Chain Case Oil - HCS Snowmobile Forums
General Snowmobile Forum This is a serious discussion forum and a 100% NO BASHING ZONE. This area is here for members who are looking for serious answers for serious questions or discussion and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website Without Warning.The calling out or posting of another members user name in the title of a thread a members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently.
Old 07-19-2007, 07:01 PM   #1 (permalink)
codyg's Avatar
Current Sled(s): 2005 Sabertcat 700 EXT
Previous Sled(s): 1996 ZRT 600
Riding Since: 1998
What type of chain case oil you guys use? I just drianed my ZRT and the manual just tells me the part number or something that operates in low temps. Does it matter wat weight? Like 40, 60, 80, ect.
codyg is offline   Reply With Quote
Old 07-19-2007, 07:12 PM   #2 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
What type of chain case oil you guys use? I just drianed my ZRT and the manual just tells me the part number or something that operates in low temps. Does it matter wat weight? Like 40, 60, 80, ect.[/b]
Chaincase oils are usually thinner, and may contain synthetics or graphite, they are designed for a link chain and gear combination. Heavier oils such as 80-90 weights are designed for gears which mesh together and run under heavy loads.
Don
Old 07-19-2007, 07:20 PM   #3 (permalink)
Super Advanced Lummox
FreezerBurnt's Avatar
Current Sled(s): 07 Switchback 600 CFI
Previous Sled(s): XCR 600
Favorite Riding Area: NW of Sudbury
Riding Since: 76
I have been using 80w90 semi synthetic the past few years and have used regular 80w90 for over 20yrs
FreezerBurnt is offline   Reply With Quote
Old 07-19-2007, 07:25 PM   #4 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
I have been using 80w90 semi synthetic the past few years and have used regular 80w90 for over 20yrs[/b]
Heh, here we go again. Why would you use such heavy oil, it's not made for link belt chains and will rob horsepower and top speed, it would be wiser to use ATF as Kawasaki did with non-Hyvo chains.
Don
Old 07-19-2007, 07:52 PM   #5 (permalink)
sspolaris's Avatar
I use the Klotz chain case lube. Fairly inexpensive and it's loaded with graphite.
sspolaris is offline   Reply With Quote
Old 07-19-2007, 07:53 PM   #6 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
I use the Klotz chain case lube. Fairly inexpensive and it's loaded with graphite.[/b]
Great product.
Old 07-19-2007, 10:07 PM   #7 (permalink)
Favorite Riding Area: UP and Lewiston
15-16 Mileage: 580
Riding Since: 1978
I use what ever they have at the dealership ams oil, Arctic Cat or Ski Doo as long as you change it at least once a season depending on how much you ride you will be just fine.
vax2005 is offline   Reply With Quote
Old 07-20-2007, 12:19 PM   #8 (permalink)
Riding Since: 76
Post
Don[/b]
Been using that for yrs
Everyone I know uses it on their sleds
I am still not sold on ATF though
Not arguing with you on this as you race your sleds but all I am saying is that is the type of lube I have used
Might try ATF for this season,as I change my fluids each fall
Old 07-20-2007, 12:29 PM   #9 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
I know guys which use 80-90 wt. also, just it's those oils are power robbing in cold weather, designed as anti-sling meshing hi loading gear oils, not made for link belt chain systems at all--, if used on Yamaha or Polaris hyvo chains, after time it will ruin the chains ability to flex at hi-speeds, I have seen it happen on several sleds in the last 10 years or so on customers sleds, I am at a loss to understand why anyone would think that the thicker oils penetrate the pins on link belt chains as well as the proper oils designed by the engineers to work at temp. extremes such as a chaincase on sleds.-- Not related but even transfer cases in 4X4 trucks use either ATF or special very thin "blue oils".
Don
Old 07-20-2007, 12:40 PM   #10 (permalink)
DirtyDawg's Avatar
Don[/b]
Don, I believe you on the qualities of the oil for sure. I think my Yammi manual specs GL3 or 4 though. I'll have to check.
I run full-syn 75W90 in mine.
I drove a Subaru and I have a bucket full of balls, a yard full of dick, and enough hair on my ass to weave an oriental rug. I AM A MAN..............Braaaaaaaaaaaaaaaaaaaaaaaaaaaap.
DirtyDawg is offline   Reply With Quote
