLESS the subject is DIRECTLY related to snowmobiling.ALL non snowmobiling political posts will be deleted. This Forum for off topic, mostly non-sledding related talk. Just remember comments about a member's Family is 100% OFF LIMITS! Posting pictures of another members family, personal attacks, and threatening posts involving physical harm, WILL NOT be tolerated. The calling out or posting of another members user name in the title of a thread, a members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently.
Old 06-10-2015, 11:54 AM   #1 (permalink)
nacapster's Avatar
Current Sled(s): 15 Ski-Doo Renegade X 1200
Previous Sled(s): 12 MXZ-X 800R E-Tec, 09 XP 800R, & 04 Rev 800 HO
Favorite Riding Area: Northern Minn
16-17 Mileage: 1,100
15-16 Mileage: 498
14-15 Mileage: 909
13-14 Mileage: 1442
Riding Since: 1985
Default NOAA erases the " pause "
Now who are the deniers... LOL
Climate scientists criticize government paper that erases ‘pause’ in warming
Until last week, government data on climate change indicated that the Earth has warmed over the last century, but that the warming slowed dramatically and even stopped at points over the last 17 years.
But a paper released May 28 by researchers at the National Oceanic and Atmospheric Administration has readjusted the data in a way that makes the reduction in warming disappear, indicating a steady increase in temperature instead. But the study’s readjusted data conflict with many other climate measurements, including data taken by satellites, and some climate scientists aren’t buying the new claim.
“While I’m sure this latest analysis from NOAA will be regarded as politically useful for the Obama administration, I don’t regard it as a particularly useful contribution to our scientific understanding of what is going on,” Judith Curry, a climate science professor at Georgia Tech, wrote in a response to the study.
And in an interview, Curry told FoxNews.com that that the adjusted data doesn’t match other independent measures of temperature.
“The new NOAA dataset disagrees with a UK dataset, which is generally regarded as the gold standard for global sea surface temperature datasets,” she said. “The new dataset also disagrees with ARGO buoys and satellite analyses.”
The NOAA paper, produced by a team of researchers led by Tom Karl, director of the agency’s National Climatic Data Center, found most of its new warming trend by adjusting past measurements of sea temperatures.
Global ocean temperatures are estimated both by thousands of commercial ships, which record the temperature of the water entering their engines, and by thousands of buoys – floatation devices that sit in the water for years.
The buoys tend to get cooler temperature readings than the ships, likely because ships’ engines warm the water. Meanwhile, in recent years, buoys have become increasingly common. The result, Karl says, is that even if the world’s oceans are warming, the unadjusted data may show it not to be warming because more and more buoys are being used instead of ships. So Karl’s team adjusted the buoy data to make them line up with the ship data. They also double-checked their work by making sure that the readjusted buoy readings matched ships’ recordings of nighttime air temperatures.
The paper came out last week, and there has not been time for skeptical scientists to independently check the adjustments, but some are questioning it because of how much the adjusted data vary from other independent measurements.
First, it disagrees with the readings of more than 3,000 “ARGO buoys,” which are specifically designed to float around the ocean and measure temperature. Some scientists view their data as the most reliable.
The ARGO buoy data do not show much warming in surface temperature since they were introduced in 2003. But Karl’s team left them out of their analysis, saying that they have multiple issues, including lack of measurements near the Arctic.
In an email, Karl told FoxNews.com that the ARGO buoy readings may be added to his data “if scientific methods can be found to line up these two types of temperatures together … (of course after correcting the systematic offsets) … This is part of the cumulative and progressive scientific process.”
Karl’s study also clashes with satellite measurements. Since 1979, NOAA satellites have estimated the temperature of Earth’s atmosphere. They show almost no warming in recent years and closely match the surface data before Karl’s adjustments.
The satellite data is compiled by two separate sets of researchers, whose results match each other closely. One team that compiles the data includes Climate Professors John Christy and Roy Spencer at the University of Alabama in Huntsville, both of whom question Karl’s adjusted data.
“The study is one more example that you can get any answer you want when the thermometer data errors are larger than the global warming signal you are looking for,” Spencer told FoxNews.com.
“We believe the satellite measurements since 1979 provide a more robust measure of global temperatures, and both satellite research groups see virtually the same pause in global temperatures for the last 18 years,” he said.
Karl said satellite data also have issues, including “orbital decay, diurnal sampling, instrument calibration target temperatures and more.”
Spencer said he agreed that those are issues, but they are less problematic than using data from thousands of ships and buoys. He added that there are a couple of satellites monitoring temperature at any given time, and that they are used to check each other.
Skeptics say there are yet more measurements, including those coming from balloon data, that line up with existing data more than with Karl’s newly adjusted data. They also note that even with Karl’s adjustments, the warming trend he finds over the last 17 years is below what U.N. models had predicted.
Some climate scientists applaud Karl’s adjustments and say they debunk the idea that the Earth has stopped warming.
“[This] points out just how small and fragile a notion that was,” Peter Frumhoff, director of science & policy at the Union of Concerned Scientists, told FoxNews.com
Asked about the contradiction with satellite data, he said he trusted the new paper.
“I trust the process of legitimate scientific peer review that this paper has undergone, as well as the care that its authors bring to their respected work,” he said, adding that, “the faux debate over a so-called ‘hiatus’ has been an unfortunate diversion from meaningful dialogue about how best to address the broadly recognized serious problem of climate change.”
