Power valve & servo motor - HCS Snowmobile Forums
440/race/modified This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-30-2008, 11:05 PM   #1 (permalink)
sledcross's Avatar
Current Sled(s): 2012 F800 SnoPro & 2010 SnoPro 600
Previous Sled(s): 2006 SnoPro 440/700 EFI
I just converted my 06 Snopro to a 700 EFI. For some reason the engine is running real rich, the inner electrodes are black on both plugs. Checked my servo motor (with the cables disconnected from it) and it does not cycle when started. I can't seem to get it to do anything at any RPM, not sure what the deal is.
I would expect this to be part of my problem with the engine running bad, but I want to get this working first before I continue diagnosing the engine. Any thoughts on what to look for with this servo motor problem?
sledcross is offline   Reply With Quote
Old 12-30-2008, 11:09 PM   #2 (permalink)
gregger454's Avatar
Try Blocking off your Oil Injection and running a Pre-Mix through it. Power Valves are over-rated, all they do is make the bottom end more torquey by obviously changing the exhaust port size. Bet you a beer it's your oil injection!
gregger454 is offline   Reply With Quote
Old 12-30-2008, 11:31 PM   #3 (permalink)
sledcross's Avatar
Try Blocking off your Oil Injection and running a Pre-Mix through it. Power Valves are over-rated, all they do is make the bottom end more torquey by obviously changing the exhaust port size. Bet you a beer it's your oil injection![/b]
Not a bad idea regarding using a premix gas to solve the black plug problem.
Anyone have ideas on the servo motor for the powervalves? This is on an 06 700 EFI motor, it doesn't cycle when started, it doesn't cycle when I'm on the gas ~half throttle on the track stand. Am I missing something? Did is there some other connection in the wiring loom that is critical to the functioning of the servo motor?
Old 12-31-2008, 07:28 AM   #4 (permalink)
hagstrom41's Avatar
I would start with checking all grounds. I have had problems there before.
hagstrom41 is offline   Reply With Quote
Old 12-31-2008, 08:09 AM   #5 (permalink)
Newbie
Are you using the 440 voltageregulator or one from a f7?
kungstenne is offline   Reply With Quote
Old 12-31-2008, 12:39 PM   #6 (permalink)
sledcross's Avatar
Are you using the 440 voltageregulator or one from a f7?[/b]
I am running a brand new voltage regular from an F7.
Old 12-31-2008, 05:17 PM   #7 (permalink)
dann's Avatar
Current Sled(s): 05 snopro 440 mod
Previous Sled(s): zr's,ext,wildcat
Favorite Riding Area: pow
Riding Since: 87
i think if the cables aren't adjust properly the servo wont work.
dann is offline   Reply With Quote
Old 01-01-2009, 08:57 AM   #8 (permalink)
steffe's Avatar
Current Sled(s): Sno Pro SX 600/700 -08
Previous Sled(s): 440/700 -04, 440/700 -06, 440 -00, RXL 650
On my sled there was a problem with the heaters on the handelbar, I had to disconnect them otherwise the sled would not run ok and also there was no light at all... Try put the sled on a stand and then rev it up to over 7200rpm and have a friend to see if the apv motor turns. If it does but the sled goes into limpmode adjust the cables and if that does not work move the cables to the other side of the servo and try again. Dont block the oil injection cause it lubricates the waterpump also!!
If you touch my cat I`ll f**k your dog...
BRP: Bring Rings & Pistons
4-strokes are full of parts - 2-strokes are full of speed
steffe is offline   Reply With Quote
Old 01-03-2009, 12:25 AM   #9 (permalink)
snoproracer484's Avatar
Current Sled(s): 2013 snopro 600 sx
Previous Sled(s): '07 iqr 600 mod, 2001 440 snopro, 1999 z370
on my snopro the servo motor crapped out and i swapped it with one off ebay out of a f7 or something. sometimes it just happens, they get dirty and get rusted on the inside and just stop working. my sled it would cycle then only open the first time i hammered the gas on a stand. you can go on ebay and get one for like $50 bucks "buy it now" all of the servos from like 01 and even through the firecat models are interchangable. if you have a buddy with a cat with powervalves swap it quick and run it on the stand and see what happens. takes like 10 minutes.
snoproracer484 is offline   Reply With Quote
