Gas/oil ratio chart and How To - HCS Snowmobile Forums
440/race/modified This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-03-2010, 12:11 AM   #1 (permalink)
03f5sp's Avatar
Current Sled(s): 2010 Sno Pro 500
Previous Sled(s): 07 440x, '05 MXZ600sdi, XLT 600, 05 GSX 550f, 03 F5 SnoPro
Favorite Riding Area: Northern WI/U.P.
Riding Since: 11
Default Gas/oil ratio chart and How To
Maybe sticky this?
How to figure out mix ratios: Ok you got some number like 30:1 or 50:1 or whatever and you want to know how much oil to mix in the amount of gas you have... first need like units ie.. gallons (gal) and gallons or ounces (oz) and ounces. Normally gas is in gallons and 2 cycle oil is in ounces so we need to convert one to the other ... just convert gallons to ounces.
There are 128 oz in a gallon. - trust me!!.</B>
128 oz of gas mixed 50:1 = 128oz / 50 parts = 2.56oz Yes when you add in the oil there will be 51 total parts this is not a problem you are using a mix ratio Ie. mix 50 cups of gas with 1 cup of oil ... or ... 50:1 ... Ok ???
Don't over analyze this: The engineers of the motors for our sleds tried to make it easy on us.
Or for the math people ... Where
G = Gallon(s) of gas you have.
M = Mix Constant (ie 50 if you are using 50:1)
G * 128
------- = oz's of oil to add
M
If you are still confused just use the chart below... find how much gas you got on top and your ratio on the side and meet them to find the amount of oil you will need. "In ounces (oz)"
03f5sp is offline   Reply With Quote
Old 12-03-2010, 12:20 AM   #2 (permalink)
03f5sp's Avatar
Riding Since: 11
chart
Old 12-03-2010, 08:47 AM   #3 (permalink)
sled208's Avatar
Current Sled(s): 2017 ZR 800 RR 137" ES LOL OR 2016 m8 ltd
Previous Sled(s): 13m8 13&12 XF HC, 4 X-fires, F7, 4 poos
Favorite Riding Area: On top of snow
Riding Since: 1988
If you have an android phone there's an app for $0.99 you enter exactly how many gallons, what ratio you want and WHALLLA.......
sled208 is online now   Reply With Quote
Old 12-04-2010, 03:11 AM   #4 (permalink)
Nice...
03'MXZX 440
99'MXZ 670 HO Tony Haikonen
96'zrt 600
99'ZR 600EFI
06'LTR 450
07'Polaris Sportsman 450
85'LT 125
04'HEMI 4X4
87'CHEVY 6''lift 35''BFG'S,435HP Smallblock,4.56's
06ltr450 is offline   Reply With Quote
Old 12-07-2010, 09:49 AM   #5 (permalink)
Current Sled(s): 08 600rs
Previous Sled(s): 07 phazer
Riding Since: 1998
you my friend... SUCK haha
yo dude 12 is offline   Reply With Quote
Old 02-25-2011, 10:02 AM   #6 (permalink)
axel cannon's Avatar
Current Sled(s): 2007 iqr Rolling mod W/440
Previous Sled(s): 2003 MXZx 440, 2001 Polaris supersport 550
Favorite Riding Area: Brainerd
Riding Since: 1996
When i was mixing for my 440 i would run it 50:1 and didn't have any problems, it was fully trail converted with heads, needles, just not oil injected. I had my tank marked every 2.5 gallons until full which was not 10.5 gallons. and for every 5 gallons it was about 16 oz of oil, this would give you around 48:1 if i remember right. and it was simple math from there depending on how much you needed, and from the markings on the tank it was easy to know how much you needed. i would always carry around a quart of oil which is 32oz so i could get 10 gallons. this is just my method on mixing and it worked great for me, and if you were off my an oz or two its not a big deal the ratio isn't going to fluctuate that much.
axel cannon is offline   Reply With Quote
Old 09-12-2011, 07:56 PM   #7 (permalink)
squidward's Avatar
Current Sled(s): DooDoo
Previous Sled(s): 04 XR 440/800 triple
Favorite Riding Area: da UP boondocking
Riding Since: 1997
Easiest math is 40:1. 10 gallons fuel, 1 quart....5 gallons, 1/2 qt (16 oz)......2.5 gallons, 1/4 qt (8 oz). I never go beyond that and just get pretty close. Am normally about 7.5 to 8 gallons per fillup and put 3/4 of a quart (24oz) of oil in. This way you can get pretty damn close with just any regular quart container. After years of racing motoX, and messing with ratio rites that go 2.5 gallons at a time, I gave up. Take my 5 gallon jug to the pump, dump 1/2 qt in, and fill it up.
Truly easiest way is to buy this round container that is marked to different ratios....I bought mine in the marine section at Fleet Farm....looks like a nalgene bottle basically. Holds at least enough oil for 40:1 and 10 gallons and fits nicely in my packpack water bottle holder.
2007 Summit 800 X - 155
2011 600 RS
squidward is offline   Reply With Quote
Old 10-28-2011, 11:12 PM   #8 (permalink)
Rhubarb's Avatar
Current Sled(s): 99 MXZx 440, 99 MXZ 600, 01, MXZx 440 ,
Previous Sled(s): Also...98 Imp 800, 01 Mach Z, 02 Mxz 800
Favorite Riding Area: Around Home
14-15 Mileage: 500
13-14 Mileage: 700
Riding Since: 80's
Never thought I would ever say this but. .... This is where the metric system is better. I hate metric sys most of the time but..... 40L gas tank on sled 1L of oil needed : 30 - 750 ml 20 - 500 ml 10 - 250 ml 5 - 125 ml all for 40:1
RIP LOKI you were the best Puppy ever and best friend I could have ever asked for. Your life was to short buddy Nov 06 2003 - February 23 2011.
Rhubarb is offline   Reply With Quote