But skeptics say Karl’s adjusted data is the outlier that conflicts with everything else. “Color me ‘unconvinced’,” Curry wrote.
nacapster is offline   Reply With Quote
Old 06-10-2015, 12:15 PM   #2 (permalink)
Super Moderator
fastsleddr's Avatar
Current Sled(s): 15 AXYS 800/ 09 shift 797/ 06 fuse 600
Previous Sled(s): Lots of everything
Favorite Riding Area: the bedroom YEEHAW!!
16-17 Mileage: 2860+
15-16 Mileage: 2750+
14-15 Mileage: 3408
13-14 Mileage: 2515+
Riding Since: 1968
A F$%^%$ joke, as usual!
fastsleddr is offline   Reply With Quote
Old 06-10-2015, 12:39 PM   #3 (permalink)
Super Moderator - Chris
Bontz's Avatar
Current Sled(s): 2016 Switchback 800 Pro-X
Previous Sled(s): '15 Rush Pro-S; '12 SB Pro-R; '11 Rush Pro-R; '09 D8; '07 F8
Favorite Riding Area: Lake Namakagon/Cable, WI
16-17 Mileage: 825
15-16 Mileage: 1100
14-15 Mileage: 1153
13-14 Mileage: 1450
Riding Since: 1975
It's laughable how these teams of scientists, who are pro warming, think they're fooling anyone. Gee, I wonder where the funding for this particular group of "adjusters" comes from .... hmmmm
Bontz is offline   Reply With Quote
Old 06-10-2015, 12:49 PM   #4 (permalink)
Super Moderator
A05GSHO's Avatar
Current Sled(s): 17 Assault 800
Previous Sled(s): 15 Gade XRS 800 14 SB Pro-R 800 13 Gade 12 SB Pro-R 800
Favorite Riding Area: Northeast WI, UP
16-17 Mileage: 694
15-16 Mileage: 1112
14-15 Mileage: 2297
13-14 Mileage: 2435
Riding Since: 1968
Data Shmata
2017 Polaris Switchback Assault 800- Extreme Rear Bumper, Ultimate Shovel Bag, Rox Hand Guards, Rox 4-6" adj Riser, .375 Torsion Springs
RIP Cappy You Will Be Missed
A05GSHO is offline   Reply With Quote
Old 06-10-2015, 12:54 PM   #5 (permalink)
Bontz's Avatar
16-17 Mileage: 825
15-16 Mileage: 1100
14-15 Mileage: 1153
13-14 Mileage: 1450
Riding Since: 1975
Originally Posted by A05GSHO View Post
Data Shmata
"Numbers Engineering" ... it's great George!!
Old 06-10-2015, 12:57 PM   #6 (permalink)
akvanden's Avatar
Current Sled(s): '12 Shift 600, 2002 Edge x 500
Previous Sled(s): '02 XCSP 700, '04 XCSP 600
Favorite Riding Area: Northern MN, Vermilion area
16-17 Mileage: 750
15-16 Mileage: 500
14-15 Mileage: 500
13-14 Mileage: 1200
Riding Since: 1995
Data Shmata
If it is warming, what does that mean, longer growing seasons and more food for Earths population? Other than us, I'm sure no one really cares we if we less snow and more rain.
If we had lived a billion years ago, I wonder how much we would have spent to stop the warming period the dinosaurs lived in. Damn those dinosaurs and all their dirty dino cars warming the earth.....
akvanden is offline   Reply With Quote
Old 06-10-2015, 03:05 PM   #7 (permalink)
nacapster's Avatar
15-16 Mileage: 498
14-15 Mileage: 909
13-14 Mileage: 1442
Riding Since: 1985
Data Shmata
Yeah, you pretty much can't believe a word they say when they pull crap like this. First it was the fudged NASA satellite data which changed the hottest year on record from 1934 to 1998 which was later reversed. Then the climate gate e-mails where they collaborated to conceal data that didn't favor their political agenda. And now they're trying to deny that the " pause " even exists.
Old 06-10-2015, 03:40 PM   #8 (permalink)
nacapster's Avatar
15-16 Mileage: 498
14-15 Mileage: 909
13-14 Mileage: 1442
Riding Since: 1985
And let's not forget all the temperature monitoring station pictures showing them located right next to hot a/c exhaust fans / vents, in the middle of black asphalt parking lots, and the best, right next to outdoor BBQ grills, burn barrels, etc...etc...
Old 06-10-2015, 03:41 PM   #9 (permalink)
TommCat Performance
Tommcat's Avatar
Current Sled(s): 13 Turbo, 07 F6, 72 Puma, 72-74 Cheetahs
Favorite Riding Area: Maine
Riding Since: 1977
when data doesn't back up your claims, simply adjust the data and create new 'facts' that do.
Authorized dealer for:
Aaen Performance
Bikeman Performance
B3C synthetic fuel treatments
CP-Carrillo
Cyclops LED lighting
Curve Industries
Full Throttle Speed
Hi-Performance Engineering
Millenium Technologies
PDP snowflaps
Sandale Fabrication
Scott Taylor Gears
Thermal Zero
Thunder Products
Old 06-10-2015, 05:19 PM   #10 (permalink)
The Lummox
xcr700's Avatar
Current Sled(s): 2011 pro r 800 rush retro,03 ZR 900(sold)
Previous Sled(s): 1998 xcr700,1998 xc700,1988 400 classic
Location: MT Olympus, Manitoba,the north end of the Interlake
Favorite Riding Area: Over there
15-16 Mileage: 1000
14-15 Mileage: Lol
13-14 Mileage: 1500
Riding Since: 1867
Sounds like this place lol
Success is 1% inspiration, 98 % perspiration, and 2% attention to detail
xcr700 is offline   Reply With Quote
