2004 pro xr 440 carb troubles - HCS Snowmobile Forums
440/race/modified This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 01-14-2011, 08:19 PM   #1 (permalink)
Member
Default 2004 pro xr 440 carb troubles
hey guys i need some help/opinions.
i had my 440 out for the first run of the year today , and i noticed a studder in the engine. when stopped , if i tried to give the sled full throtle at a dead stop it would take off slowly and almost like it was loading up on gas , it felt as if it was running on one cylinder , let off the gas and ease it on to full throtle and the thing takes off like a rocket , and it does the same again if cruising at half throtle for extended periods of time and then go right to full throtle again and it does the same studder it does when stopped to full throttle , anybody have any encounters similar to this or got an idea on what it could be?
i was thinking maybe changing the clip position on the needle valve?
anybody have any ideas? it would be VERY apreciated
tyler ryan is offline   Reply With Quote
Old 01-14-2011, 09:49 PM   #2 (permalink)
SnoPro420's Avatar
Current Sled(s): 2011 IQr 600mod
Previous Sled(s): 01, ProX440, 02,04,06 440/600mods
Favorite Riding Area: U.P. MI & Steamboat springs CO
10-11 Mileage: 500
09-10 Mileage: 250
Riding Since: 3
tell us what you have for a set up in the carb now?????? main jet size, needle clip position, pilot jet size
In Loving Memory of Sam McLam #163 We Miss You!
Current Sleds:2011 Poo IQr 600mod
Previous Sleds: 01 ProX440, 02 Cat SnoPro440, 04 Cat SnoPro440, 06 Cat SnoPro440, 06 Cat Factory 600mod, 2010 IQr 600mod
O.I.F. - O.E.F. Combat Vet 2007-2011
SnoPro420 is offline   Reply With Quote
Old 01-15-2011, 07:46 AM   #3 (permalink)
Member
i was hoping it was something simply diagnosed like chipped reeds or something
as for my setup i would imagine it is close to stock , i have only had this skidoo over the summer and i didnt want to take the carb apart untill i knew where the sled was too in regards to how it runs.
so to answer your questions im assuming it is stock , the sled was trail converted by the polaris dealership , so if there is any carb issues involved with trail converting this sled then it was done by the dealer , otherfrom that i think it could be pretty well stock. sorry for the lack of info
Old 01-15-2011, 01:34 PM   #4 (permalink)
Current Sled(s): 03 Proxr 440
Previous Sled(s): 1994 Indy 440
09-10 Mileage: 700
Riding Since: 1993
The polaris specs are way off as far as jetting is on this thing. Also dont keep it a partial throttle as it will run lean. They were not designed to run there and the needle is to lean. You have to have a sort of snowx throttle on and off.
cbutch is offline   Reply With Quote
Old 01-16-2011, 12:37 AM   #5 (permalink)
Member
Current Sled(s): 2002 Pol PRO X 440
Previous Sled(s): 02 XC800X, 96 XLT, 02 ZL800, 02XC800, et
Favorite Riding Area: Anywhere with snow.
10-11 Mileage: 0 work!
09-10 Mileage: 750
Riding Since: 1972
Clean your carbs! And put in a fresh tank of gas. I say this as you state that this was the first run of the year. If your like most of the guys I here about you take it off the trailer and try to go. I clean my carbs every year before I ride any of my sleds just because you never know and it dosn't matter how much stabile you put in the tank. I have had the pilots get gunked up using that as well. Clean the carbs.
motorhead1216 is offline   Reply With Quote
Old 01-16-2011, 12:00 PM   #6 (permalink)
Member
turns out it was just the homemade can leaning out the engine , put the stock silencer on it and it was a completely diffrent machine , if i puts it back on ill just richen it up in the carb , but for now i think its going to stay as is.
thanks very much for the good info , not so much for dirty comments
thanks guys!
Old 01-16-2011, 12:47 PM   #7 (permalink)
09-10 Mileage: 700
Riding Since: 1993
Dont worry about the comments and continue to ask questions. That is how I learned lots of reading with a few questions here and there. Your going to love the sled.
Old 01-16-2011, 08:56 PM   #8 (permalink)
Member
yeah i love the sled man! it has wayy more power then any of the mxz 440's i ride with. i am completely overwhelmed with the power it has.
Old 01-17-2011, 01:50 AM   #9 (permalink)
akiqpilot's Avatar
You say the sled was trail converted by the dealer? If possible you should ask the dealer if they put the trail needle in the carbs. The trail needle adds fuel in the 1/4 throttle range and will prevent to motor from burning down.
Also, run the timing box on "E", you could run "F" or "G" if you get a batch of bad fuel but "E" is the setting for Pump Gas.
Also, Pump Gas means 92 octane and nothing less. Running inferior fuel is not good for this motor.
Also, the '04 440 has an issue with the center bearing on the crank. If the dealer or you haven't already addressed this issue then you are on borrowed time. The sled won't make it past about 10-15 tanks of fuel and you will blow the crank. There is a thread in the pinned topics discussing different ways to fix this problem. Every tank of fuel you run through the motor is taking life off the crank. This issue must be fixed or you will be very dissapointed here very soon.
Don't drive the sled like a sally, it's meant to be driven hard. Thats how it should be ridden, like a dirt bike. On and Off the throttle continually.
"Never argue with an idiot; they'll drag you down to their level and beat you with experience." ~ anonymous
akiqpilot is offline   Reply With Quote
Old 01-17-2011, 03:09 PM   #10 (permalink)
Member
regarding the badbearing issue. how will i know that its fixed? how will i know if it is going??
and were there some recall on the bearing or something that the dealer put in a longer lasting bearing?
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
